Ich kann leider nicht sagen, ob es über pon genauso funktionieren würde.
Schau dir sicherheitshalber mal das Log mit debuglevel 5 an. Du kannst das Loglevel in der homegear Konsole mit dl 5 zur Laufzeit ändern.
Lege ich den Aktor manuell mit peers create an, komme ich zu dem gleichen Ergebnis wie mit pon
Hier ein Log Auszug mit Debug Level 5 vom Betätigen des Tasters:
10/01/17 12:58:52.370 Debug (My-EnOcean-Interface): Packet enters raisePacketReceived.
10/01/17 12:58:52.370 Debug (My-EnOcean-Interface): Packet is now passed to the EventHandler.
10/01/17 12:58:52.370 EnOcean packet received (My-EnOcean-Interface, RSSI: -95 dBm): 55000707017AF60001Axxxxx2001FFFFFFFF5F0022 - Sender address: 0x01Axxxxx
10/01/17 12:58:52.371 Debug (My-EnOcean-Interface): Packet processing of packet took 0 ms.
10/01/17 12:58:52.418 Debug (My-EnOcean-Interface): Packet enters raisePacketReceived.
10/01/17 12:58:52.418 Debug (My-EnOcean-Interface): Packet is now passed to the EventHandler.
10/01/17 12:58:52.417 EnOcean packet received (My-EnOcean-Interface, RSSI: -89 dBm): 55000707017AF61001Axxxxx3101FFFFFFFF590007 - Sender address: 0x01Axxxxx
10/01/17 12:58:52.418 Debug (My-EnOcean-Interface): Packet processing of packet took 0 ms.
10/01/17 12:58:52.465 Debug (My-EnOcean-Interface): Packet enters raisePacketReceived.
10/01/17 12:58:52.466 Debug (My-EnOcean-Interface): Packet is now passed to the EventHandler.
10/01/17 12:58:52.465 EnOcean packet received (My-EnOcean-Interface, RSSI: -89 dBm): 550009070156D20460E401Axxxxx0101FFFFFFFF590001 - Sender address: 0x01Axxxxx
10/01/17 12:58:52.466 Debug (My-EnOcean-Interface): Packet processing of packet took 0 ms.
Und hier vom Ändern eines Kanals über Homegear:
10/01/17 13:09:20.864 Module EnOcean: Info: STATE of peer 35 with serial number EOD01Axxxxx:1 was set to 0x00.
10/01/17 13:09:20.865 Module EnOcean: EnOcean USB 300 "My-EnOcean-Interface": Info: Sending packet 550009070156D2010000FFA2BA00000301Axxxxx000062
10/01/17 13:09:20.907 Module EnOcean: EnOcean USB 300 "My-EnOcean-Interface": Info: Ignoring packet from myself: 550009070156D2010000FFA2BA00810101Axxxxx5C0087
ID │ Name │ Serial Number │ Address │ Type │ Type Description
23 │ │ EOD01AXXXXX │ 01A2XXXX │ 1A53802 │ Eltako FUD61NPN-230V
OK this works thanks.
Do I have to pair the dimmer in homegear?
I have now read the serial number through the logs and use them.
Do I have to do something else?
