Hi
I managed to set up homegear and the MQTT publishing, however the commands sent to homegear in MQTT are not working
with the command mosquitto_pub -t homegear/climate/set/1/1/SET_TEMPERATURE -m 22 nothing happens on my radiator vane (peer 1)
but docker exec -it homegear homegear -e rc '$hg->setValue("OKF0003066:1", "SET_TEMPERATURE", 22.0);'works, so the link with the vane is working
on the topic homegear/climate/plain/1/1 I can see all the published values
for information, the list of peers in homegear:
ID │ Name │ Address │ Serial Number │ Type │ Type String │ Firmware │ Unreach
1 │ │ 1B8F6F │ OKF0003066 │ 01A1 │ BC-RT-TRX-CyN │ 1.1 │ No
also here is the output of the homegear.log when I send a command in MQTT:
04/11/19 20:28:18.026 Info: REST RPC call received. Method: getValue
04/11/19 20:28:18.027 RPC Server (Port 2001): Debug: Connection to client number 169 closed.
04/11/19 20:28:18.028 RPC Server (Port 2001): Debug: Connection to client number 169 closed (1).
04/11/19 20:28:18.053 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.1.100:45712 accepted. Client number: 170
04/11/19 20:28:18.054 RPC Server (Port 2001): Info: RPC server client id for client number 170 is: 84
04/11/19 20:28:18.057 RPC Server (Port 2001): Listening for incoming packets from client number 170.
04/11/19 20:28:18.058 RPC Server (Port 2001): Debug: Packet received: 474554202F6170692F76312F7661726961626C652F312F312F434F4D464F52545F54454D504552415455524520485454502F312E310D0A486F73743A203139322E3136382E312E3130303A323030310D0A4163636570742D456E636F64696E673A206964656E746974790D0A0D0A
04/11/19 20:28:18.058 Info: REST RPC call received. Method: getValue
04/11/19 20:28:18.060 RPC Server (Port 2001): Debug: Connection to client number 170 closed.
04/11/19 20:28:18.060 RPC Server (Port 2001): Debug: Connection to client number 170 closed (1).
04/11/19 20:28:25.031 Debug (max-cube): Packet 0900060400000000000D enters raisePacketReceived.
04/11/19 20:28:25.032 Debug (max-cube): Packet 0900060400000000000D is now passed to the EventHandler.
04/11/19 20:28:25.031 MAX packet received (max-cube, RSSI: 0x50): 0900060400000000000D
04/11/19 20:28:25.032 Debug (max-cube): Packet processing of packet 0900060400000000000D took 0 ms.
04/11/19 20:28:27.187 Debug: MQTT packet received: D000
04/11/19 20:28:27.187 MQTT Client: Debug: Packet received: D000
04/11/19 20:28:27.188 MQTT Client: Debug: Received ping response.
04/11/19 20:28:28.632 Debug: MQTT packet received: 302C0028686F6D65676561722F636C696D6174652F7365742F312F312F5345545F54454D50455241545552453230
04/11/19 20:28:28.632 MQTT Client: Debug: Packet received: 302C0028686F6D65676561722F636C696D6174652F7365742F312F312F5345545F54454D50455241545552453230
04/11/19 20:28:28.633 Info: MQTT RPC call received. Method: setValue
04/11/19 20:28:31.211 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.1.10:64306 accepted. Client number: 171
04/11/19 20:28:31.212 RPC Server (Port 2001): Info: RPC server client id for client number 171 is: 85
04/11/19 20:28:31.213 RPC Server (Port 2001): Listening for incoming packets from client number 171.
04/11/19 20:28:31.214 RPC Server (Port 2001): Debug: Packet received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
04/11/19 20:28:31.214 RPC Server (Port 2001): Info: Client number 171 is calling RPC method: ping (1) Parameters:
(String) hmm
04/11/19 20:28:31.216 MQTT Client: Debug: queueMessage(peerId, channel, keys, values) -> peerId=0, channel=-1, keys, values
04/11/19 20:28:31.217 MQTT Client: Debug: queueMessage (message) topic: plain/0/-1/PONG message:hmm
04/11/19 20:28:31.217 MQTT Client Info: Publishing topic homegear/climate/plain/0/-1/PONG
04/11/19 20:28:31.218 MQTT Client: Debug: Sending: 33270020686F6D65676561722F636C696D6174652F706C61696E2F302F2D312F504F4E470035686D6D
04/11/19 20:28:31.218 RPC Server (Port 2001): Response:
(Boolean) 1
04/11/19 20:28:31.218 RPC Server (Port 2001): Response packet: HTTP/1.1 200 OK
Connection: Keep-Alive
Content-Type: text/xml
Content-Length: 123
<?xml version="1.0"?><methodResponse><params><param><value><boolean>1</boolean></value></param></params></methodResponse>
04/11/19 20:28:31.219 Debug: MQTT packet received: 40020035
04/11/19 20:28:31.220 MQTT Client: Debug: Packet received: 40020035
04/11/19 20:28:31.220 MQTT Client: Debug: Received PUBACK.
04/11/19 20:28:31.220 RPC client: Debug: Calling RPC method "system.multicall" on server 192.168.1.10.
04/11/19 20:28:31.221 RPC client: Parameters:
(Array length=1)
(Struct length=2)
[methodName]
(String) event
[params]
(Array length=4)
(String) hmm_BidCos-RF
(String) CENTRAL
(String) PONG
(String) hmm
04/11/19 20:28:31.221 Debug: Calling getFileDescriptor...
04/11/19 20:28:31.221 Debug: Connecting to host 192.168.1.10 on port 2000...
04/11/19 20:28:31.224 Debug: Connected to host 192.168.1.10 on port 2000. Client number is: 172
04/11/19 20:28:31.224 RPC client: Debug: Sending packet: POST /RPC2 HTTP/1.1
User-Agent: Homegear 0.7.37-2722
Host: 192.168.1.10:2000
Content-Length: 424
Connection: close
any idea of what is happening?
