I don’t know if I should start a new topic (I’ve been the only one creating topics lately!) but now I have an issue of homegear crashing, usually during the night…
Here is the log from last night, where it crashed at 4:38, and I restarted it manually at 7:15…
05/07/19 04:35:33.426 IPC Server: Error: No or invalid response received to RPC request. Method: broadcastEvent
05/07/19 04:35:25.501 MAX packet received (max-cube, RSSI: 0x50): 0900060400000000000D
05/07/19 04:35:35.392 IPC Server: Info: Connection accepted. Client number: 148
05/07/19 04:35:37.618 IPC Server: Error: No or invalid response received to RPC request. Method: broadcastEvent
05/07/19 04:35:38.082 IPC Server: Error calling "broadcastEvent" on client 79: No response received.
05/07/19 04:35:38.083 IPC Server: Info: Client 81 successfully registered RPC method "managementGetCommandStatus" (this method is registered by 2 client(s)).
05/07/19 04:35:38.083 IPC Server: Error calling "broadcastEvent" on client 79: No response received.
05/07/19 04:35:48.079 IPC Server: Info: Connection accepted. Client number: 150
05/07/19 04:35:48.770 IPC Server: Info: Client 82 successfully registered RPC method "managementGetCommandStatus" (this method is registered by 3 client(s)).
05/07/19 04:35:58.963 IPC Server: Info: Connection accepted. Client number: 151
05/07/19 04:36:09.757 IPC Server: Info: Connection accepted. Client number: 152
05/07/19 04:35:55.757 MAX packet received (max-cube, RSSI: 0x50): 0900060400000000000D
05/07/19 04:36:09.804 MAX packet received (max-cube, RSSI: 0x39): 0CDC0442182F821B8F5C0022B9
05/07/19 04:36:18.711 IPC Server: Info: IPC client 79 removed.
05/07/19 04:36:20.574 IPC Server: Info: Connection accepted. Client number: 154
05/07/19 04:36:33.284 IPC Server: Info: Connection accepted. Client number: 155
05/07/19 04:36:33.383 MQTT Client: Error: No PINGRESP received.
05/07/19 04:36:43.385 IPC Server: Info: Client 83 successfully registered RPC method "managementGetCommandStatus" (this method is registered by 4 client(s)).
05/07/19 04:36:46.904 IPC Server: Info: Connection accepted. Client number: 157
05/07/19 04:36:48.748 IPC Server: Info: Client 84 successfully registered RPC method "managementGetCommandStatus" (this method is registered by 5 client(s)).
05/07/19 04:37:01.944 IPC Server: Info: Connection accepted. Client number: 159
05/07/19 04:37:04.239 IPC Server: Info: Client 86 successfully registered RPC method "managementGetCommandStatus" (this method is registered by 6 client(s)).
05/07/19 04:37:06.643 IPC Server: Error: IPC client with ID 80 is not responding... Closing connection.
05/07/19 04:37:09.157 IPC Server: Error: No or invalid response received to RPC request. Method: broadcastEvent
05/07/19 04:37:10.931 IPC Server: Info: Client 85 successfully registered RPC method "managementGetCommandStatus" (this method is registered by 6 client(s)).
05/07/19 04:37:13.631 IPC Server: Info: Connection accepted. Client number: 162
05/07/19 04:37:14.586 MQTT Client: Error: Connection to MQTT server with protocol version 3 failed.
05/07/19 04:37:16.682 Critical: Physical interface's (max-cube) lifetick was not updated for more than 60 seconds.
05/07/19 04:37:17.515 Critical: Killing child process.
05/07/19 04:37:18.214 Info: Process with id 2786 ended.
05/07/19 04:37:18.215 Homegear was terminated. Restarting (1)...
05/07/19 04:37:28.298 Homegear was terminated. Restarting (2)...
05/07/19 04:37:28.991 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
05/07/19 04:37:28.992 Info: Core file size now is "4294967295".
05/07/19 04:37:28.992 Info: Setting maximum thread priority to "0" for user with id 0 and group with id 0.
05/07/19 04:37:28.993 Info: Maximum thread priority now is "0".
05/07/19 04:37:29.697 Info: Backing up database...
05/07/19 04:37:30.112 Initializing database...
05/07/19 04:37:30.353 Info: Loading family module (type 1) mod_sonos.so
05/07/19 04:37:30.968 Info: Loading settings from /etc/homegear/families/sonos.conf
05/07/19 04:37:31.336 Info: Loading family module (type 1) mod_beckhoff.so
05/07/19 04:37:31.404 Info: Loading settings from /etc/homegear/families/beckhoff.conf
05/07/19 04:37:31.485 Module Beckhoff: Error in file Interfaces.cpp line 45 in function virtual void MyFamily::Interfaces::create(): The provided hostname is empty.
05/07/19 04:37:31.500 Info: Loading family module (type 1) mod_homematicwired.so
05/07/19 04:37:31.607 Info: Loading settings from /etc/homegear/families/homematicwired.conf
05/07/19 04:37:31.626 Info: Loading family module (type 1) mod_homematicbidcos.so
05/07/19 04:37:31.816 Info: Loading settings from /etc/homegear/families/homematicbidcos.conf
05/07/19 04:37:31.916 Info: Loading family module (type 1) mod_philipshue.so
05/07/19 04:37:32.019 Info: Loading settings from /etc/homegear/families/philipshue.conf
05/07/19 04:37:32.087 Info: Loading family module (type 1) mod_ipcam.so
05/07/19 04:37:32.233 Info: Loading settings from /etc/homegear/families/ipcam.conf
05/07/19 04:37:32.413 Info: Loading family module (type 1) mod_max.so
05/07/19 04:37:32.531 Info: Loading settings from /etc/homegear/families/max.conf
05/07/19 04:37:32.568 Info: Loading family module (type 1) mod_enocean.so
05/07/19 04:37:32.668 Info: Loading settings from /etc/homegear/families/enocean.conf
05/07/19 04:37:32.698 Info: Loading family module (type 1) mod_knx.so
05/07/19 04:37:32.865 Info: Loading settings from /etc/homegear/families/knx.conf
05/07/19 04:37:32.881 Info: Loading family module (type 1) mod_intertechno.so
05/07/19 04:37:32.932 Info: Loading settings from /etc/homegear/families/intertechno.conf
05/07/19 04:37:32.971 Info: Loading family module (type 1) mod_insteon.so
05/07/19 04:37:33.071 Info: Loading settings from /etc/homegear/families/insteon.conf
05/07/19 04:37:33.104 Info: Loading family module (type 1) mod_miscellaneous.so
05/07/19 04:37:33.273 Info: Loading settings from /etc/homegear/families/miscellaneous.conf
05/07/19 04:37:33.275 Info: Loading family module (type 1) mod_ccu.so
05/07/19 04:37:33.350 Info: Loading settings from /etc/homegear/families/ccu.conf
05/07/19 04:37:33.355 Info: Loading family module (type 1) mod_kodi.so
05/07/19 04:37:33.436 Info: Loading settings from /etc/homegear/families/kodi.conf
05/07/19 04:37:33.449 Info: Loading family module (type 1) mod_zwave.so
05/07/19 04:37:34.049 Info: Loading settings from /etc/homegear/families/z-wave.conf
05/07/19 04:37:34.445 Info: Loading family module (type 1) mod_mbus.so
05/07/19 04:37:34.493 Info: Loading settings from /etc/homegear/families/m-bus.conf
05/07/19 04:37:34.520 Info: Setting up physical interfaces and GPIOs...
05/07/19 04:37:34.619 Info: Dropping privileges to user homegear (1000) and group homegear (1000)
05/07/19 04:37:34.679 Info: Homegear is (now) running as user with id 1000 and group with id 1000.
05/07/19 04:37:35.424 Starting script engine server...
05/07/19 04:37:35.682 Initializing licensing controller...
05/07/19 04:37:35.683 Loading licensing controller data...
05/07/19 04:37:35.684 Loading devices...
05/07/19 04:37:35.686 Loading XML RPC devices...
05/07/19 04:37:39.723 Loading device 1
05/07/19 04:37:40.275 Module HomeMatic BidCoS: Info: Central address set to 0xFDD019.
05/07/19 04:37:40.452 Loading XML RPC devices...
05/07/19 04:37:40.955 Loading device 2
05/07/19 04:37:40.993 Loading XML RPC devices...
05/07/19 04:37:41.110 Loading device 3
05/07/19 04:37:41.185 Loading XML RPC devices...
05/07/19 04:37:41.701 Loading device 4
05/07/19 04:37:41.959 Module MAX: Info: Central address set to 0xFD1111.
05/07/19 04:37:42.045 Module MAX: Loading MAX! peer 1
05/07/19 04:37:46.730 Module MAX: Loading MAX! peer 2
05/07/19 04:37:48.113 Module MAX: Loading MAX! peer 3
05/07/19 04:37:48.568 Module MAX: Loading MAX! peer 4
05/07/19 04:37:48.635 Module MAX: Loading MAX! peer 5
05/07/19 04:37:48.794 Module MAX: Loading MAX! peer 6
05/07/19 04:37:48.851 Module MAX: Loading MAX! peer 7
05/07/19 04:37:48.914 Module MAX: Loading MAX! peer 8
05/07/19 04:37:48.958 Module MAX: Loading MAX! peer 9
05/07/19 04:37:49.021 Module MAX: Loading MAX! peer 10
05/07/19 04:37:49.358 Info: Not initializing device family Philips hue, because it is disabled in it's configuration file.
05/07/19 04:37:50.366 Info: Disposing family module mod_philipshue.so
05/07/19 04:37:51.644 Loading XML RPC devices...
05/07/19 04:37:57.162 Loading device 5
05/07/19 04:37:59.929 Loading XML RPC devices...
05/07/19 04:38:01.139 Warning: Unknown parameter property: label
05/07/19 04:38:01.831 Warning: Unknown parameter property: label
05/07/19 04:38:02.433 Loading device 6
05/07/19 04:38:02.692 Loading XML RPC devices...
05/07/19 04:38:03.608 Loading device 7
05/07/19 04:38:04.037 Loading XML RPC devices...
05/07/19 04:38:04.407 Warning: Unknown parameter property: label
05/07/19 04:38:04.505 Warning: Unknown parameter property: label
05/07/19 04:38:04.516 Warning: Unknown parameter property: label
05/07/19 04:38:04.517 Warning: Unknown parameter property: label
05/07/19 04:38:04.531 Warning: Unknown parameter property: label
05/07/19 04:38:04.532 Warning: Unknown parameter property: label
05/07/19 04:38:04.556 Warning: Unknown parameter property: label
05/07/19 04:38:04.557 Warning: Unknown parameter property: label
05/07/19 04:38:04.567 Warning: Unknown parameter property: label
05/07/19 04:38:04.587 Warning: Unknown parameter property: label
05/07/19 04:38:04.588 Warning: Unknown parameter property: label
05/07/19 04:38:04.599 Warning: Unknown parameter property: label
05/07/19 04:38:04.600 Warning: Unknown parameter property: label
05/07/19 04:38:04.605 Warning: Unknown parameter property: label
05/07/19 04:38:04.606 Warning: Unknown parameter property: label
05/07/19 04:38:04.631 Warning: Unknown parameter property: label
05/07/19 04:38:04.632 Warning: Unknown parameter property: label
05/07/19 04:38:04.650 Warning: Unknown parameter property: label
05/07/19 04:38:04.668 Loading device 8
05/07/19 04:38:04.743 Loading XML RPC devices...
05/07/19 04:38:04.745 Loading device 9
05/07/19 04:38:04.860 Loading XML RPC devices...
05/07/19 04:38:06.883 Loading device 10
05/07/19 04:38:07.732 Loading XML RPC devices...
05/07/19 04:38:09.408 Loading device 11
05/07/19 04:38:11.036 Loading XML RPC devices...
05/07/19 04:38:15.709 Loading device 12
05/07/19 04:38:18.154 Loading XML RPC devices...
05/07/19 04:38:19.333 Loading device 13
05/07/19 04:38:22.105 Info: Not initializing device family CCU, because it is disabled in it's configuration file.
05/07/19 04:38:22.526 Info: Disposing family module mod_ccu.so
05/07/19 04:38:23.029 Loading XML RPC devices...
05/07/19 04:38:29.615 Loading device 14
05/07/19 04:38:31.808 Initializing RPC client...
05/07/19 04:38:33.039 Starting MQTT client...
05/07/19 04:38:36.537 Starting XML RPC server FamilyRPCServer listening on :::2000...
05/07/19 04:38:43.413 MQTT Client: Info: Successfully connected to MQTT server using protocol version 4.
05/07/19 04:38:43.600 Info: Subscribing to topic homegear/climate/rpc/#
05/07/19 04:38:43.705 Signal 11 received.
05/07/19 04:38:57.587 Info: Process with id 3438 ended.
05/07/19 04:38:57.776 Warning: Pipe to child process closed.
05/07/19 04:38:57.791 Error: Core was dumped.
05/07/19 04:38:57.792 Homegear was terminated. Restarting (1)...
05/07/19 04:39:08.895 Homegear was terminated. Restarting (2)...
05/07/19 04:39:09.473 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
05/07/19 04:39:09.474 Info: Core file size now is "4294967295".
05/07/19 04:39:09.474 Info: Setting maximum thread priority to "0" for user with id 0 and group with id 0.
05/07/19 04:39:09.474 Info: Maximum thread priority now is "0".
05/07/19 04:39:09.873 Info: Backing up database...
05/07/19 04:39:10.153 Initializing database...
05/07/19 04:39:10.294 Info: Loading family module (type 1) mod_sonos.so
05/07/19 04:39:10.803 Info: Loading settings from /etc/homegear/families/sonos.conf
05/07/19 04:39:10.991 Info: Loading family module (type 1) mod_beckhoff.so
05/07/19 04:39:11.017 Info: Loading settings from /etc/homegear/families/beckhoff.conf
05/07/19 04:39:11.033 Module Beckhoff: Error in file Interfaces.cpp line 45 in function virtual void MyFamily::Interfaces::create(): The provided hostname is empty.
05/07/19 04:39:11.035 Info: Loading family module (type 1) mod_homematicwired.so
05/07/19 04:39:11.081 Info: Loading settings from /etc/homegear/families/homematicwired.conf
05/07/19 04:39:11.089 Info: Loading family module (type 1) mod_homematicbidcos.so
05/07/19 04:39:11.160 Info: Loading settings from /etc/homegear/families/homematicbidcos.conf
05/07/19 04:39:11.215 Info: Loading family module (type 1) mod_philipshue.so
05/07/19 04:39:11.281 Info: Loading settings from /etc/homegear/families/philipshue.conf
05/07/19 04:39:11.308 Info: Loading family module (type 1) mod_ipcam.so
05/07/19 04:39:11.378 Info: Loading settings from /etc/homegear/families/ipcam.conf
05/07/19 04:39:11.450 Info: Loading family module (type 1) mod_max.so
05/07/19 04:39:11.513 Info: Loading settings from /etc/homegear/families/max.conf
05/07/19 04:39:11.527 Info: Loading family module (type 1) mod_enocean.so
05/07/19 04:39:11.612 Info: Loading settings from /etc/homegear/families/enocean.conf
05/07/19 04:39:11.625 Info: Loading family module (type 1) mod_knx.so
05/07/19 04:39:11.734 Info: Loading settings from /etc/homegear/families/knx.conf
05/07/19 04:39:11.741 Info: Loading family module (type 1) mod_intertechno.so
05/07/19 04:39:11.787 Info: Loading settings from /etc/homegear/families/intertechno.conf
05/07/19 04:39:11.842 Info: Loading family module (type 1) mod_insteon.so
05/07/19 04:39:11.894 Info: Loading settings from /etc/homegear/families/insteon.conf
05/07/19 04:39:11.912 Info: Loading family module (type 1) mod_miscellaneous.so
05/07/19 04:39:12.044 Info: Loading settings from /etc/homegear/families/miscellaneous.conf
05/07/19 04:39:12.048 Info: Loading family module (type 1) mod_ccu.so
05/07/19 04:39:12.175 Info: Loading settings from /etc/homegear/families/ccu.conf
05/07/19 04:39:12.182 Info: Loading family module (type 1) mod_kodi.so
05/07/19 04:39:12.252 Info: Loading settings from /etc/homegear/families/kodi.conf
05/07/19 04:39:12.256 Info: Loading family module (type 1) mod_zwave.so
05/07/19 04:39:12.703 Info: Loading settings from /etc/homegear/families/z-wave.conf
05/07/19 04:39:13.247 Info: Loading family module (type 1) mod_mbus.so
05/07/19 04:39:13.302 Info: Loading settings from /etc/homegear/families/m-bus.conf
05/07/19 04:39:13.361 Info: Setting up physical interfaces and GPIOs...
05/07/19 04:39:13.503 Info: Dropping privileges to user homegear (1000) and group homegear (1000)
05/07/19 04:39:13.693 Info: Homegear is (now) running as user with id 1000 and group with id 1000.
05/07/19 04:39:14.017 Starting script engine server...
05/07/19 04:39:14.135 Initializing licensing controller...
05/07/19 04:39:14.135 Loading licensing controller data...
05/07/19 04:39:14.135 Loading devices...
05/07/19 04:39:14.136 Loading XML RPC devices...
05/07/19 04:39:22.541 Loading device 1
05/07/19 04:39:25.541 Module HomeMatic BidCoS: Info: Central address set to 0xFDD019.
05/07/19 04:39:29.624 Loading XML RPC devices...
05/07/19 05:08:59.490 Loading device 2
05/07/19 05:09:52.625 Loading XML RPC devices...
05/07/19 05:17:48.978 Loading device 3
05/07/19 05:18:27.667 Loading XML RPC devices...
05/07/19 07:14:40.368 Starting Homegear...
05/07/19 07:14:40.372 Homegear version 0.7.37-2722
05/07/19 07:14:40.372 Git commit SHA of libhomegear-base: -
05/07/19 07:14:40.372 Git branch of libhomegear-base: -
05/07/19 07:14:40.373 Git commit SHA of Homegear: -
05/07/19 07:14:40.373 Git branch of Homegear: -
05/07/19 07:14:40.373 Starting Homegear...
05/07/19 07:14:40.374 Homegear version 0.7.37-2722
05/07/19 07:14:40.374 Git commit SHA of libhomegear-base: -
05/07/19 07:14:40.374 Git branch of libhomegear-base: -
05/07/19 07:14:40.375 Git commit SHA of Homegear: -
05/07/19 07:14:40.375 Git branch of Homegear: -
05/07/19 07:14:40.377 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
05/07/19 07:14:40.378 Info: Core file size now is "4294967295".
05/07/19 07:14:40.378 Info: Setting maximum thread priority to "0" for user with id 0 and group with id 0.
05/07/19 07:14:40.378 Info: Maximum thread priority now is "0".
05/07/19 07:14:40.495 Info: Backing up database...
05/07/19 07:14:40.892 Initializing database...
any idea? I’m using the 0.7.37-2722 version in docker on a RPi
