ich habe wie so manch anderer auch diesen Fehler und komme nicht weiter.
Ich benutze openhabian 3.2.0 mit einem HM-MOD-RPI-PCB und Homegear version 0.9.22062305-3560 und kann auch meine Türsensoren pairen und lesen. Allerdings habe ich noch einen Fensteröffner, dem ich Befehle schicken möchte und kriege immer diesen Fehler.
Aus dem homegear.log sehe ich dann das:
06/24/22 22:45:53.357 Module HomeMatic BidCoS: Debug: LEVEL of peer 6 with serial number REQ1054675:1 was set to 00.
06/24/22 22:45:55.911 RPC Server (Port 2001): Response:
(Struct length=3)
[faultCode] (Integer) -100
[faultString] (String) No answer from device.
[retry] (Boolean) 0
06/24/22 22:45:55.912 RPC Server (Port 2001): Response binary:
42696EFF000000580000010100000003000000096661756C74436F646500000001FFFFFF9C0000000B6661756C74537472696E6700000003000000164E6F20616E737765722066726F6D206465766963652E0000000572657472790000000200
06/24/22 22:45:56.400 Module HomeMatic BidCoS: Debug: Deleting queue 12 for BidCoS peer with address 0x562BA2
06/24/22 22:45:56.400 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
06/24/22 22:45:56.400 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 6). Retrying...
06/24/22 22:45:56.500 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 1047B001FD0001562BA202040000000001
06/24/22 22:45:56.501 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD001601240200000147B001FC7D0001562BA2020400000000017D48
06/24/22 22:45:59.510 Module HomeMatic BidCoS: Debug: Deleting queue 13 for BidCoS peer with address 0x562BA2
06/24/22 22:45:59.861 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0004012404040F
06/24/22 22:45:59.862 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: F0
06/24/22 22:45:59.862 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0004012404040FF0
06/24/22 22:45:59.862 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: No answer to packet 1047B001FD0001562BA202040000000001
06/24/22 22:45:59.862 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
06/24/22 22:45:59.862 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 6). Retrying...
06/24/22 22:45:59.862 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Sending (My-HM-MOD-RPI-PCB): 1047B001FD0001562BA202040000000001
06/24/22 22:45:59.862 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD001601250200000147B001FC7D0001562BA202040000000001845B
06/24/22 22:46:00.543 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000 06/24/22 22:46:00.544 RPC Server (Port 2001): Info: Client number 36 is calling RPC method: listBidcosInterfaces (2) Parameters:
06/24/22 22:46:00.544 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS] (String) VBC0526529
[CONNECTED] (Boolean) 1
[DEFAULT] (Boolean) 1
[DESCRIPTION] (String) Homegear default BidCoS interface
06/24/22 22:46:00.544 RPC Server (Port 2001): Response binary:
42696E0100000087000001000000000100000101000000040000000741444452455353000000030000000A5642433035323635323900000009434F4E4E454354454400000002010000000744454641554C5400000002010000000B4445534352495054494F4E0000000300000021486F6D65676561722064656661756C7420426964436F5320696E74657266616365
Da muss ich mal nachfragen. Fensteröffer = WinMatic?
Oder Drehgriffkontakt Hm-Sec-RHS? Da hagelte es in einem anderen Objekt in Verbindung mit einer CCU zwischenzeitllich so viele Fehlermeldungen, das andere Aktoren auch beleidigt waren. Diverse Batterien getauscht. Jetzt gehts grade. Hier mit Homegear läuft nur ein Sensor welcher nur einmal Zicken gemacht hat. Batterietausch (obwohl noch keine LowBat Meldung) und Fenster auf und zu. Dann gings.
Trotzdem wohl eines der schwierigsten Geräte in Bezug auf Fehlersuche.
Antenne, Batterie, Chip und Firmware welche sich nicht upgraden lässt… alles wurde beim RHS schon im HomematicForum verdächtigt.
Der AskSinAnalyzer von Jerome hilft da ggf. weiter den Störenfried zu finden. Die USB Version mit AskSinAnalyzerXS läuft mit nem CC1101 und nem Arduino ProMini 3.3V. An PC oder Laptop. Bei 5 Volt ProMini oder Nano Systemen mit Pegelwandler verwenden da manche Pins 5V weitergeben.
Ansonsten Batterien raus und rein, ablernen, anlernen, Batterien tauschen und beim Fluchen Fenster geschlossen halten. Und manchmal geht es plötzlich
ja, der Fensteröffner bei mir ist der WinMatic. In meinem Haushalt ist das der einzige Aktor von Homematic, ab und angelernt hab ich auch schon zig Male… Firmware vom HM-MOD-RPI-PCB gerade auch geflasht, glaub auf die 1.4.1v… Ich weiß echt nicht mehr weiter, warum der einfach nicht antwortet…
Edit:
ich kann über Homegear den Wert für Relock_Delay setzen, da meckert der nicht und es wird angenommen. Allerdings nimmt der dafür alle anderen Werte nicht, Level zb nicht und akzeptiert kein STOP, da sagt der immer, dass es keine Antwort gibt
Also WinMatic… Scheitert es beim Anlernen oder im Betrieb? Fehler/Binkcodes am Gerät? Gebraucht gekauft? Falls er woanders nicht korrekt abgelernt wurde und der Schlüssel nicht bekannt ist, macht AES Probleme. Das ist dann ein Fall für den ResetService von ELV/eq3. 30 Eur glaub ich. Auf jeden Fall erst nachfragen wenn Du das Gerät nicht selbst dort gekauft hast.
Ansonsten zum Test für 30 Eur ne gebrauchte CCU2 bei Kleinanzeigen. Die kann man später ggf. noch für HmIP nutzen.
Scheitert im Betrieb, ich kann das Level nicht setzen, aber den Relock Delay schon.
Keine Fehler/Blinkcodes. Neu gekauft, allerdings hatte ich das bei nem Freund zuerst angelernt und wurde nicht abgelernt, sondern nur resettet und bei mir angelernt.
Was mich wundert ist halt, dass ich den Relock Delay setzen kann, alles andere aber nicht…
Edit: Speed kann ich auch einstellen, aber das bringt mir alles nichts, wenn ich es nicht in Bewegung bringen kann
Dann würde ich ihn an der vorherigen Zentrale nochmal anlernen. Korrekt ablernen und auf Werkseinstellungen zurücksetzen.
Edit:
Könnte es evtl. auch Timingprobleme mit dem HM-MOD-RPI-PCB geben? Die Ansteuerung ist nicht so fix wie beim CC1101 über SPI. Bei wenigen Geräten im Standard Modus fällt das nicht so schnell auf. Werden es mehr oder kommt AES dazu erhöht sich die Datenmenge enorm. Daher ist u.a. das HM-MOD-RPI-PCB auch nicht das Funkmodul der ersten Wahl. Wer nicht selbst mit dem CC1101 basteln will, findet evtl. bei @pmayer noch ein hübsches Teil. https://forum.homegear.eu/t/cc1101-rpi-spi-adapter/1381
Dennoch erscheint es mir Sinnvoll auch die jetzt bekannte Stolperfalle des nicht korrekt abgelernten Gerätes zu beseitigen.
So, hat bei mir jetzt alles geklappt, danke @Tobias für den Tip mit dem Ablernen . Das war tatsächlich der Fehler, am alten Pi wurde der ohne anlernen erkannt und hat Befehle entgegengenommen. Jetzt klappt alles wie es soll. Ich dachte mit einem Reset würde der tatsächlich auf Werkseinstellungen gesetzt werden…
