ich bin neu und habe keine Erfahrung
Ich habe wie in der Anleitung :
doc.homegear.eu/data/homegear-h … idcos-conf
dieses Modul nach Qnerds Schaltplan verdrahtet
und meine homematicbidcos.conf:
# rfKey = 00112233445566778899AABBCCDDEEFF
rfKey = xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
## incremented by 1
currentRfKeyIndex = 1
## old and the new one.
## risk.
[TI CC1101 Module]
id = My-CC1101
## to new peers.
deviceType = cc1100
device = /dev/spidev0.0
responseDelay = 100
interruptPin = 2
gpio1 = 23
system als auch homegear startet aber das Modul kann nicht angesprochen werden:
im homegear.err steht:
Module HomeMatic BidCoS: TI CC110X “Domi-CC1101”: Error (check) writing to register 0.
Critical: At least one of the physical devices could not be opened… Exiting…
Module HomeMatic BidCoS: TI CC110X “Domi-CC1101”: Connection to TI CC1101 closed unexpectedly… Trying to reconnect…
Error in file RPC/RpcClient.cpp line 520 in function void Rpc::RpcClient::sendRequest(Rpc::RemoteRpcServer*, std::vector&, std::vector&, bool, bool&): Could not get address inf$
Removing server. Server has to send “init” again.
