Hat nicht unmittelbar etwas mit der Ursprungsfrage zu tun, aber diese Sachen stören mich und vielleicht kann hier jemand helfen, diese Fehlermeldungen abzustellen:
06/21/20 12:24:00.883 Warning: Unknown cast: decimalIntegerInverseScale
06/21/20 12:24:01.170 Warning: variables with id “custom_ch7_values” does not exist.
06/21/20 12:24:01.170 Warning: configParameters with id “config” does not exist.
06/21/20 12:24:01.173 Warning: variables with id “custom_ch7_values” does not exist.
06/21/20 12:24:02.486 Module Zigbee: Zigbee serial module “Serial1”: Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
06/21/20 12:24:14.226 Module Zigbee: Zigbee serial module “Serial1”: Error: No response received to packet: FE012F060028
06/21/20 12:24:44.891 Warning: Setting not found: maxWaitForPhysicalInterfaces
06/20/20 16:41:02.122 Script Engine Server: Error: Could not check license. Licensing module with id 0x7000 not found
That’s true. I had to go back to an older nightly because MQTT was not working (confirmed by Sathya). I think I should install the latest nightly now because still I fail in adding IKEA lamps.
Yes, also with actual nightly they are still visible (always two times):
06/22/20 13:39:02.580 Module Zigbee: Zigbee serial module “Serial1”: Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
06/22/20 13:39:02.581 Module Zigbee: Zigbee serial module “Serial1”: Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
06/22/20 13:39:14.313 Module Zigbee: Zigbee serial module “Serial1”: Error: No response received to packet: FE012F060028
06/22/20 13:39:44.024 Setting replaceClientServerAddress is deprecated and will be removed by end of 2020.
That sent packet is trying to set Trust Center link key exchange to ‘false’. This might explain why you cannot add that light device, without this setting ‘legacy’ devices cannot join the network. Only Zigbee 3.x can.
I’ll try to increase timeouts but I don’t expect to make a difference.
Back to work after months… Already reflashed my CC2531-stick with 3.0-firmware. My XIAOMI-devices are paired and work stable. But still I cannot pair my IKEA-devices.
Err-file:
09/03/20 17:22:47.766 Module Zigbee: Zigbee serial module “Serial1”: Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
09/03/20 17:22:49.070 Module Zigbee: Zigbee serial module “Serial1”: Warning: Unknown start byte received: 64
09/03/20 17:22:49.070 Module Zigbee: Zigbee serial module “Serial1”: Warning: Unknown start byte received: 10
09/03/20 17:22:49.071 Module Zigbee: Zigbee serial module “Serial1”: Warning: Unknown start byte received: 0
Log-file:
09/03/20 17:38:50.143 Script Engine Server: Error: Could not check license. Licensing module with id 0x7000 not found
09/03/20 17:38:50.488 Info: Script with id 58 finished with exit code 0
09/03/20 17:38:53.905 Info: Script with id 59 finished with exit code 0
09/03/20 17:38:58.266 Info: Script with id 60 finished with exit code 0
I am using Homegear 0.8.0-3031, is there a need to update?
