ZigBee: Errormessages in Log
Please ensure the proper device is set in the zigbee configuration.
For example, on raspberry it might be:
device=/dev/ttyACM0
sure, I’ve done this. I have no problem with my Xiaomi-devices.
This was misleading, I thought that in your case the module couldn’t initialize the serial.
Can you check the log for the part when a pairing is issued?
which log-level is needed?
The higher, the better, since it contains more info.
Also, could you specify what IKEA devices are those? Do they support zigbee 3.0? If not, is the version that is supported available?
Hi Adrian,
changed Debug-level to 5, but it is still the same.
9/07/20 19:11:31.170 Module Zigbee: Zigbee serial module “Serial1”: Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
09/07/20 19:11:40.720 Module Zigbee: Zigbee serial module “Serial1”: Error: No response received to packet: FE00210120
I flashed to ZIGBEE3.0 because before I had the same prob with my IKEA GU10-bulb LED1737R5 and also L1528 LED-panel. Both devices are factory resetted.
I had no probs with that devices using ZIGBEE2MQTT. Is there a major difference using IKEA-products?
That’s a portion of the initialization part. Doesn’t help much.
I assume the serial is initialized eventually, as you mentioned that xiaomi devices work.
