I just finished security (S0 for now). The module works with both usb sticks (including the bridge ones, which I’m told open zwave and fhem cannot use) and with a zip gateway.
I’m quite sure there are some bugs to iron out and there are features to be added, too. For example multi channel is not implemented, we’ll need a testing device for having that working.
Since last time I mentioned multi-channel devices, I’ll start with telling that multi-channel devices now work.
I also ironed out some issues and tested the module, but there might be some more.
But until now, I could change configuration parameters, set and reset associations (including multi-channel associations), receive notifications and so on.
Later edit: If you are interested in some details, just ask, I’ll try to reply.
That depends on feedback on the beta. Right now I’m focused on testing the code than on changing it. The binary module available I think still has some issues, but the one I’m using right now seems very stable and I stressed it quite a bit. Of course, I might miss some things, that’s why it would be nice if people would be using it before the stable version and have feedback about it.
