Ich muss da noch was ergänzen:
Nachdem der HM-ES-PMSw1-Pl jetzt über das ganze Osterwochenende am Strom hing und auch “AN” war hat er tatsächlich den sich ändernden “STATE” gesendet bzw. ein entsprechender Eintrag ist im Log aufgetaucht:
03/29/16 13:38:25.742 Module HomeMatic BidCoS: Info: CURRENT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0006.
03/29/16 13:38:25.743 Module HomeMatic BidCoS: Info: ENERGY_COUNTER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000146.
03/29/16 13:38:25.743 Module HomeMatic BidCoS: Info: FREQUENCY on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x01.
03/29/16 13:38:25.743 Module HomeMatic BidCoS: Info: POWER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000014.
03/29/16 13:38:25.743 Module HomeMatic BidCoS: Info: VOLTAGE on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0914.
03/29/16 13:38:25.743 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:38:25.743 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:39:16.482 Module HomeMatic BidCoS: Info: BOOT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x01.
03/29/16 13:39:16.483 Module HomeMatic BidCoS: Info: CURRENT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00C9.
03/29/16 13:39:16.483 Module HomeMatic BidCoS: Info: ENERGY_COUNTER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000146.
03/29/16 13:39:16.483 Module HomeMatic BidCoS: Info: FREQUENCY on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0xFF.
03/29/16 13:39:16.483 Module HomeMatic BidCoS: Info: POWER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0000B9.
03/29/16 13:39:16.483 Module HomeMatic BidCoS: Info: VOLTAGE on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0910.
03/29/16 13:39:18.615 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0xC8.
03/29/16 13:39:18.616 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:39:24.363 Module HomeMatic BidCoS: Info: BOOT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x01.
03/29/16 13:39:24.363 Module HomeMatic BidCoS: Info: CURRENT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0000.
03/29/16 13:39:24.363 Module HomeMatic BidCoS: Info: ENERGY_COUNTER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000146.
03/29/16 13:39:24.363 Module HomeMatic BidCoS: Info: FREQUENCY on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0xFE.
03/29/16 13:39:24.363 Module HomeMatic BidCoS: Info: POWER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000000.
03/29/16 13:39:24.363 Module HomeMatic BidCoS: Info: VOLTAGE on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0917.
03/29/16 13:39:24.615 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:39:24.615 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:39:34.483 Module HomeMatic BidCoS: Info: BOOT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x01.
03/29/16 13:39:34.483 Module HomeMatic BidCoS: Info: CURRENT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0068.
03/29/16 13:39:34.483 Module HomeMatic BidCoS: Info: ENERGY_COUNTER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000146.
03/29/16 13:39:34.483 Module HomeMatic BidCoS: Info: FREQUENCY on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0xFF.
03/29/16 13:39:34.483 Module HomeMatic BidCoS: Info: POWER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000086.
03/29/16 13:39:34.483 Module HomeMatic BidCoS: Info: VOLTAGE on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0912.
03/29/16 13:39:36.715 Module HomeMatic BidCoS: Info: STATE on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0xC8.
03/29/16 13:39:36.715 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
aber er hat sich immer noch nicht über OpenHAB schalten lassen
nachdem ich das Gerät aus der Steckdose herausgezogen habe um es zur Steckdose auf dem Schreibtisch “Umzuziehen” und dort wieder eingesteckt habe kommt nun keine Aktualisierung mehr vom “STATE”. Beim Betätigen des Tasters auf dem Aktor kommt nun nur noch “WORKING […] was set to 0x00.” und hin und wieder die Aktualisierung der Werte “CURRENT”, “ENERGY_COUNTER”, “FREQUENCY”, “POWER” und “VOLTAGE”
03/29/16 13:59:04.718 Module HomeMatic BidCoS: Info: CURRENT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0000.
03/29/16 13:59:04.718 Module HomeMatic BidCoS: Info: ENERGY_COUNTER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000000.
03/29/16 13:59:04.718 Module HomeMatic BidCoS: Info: FREQUENCY on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x02.
03/29/16 13:59:04.718 Module HomeMatic BidCoS: Info: POWER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000000.
03/29/16 13:59:04.718 Module HomeMatic BidCoS: Info: VOLTAGE on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x091B.
03/29/16 13:59:11.880 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:59:14.380 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:59:17.180 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 13:59:19.880 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 14:00:29.481 Module HomeMatic BidCoS: Info: WORKING on channel 1 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x00.
03/29/16 14:01:30.218 Module HomeMatic BidCoS: Info: CURRENT on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x0000.
03/29/16 14:01:30.218 Module HomeMatic BidCoS: Info: ENERGY_COUNTER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000000.
03/29/16 14:01:30.218 Module HomeMatic BidCoS: Info: FREQUENCY on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0xFF.
03/29/16 14:01:30.218 Module HomeMatic BidCoS: Info: POWER on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x000000.
03/29/16 14:01:30.218 Module HomeMatic BidCoS: Info: VOLTAGE on channel 2 of HomeMatic BidCoS peer 52 with serial number LEQ0930239 was set to 0x091A.
auch wenn ich über ein PHP-Script mit
versuche den Aktor an oder aus zu schalten kommt nur
Array
[faultCode] => -100
[faultString] => No answer from device.
Und das obwohl das Device direkt neben dem LAN-GW (DEHDLGW0001) liegt und einen sehr guten Empfang hat:
Array
[ID] => 52
[INTERFACE] => DEHDLGW001
[NAME] => DEHDSP1001
[RSSI] => -49
