- /* Copyright 2013-2019 Homegear GmbH
- * Homegear is free software: you can redistribute it and/or modify
- * it under the terms of the GNU General Public License as published by
- * the Free Software Foundation, either version 3 of the License, or
- * (at your option) any later version.
- * Homegear is distributed in the hope that it will be useful,
- * but WITHOUT ANY WARRANTY; without even the implied warranty of
- * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
- * GNU General Public License for more details.
- * You should have received a copy of the GNU General Public License
- * along with Homegear. If not, see <http://www.gnu.org/licenses/>.
- * In addition, as a special exception, the copyright holders give
- * permission to link the code of portions of this program with the
- * OpenSSL library under certain conditions as described in each
- * individual source file, and distribute linked combinations
- * including the two.
- * You must obey the GNU General Public License in all respects
- * for all of the code used other than OpenSSL. If you modify
- * file(s) with this exception, you may extend this exception to your
- * version of the file(s), but you are not obligated to do so. If you
- * do not wish to do so, delete this exception statement from your
- * version. If you delete this exception statement from all source
- * files in the program, then also delete it here.
- #include "HmCcTc.h"
- #include <homegear-base/BaseLib.h>
- #include "../GD.h"
- namespace BidCoS
- HmCcTc::HmCcTc(uint32_t parentID, IPeerEventSink* eventHandler) : BidCoSPeer(parentID, eventHandler)
- init();
- startDutyCycle(-1); //Peer is newly created
- HmCcTc::HmCcTc(int32_t id, int32_t address, std::string serialNumber, uint32_t parentID, IPeerEventSink* eventHandler) : BidCoSPeer(id, address, serialNumber, parentID, eventHandler)
- init();
- HmCcTc::~HmCcTc()
- dispose();
- void HmCcTc::init()
- try
- _stopDutyCycleThread = false;
- catch(const std::exception& ex)
- GD::out.printEx(__FILE__, __LINE__, __PRETTY_FUNCTION__, ex.what());
- void HmCcTc::dispose()
- try
- _stopDutyCycleThread = true;
- _bl->threadManager.join(_dutyCycleThread);
- _bl->threadManager.join(_sendDutyCyclePacketThread);
- BidCoSPeer::dispose();
- void HmCcTc::worker()
- bool HmCcTc::load(BaseLib::Systems::ICentral* device)
- try
- BidCoSPeer::load(device);
- serviceMessages->endUnreach();
- if(!_rpcDevice)
- GD::out.printError("Error: Could not find RPC device for peer with ID " + std::to_string(_peerID));
- return true;
- _rpcDevice->receiveModes = BaseLib::DeviceDescription::HomegearDevice::ReceiveModes::Enum::always;
- _rpcDevice->timeout = 0;
- return true;
- return false;
- void HmCcTc::loadVariables(BaseLib::Systems::ICentral* device, std::shared_ptr<BaseLib::Database::DataTable>& rows)
- try
- BidCoSPeer::loadVariables(device, rows);
- for(BaseLib::Database::DataTable::iterator row = rows->begin(); row != rows->end(); ++row)
- _variableDatabaseIDs[row->second.at(2)->intValue] = row->second.at(0)->intValue;
- switch(row->second.at(2)->intValue)
- case 1000:
- _currentDutyCycleDeviceAddress = row->second.at(3)->intValue;
- break;
- case 1004:
- _valveState = row->second.at(3)->intValue;
- break;
- case 1005:
- _newValveState = row->second.at(3)->intValue;
- break;
- case 1006:
- _lastDutyCycleEvent = row->second.at(3)->intValue;
- break;
- case 1007:
- _dutyCycleMessageCounter = (uint8_t)row->second.at(3)->intValue;
- break;
- setDeviceType((uint32_t)DeviceType::HMCCTC);
- startDutyCycle(calculateLastDutyCycleEvent());
- void HmCcTc::saveVariables()
- try
- BidCoSPeer::saveVariables();
- saveVariable(1000, _currentDutyCycleDeviceAddress);
- saveVariable(1004, _valveState);
- saveVariable(1005, _newValveState);
- saveVariable(1006, _lastDutyCycleEvent);
- saveVariable(1007, (int64_t)_dutyCycleMessageCounter);
- int32_t HmCcTc::calculateCycleLength(uint8_t messageCounter)
- int32_t result = (((_address << 8) | messageCounter) * 1103515245 + 12345) >> 16;
- return (result & 0xFF) + 480;
- int64_t HmCcTc::calculateLastDutyCycleEvent()
- try
- if(_lastDutyCycleEvent < 0) _lastDutyCycleEvent = 0;
- int64_t now = std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::system_clock::now().time_since_epoch()).count();
- if(now - _lastDutyCycleEvent > 1800000000) return -1; //Duty cycle is out of sync anyway so don't bother to calculate
- int64_t nextDutyCycleEvent = _lastDutyCycleEvent;
- int64_t lastDutyCycleEvent = _lastDutyCycleEvent;
- _dutyCycleMessageCounter--; //The saved message counter is the current one, but the calculation has to use the last one
- while(nextDutyCycleEvent < now + 25000000)
- lastDutyCycleEvent = nextDutyCycleEvent;
- nextDutyCycleEvent = lastDutyCycleEvent + (calculateCycleLength(_dutyCycleMessageCounter) * 250000) + _dutyCycleTimeOffset;
- _dutyCycleMessageCounter++;
- GD::out.printDebug("Debug: Setting last duty cycle event to: " + std::to_string(lastDutyCycleEvent));
- return lastDutyCycleEvent;
- return 0;
- void HmCcTc::setValveState(int32_t valveState)
- try
- valveState *= 256;
- //Round up if necessary. I don't use double for calculation, because hopefully this is faster.
- if(valveState % 100 >= 50) valveState = (valveState / 100) + 1; else valveState /= 100;
- _newValveState = valveState;
- if(_newValveState > 255) _newValveState = 255;
- if(_newValveState < 0) _newValveState = 0;
- void HmCcTc::startDutyCycle(int64_t lastDutyCycleEvent)
- try
- if(_dutyCycleThread.joinable())
- GD::out.printCritical("HomeMatic BidCoS peer " + std::to_string(_peerID) + ": Duty cycle thread already started. Something went very wrong.");
- return;
- _bl->threadManager.start(_dutyCycleThread, true, 35, SCHED_FIFO, &HmCcTc::dutyCycleThread, this, lastDutyCycleEvent);
- void HmCcTc::dutyCycleThread(int64_t lastDutyCycleEvent)
- try
- int64_t nextDutyCycleEvent = (lastDutyCycleEvent < 0) ? std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::system_clock::now().time_since_epoch()).count() : lastDutyCycleEvent;
- _lastDutyCycleEvent = nextDutyCycleEvent;
- int64_t timePoint;
- int64_t cycleTime;
- uint32_t cycleLength = calculateCycleLength(_dutyCycleMessageCounter - 1); //The calculation has to use the last message counter
- _dutyCycleCounter = (std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::system_clock::now().time_since_epoch()).count() - _lastDutyCycleEvent) / 250000;
- if(_dutyCycleCounter < 0) _dutyCycleCounter = 0;
- if(_dutyCycleCounter > 0) GD::out.printInfo("Info: Skipping " + std::to_string(_dutyCycleCounter * 250) + " ms of duty cycle.");
- //_dutyCycleCounter = (_dutyCycleCounter % 8 > 3) ? _dutyCycleCounter + (8 - (_dutyCycleCounter % 8)) : _dutyCycleCounter - (_dutyCycleCounter % 8);
- while(!_stopDutyCycleThread)
- try
- cycleTime = (int64_t)cycleLength * 250000;
- nextDutyCycleEvent += cycleTime + _dutyCycleTimeOffset; //Add offset every cycle. This is very important! Without it, 20% of the packets are sent too early.
- GD::out.printInfo("Info: Next duty cycle: " + std::to_string(nextDutyCycleEvent / 1000) + " (in " + std::to_string(cycleTime / 1000) + " ms) with message counter 0x" + BaseLib::HelperFunctions::getHexString(_dutyCycleMessageCounter));
- std::chrono::milliseconds sleepingTime(250);
- while(!_stopDutyCycleThread && _dutyCycleCounter < (signed)cycleLength - 80)
- std::this_thread::sleep_for(sleepingTime);
- _dutyCycleCounter += 1;
- if(_stopDutyCycleThread) break;
- while(!_stopDutyCycleThread && _dutyCycleCounter < (signed)cycleLength - 40)
- setDecalcification();
- timePoint = std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count();
- GD::out.printInfo("Info: Correcting time mismatch of " + std::to_string((nextDutyCycleEvent - 10000000 - timePoint) / 1000) + "ms.");
- std::this_thread::sleep_for(std::chrono::microseconds(nextDutyCycleEvent - timePoint - 5000000));
- std::this_thread::sleep_for(std::chrono::microseconds(nextDutyCycleEvent - timePoint - 2000000));
- _bl->threadManager.start(_sendDutyCyclePacketThread, false, 44, SCHED_FIFO, &HmCcTc::sendDutyCyclePacket, this, _dutyCycleMessageCounter, nextDutyCycleEvent);
- cycleLength = calculateCycleLength(_dutyCycleMessageCounter);
- _dutyCycleCounter = 0;
- void HmCcTc::setDecalcification()
- try
- std::time_t time1 = std::time(nullptr);
- std::tm time2;
- localtime_r(&time1, &time2);
- if(time2.tm_wday == 6 && time2.tm_hour == 14 && time2.tm_min >= 0 && time2.tm_min <= 3)
- try
- for(std::unordered_map<int32_t, bool>::iterator i = _decalcification.begin(); i != _decalcification.end(); ++i)
- i->second = true;
- void HmCcTc::sendDutyCyclePacket(uint8_t messageCounter, int64_t sendingTime)
- try
- if(sendingTime < 0) sendingTime = 2000000;
- if(_stopDutyCycleThread) return;
- int32_t address = getNextDutyCycleDeviceAddress();
- GD::out.printDebug("Debug: HomeMatic BidCoS peer " + std::to_string(_peerID) + ": Next HM-CC-VD is 0x" + BaseLib::HelperFunctions::getHexString(address));
- if(address < 1)
- GD::out.printDebug("Debug: Not sending duty cycle packet, because no valve drives are paired to me.");
- return;
- std::vector<uint8_t> payload;
- payload.push_back(getAdjustmentCommand(address));
- payload.push_back(_newValveState);
- std::shared_ptr<BidCoSPacket> packet(new BidCoSPacket(messageCounter, 0xA2, 0x58, _address, address, payload));
- int64_t nanoseconds = (sendingTime - std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count() - 1000000) * 1000;
- int32_t seconds = nanoseconds / 1000000000;
- nanoseconds -= seconds * 1000000000;
- struct timespec timeToSleep;
- timeToSleep.tv_sec = seconds;
- timeToSleep.tv_nsec = nanoseconds;
- nanosleep(&timeToSleep, NULL);
- nanoseconds = (sendingTime - std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count() - 500000) * 1000;
- timeToSleep.tv_sec = 0;
- nanoseconds = (sendingTime - std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count() - 100000) * 1000;
- nanoseconds = (sendingTime - std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count() - 30000) * 1000;
- nanoseconds = (sendingTime - std::chrono::duration_cast<std::chrono::microseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count()) * 1000;
- int64_t timePoint = std::chrono::duration_cast<std::chrono::milliseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count();
- _physicalInterface->sendPacket(packet);
- _valveState = _newValveState;
- int64_t timePassed = std::chrono::duration_cast<std::chrono::milliseconds>(std::chrono::high_resolution_clock::now().time_since_epoch()).count() - timePoint;
- GD::out.printDebug("Debug: HomeMatic BidCoS peer " + std::to_string(_peerID) + ": Sending took " + std::to_string(timePassed) + "ms.");
- int32_t HmCcTc::getAdjustmentCommand(int32_t peerAddress)
- try
- if(_decalcification[peerAddress])
- _decalcification[peerAddress] = false;
- return 4;
- else if(_newValveState == 0) return 2; //OFF
- else if(_newValveState == 255) return 3; //ON
- else
- if(_newValveState != _valveState) return 3; else return 0;
- return 0;
- int32_t HmCcTc::getNextDutyCycleDeviceAddress()
- try
- std::lock_guard<std::mutex> peersGuard(_peersMutex);
- if(_peers.find(2) == _peers.end() || _peers.at(2).empty()) return -1;
- std::vector<std::shared_ptr<BaseLib::Systems::BasicPeer>>& channel2Peers = _peers.at(2);
- for(std::vector<std::shared_ptr<BaseLib::Systems::BasicPeer>>::iterator i = channel2Peers.begin(); i != channel2Peers.end(); ++i)
- if(_currentDutyCycleDeviceAddress == -1)
- _currentDutyCycleDeviceAddress = (*i)->address;
- break;
- else if((*i)->address == _currentDutyCycleDeviceAddress)
- i++;
- if(i == channel2Peers.end()) _currentDutyCycleDeviceAddress = channel2Peers.at(0)->address;
- else _currentDutyCycleDeviceAddress = (*i)->address;
- break;
- return _currentDutyCycleDeviceAddress;
- return -1;
This file has been truncated. show original
