08/14/19 16:57:19.272 RPC client: Response was:
(Array length=1)
(String) event
08/14/19 16:57:19.274 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
08/14/19 16:57:19.274 RPC Server (Port 2001): Info: Client number 16713 is calling RPC method: listBidcosInterfaces (2) Parameters:
08/14/19 16:57:19.275 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS] (String) VBC9911585
[CONNECTED] (Boolean) 1
[DEFAULT] (Boolean) 1
[DESCRIPTION] (String) Homegear default BidCoS interface
08/14/19 16:57:19.275 RPC Server (Port 2001): Response binary:
42696E0100000087000001000000000100000101000000040000000741444452455353000000030000000A5642433939313135383500000009434F4E4E454354454400000002010000000744454641554C5400000002010000000B4445534352495054494F4E0000000300000021486F6D65676561722064656661756C7420426964436F5320696E74657266616365
08/14/19 16:57:21.134 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: K
08/14/19 16:57:21.137 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN. Raw data:
48484D2D4C414E2D49462C303343342C4C4551303634313638362C3243443632312C3243443632312C39303846384543432C303032332C30330D0A
08/14/19 16:57:21.137 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: HHM-LAN-IF,03C4,LEQ0641686,2CD621,2CD621,908F8ECC,0023,03
08/14/19 16:57:23.175 RPC Server (Port 2001): Debug: Packet received: 42696E000000003D0000000873657456616C756500000003000000030000000C4C4551303539303730363A3100000003000000054C4556454C00000004351EB85200000000
08/14/19 16:57:23.175 RPC Server (Port 2001): Info: Client number 16713 is calling RPC method: setValue (2) Parameters:
(String) LEQ0590706:1
(String) LEVEL
(Float) 0.83
08/14/19 16:57:23.175 Module HomeMatic BidCoS: Debug: LEVEL of peer 11 with serial number LEQ0590706:1 was set to A6.
08/14/19 16:57:23.176 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 0ED7A0112CD6212B67200201A600A0
08/14/19 16:57:23.176 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: S90A22CE8,00,00000000,01,FFFFFFFF908F96C3,D7A0112CD6212B67200201A600A0
08/14/19 16:57:23.196 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN. Raw data:
5239304132324345382C303030322C30303030303030302C46462C374646462C36430D0A
08/14/19 16:57:23.196 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: R90A22CE8,0002,00000000,FF,7FFF,6C
08/14/19 16:57:23.196 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Ignoring too small packet: 6C
08/14/19 16:57:25.747 RPC Server (Port 2001): Response:
(Struct length=2)
[faultCode] (Integer) -100
[faultString] (String) No answer from device.
08/14/19 16:57:25.747 RPC Server (Port 2001): Response binary:
42696EFF0000004A0000010100000002000000096661756C74436F646500000001FFFFFF9C0000000B6661756C74537472696E6700000003000000164E6F20616E737765722066726F6D206465766963652E
08/14/19 16:57:25.754 RPC Server (Port 2001): Debug: Connection to client number 16713 closed (3).
08/14/19 16:57:25.756 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.2.68:47620 accepted. Client number: 16738
08/14/19 16:57:25.756 RPC Server (Port 2001): Info: RPC server client id for client number 16738 is: 100
08/14/19 16:57:25.757 RPC Server (Port 2001): Listening for incoming packets from client number 16738.
08/14/19 16:57:25.758 RPC Server (Port 2001): Debug: Packet received: 42696E000000003D0000000873657456616C756500000003000000030000000C4C4551303539303730363A3100000003000000054C4556454C00000004351EB85200000000
08/14/19 16:57:25.758 RPC Server (Port 2001): Info: Client number 16738 is calling RPC method: setValue (2) Parameters:
(String) LEVEL
(Float) 0.83
08/14/19 16:57:25.758 Module HomeMatic BidCoS: Debug: LEVEL of peer 11 with serial number LEQ0590706:1 was set to A6.
08/14/19 16:57:28.328 RPC Server (Port 2001): Response:
(Struct length=2)
08/14/19 16:57:28.328 RPC Server (Port 2001): Response binary:
08/14/19 16:57:28.809 Module HomeMatic BidCoS: Debug: Deleting queue 60 for BidCoS peer with address 0x2B6720
08/14/19 16:57:28.809 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
08/14/19 16:57:28.809 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 11). Retrying…
08/14/19 16:57:28.910 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 0ED8A0112CD6212B67200201A600A0
08/14/19 16:57:28.910 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: S90A2434D,00,00000000,01,FFFFFFFF908FAD28,D8A0112CD6212B67200201A600A0
08/14/19 16:57:28.930 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN. Raw data:
5239304132343334442C303030322C30303030303030302C46462C374646462C44320D0A
08/14/19 16:57:28.930 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: R90A2434D,0002,00000000,FF,7FFF,D2
08/14/19 16:57:28.930 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Ignoring too small packet: D2
08/14/19 16:57:31.927 Module HomeMatic BidCoS: Debug: Deleting queue 61 for BidCoS peer with address 0x2B6720
08/14/19 16:57:31.927 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
08/14/19 16:57:31.928 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 11). Retrying…
08/14/19 16:57:32.028 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 0ED8A0112CD6212B67200201A600A0
08/14/19 16:57:32.028 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: S90A24F7C,00,00000000,01,FFFFFFFF908FB957,D8A0112CD6212B67200201A600A0
08/14/19 16:57:32.049 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN. Raw data:
5239304132344637432C303030322C30303030303030302C46462C374646462C39350D0A
08/14/19 16:57:32.049 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: R90A24F7C,0002,00000000,FF,7FFF,95
08/14/19 16:57:32.049 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Ignoring too small packet: 95
08/14/19 16:57:34.282 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C0000000470696E670000000100000003000000083732373839393462
08/14/19 16:57:34.282 RPC Server (Port 2001): Info: Client number 16738 is calling RPC method: ping (2) Parameters:
(String) 7278994b
08/14/19 16:57:34.282 RPC Server (Port 2001): Response:
(Boolean) 1
08/14/19 16:57:34.283 RPC Server (Port 2001): Response binary:
42696E01000000050000000201
08/14/19 16:57:34.283 RPC client: Debug: Calling RPC method “system.multicall” on server 192.168.2.68.
08/14/19 16:57:34.283 RPC client: Parameters:
(Array length=1)
(Struct length=2)
[methodName] (String) event
[params] (Array length=4)
(String) RF-7278994b
(String) CENTRAL
(String) PONG
(String) 7278994b
08/14/19 16:57:34.283 Debug: Calling getFileDescriptor…
08/14/19 16:57:34.283 Debug: Connecting to host 192.168.2.68 on port 9126…
08/14/19 16:57:34.284 Debug: Connected to host 192.168.2.68 on port 9126. Client number is: 16739
08/14/19 16:57:34.284 RPC client: Debug: Sending packet: 42696E00000000930000001073797374656D2E6D756C746963616C6C00000001000001000000000100000101000000020000000A6D6574686F644E616D6500000003000000056576656E7400000006706172616D730000010000000004000000030000000B52462D3732373839393462000000030000000743454E5452414C0000000300000004504F4E4700000003000000083732373839393462
08/14/19 16:57:34.285 RPC client: Debug: Packet received: 42696E0100000015000001000000000100000003000000056576656E74
08/14/19 16:57:34.286 RPC client: Debug: Received packet from server 192.168.2.68: 42696E0100000015000001000000000100000003000000056576656E74
08/14/19 16:57:34.286 RPC client: Response was:
(Array length=1)
(String) event
08/14/19 16:57:34.286 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
08/14/19 16:57:34.286 RPC Server (Port 2001): Info: Client number 16738 is calling RPC method: listBidcosInterfaces (2) Parameters:
08/14/19 16:57:34.286 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
08/14/19 16:57:34.287 RPC Server (Port 2001): Response binary:
08/14/19 16:57:35.045 Module HomeMatic BidCoS: Debug: Deleting queue 62 for BidCoS peer with address 0x2B6720
08/14/19 16:57:35.045 Module HomeMatic BidCoS: Info: Setting peer to unreachable, because the queue processing was interrupted.
08/14/19 16:57:35.045 Module HomeMatic BidCoS: Info: Queue is not finished (peer: 11). Retrying…
08/14/19 16:57:35.146 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 0ED8A0112CD6212B67200201A600A0
08/14/19 16:57:35.146 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: S90A25BAA,00,00000000,01,FFFFFFFF908FC585,D8A0112CD6212B67200201A600A0
08/14/19 16:57:35.166 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN. Raw data:
5239304132354241412C303030322C30303030303030302C46462C374646462C35380D0A
08/14/19 16:57:35.166 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: R90A25BAA,0002,00000000,FF,7FFF,58
08/14/19 16:57:35.166 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Ignoring too small packet: 58
