ich verwende einen PI Version 3B mit dem Homegear Linux Image. Ich habe den HM-MOD-RPI-PCB selbst gelötet und vorher auf Homematik getestet - da geht das Paring, ich sehe die Devices und kann auch die Werte auslesen (z.B. Temperatur von HmIP-STHD).
Ich bekomme aber unter Homegear kein Pairing hin:
root@homegearpi-f7-f6-d5:/home/pi# homegear -r
01/10/18 10:50:01.751 Debug: debugLevel set to 6
01/10/18 10:50:01.752 Debug: memoryDebugging set to 1
01/10/18 10:50:01.752 Debug: devLog set to 1
01/10/18 10:50:01.752 Debug: enableCoreDumps set to 1
01/10/18 10:50:01.752 Debug: setDevicePermissions set to 1
01/10/18 10:50:01.752 Debug: workingDirectory set to /var/lib/homegear/
01/10/18 10:50:01.752 Debug: socketPath set to /var/run/homegear/
01/10/18 10:50:01.752 Debug: dataPath set to /var/lib/homegear/
01/10/18 10:50:01.752 Debug: familyDataPath set to /var/lib/homegear/families/
01/10/18 10:50:01.752 Debug: databaseMemoryJournal set to 0
01/10/18 10:50:01.752 Debug: databaseWALJournal set to 1
01/10/18 10:50:01.752 Debug: databaseSynchronous set to 1
01/10/18 10:50:01.752 Debug: databaseMaxBackups set to 10
01/10/18 10:50:01.752 Debug: logfilePath set to /var/log/homegear/
01/10/18 10:50:01.752 Debug: enableUPnP set to 1
01/10/18 10:50:01.752 Debug: uPnPIpAddress set to enxb827eba91c5b
01/10/18 10:50:01.753 Debug: caPath set to /etc/homegear/homegearca.crt
01/10/18 10:50:01.753 Debug: certPath set to /etc/homegear/homegear.crt
01/10/18 10:50:01.753 Debug: keyPath set to /etc/homegear/homegear.key
01/10/18 10:50:01.753 Debug: loadDHParamsFromFile set to 1
01/10/18 10:50:01.753 Debug: dhParamPath set to /etc/homegear/dh1024.pem
01/10/18 10:50:01.753 Debug: deviceDescriptionPath set to /etc/homegear/devices/
01/10/18 10:50:01.753 Debug: clientSettingsPath set to /etc/homegear/rpcclients.conf
01/10/18 10:50:01.753 Debug: serverSettingsPath set to /etc/homegear/rpcservers.conf
01/10/18 10:50:01.753 Debug: mqttSettingsPath set to /etc/homegear/mqtt.conf
01/10/18 10:50:01.753 Debug: familyConfigPath set to /etc/homegear/families/
01/10/18 10:50:01.753 Debug: phpIniPath set to /etc/homegear/php.ini
01/10/18 10:50:01.753 Debug: gpioPath set to /sys/class/gpio/
01/10/18 10:50:01.753 Debug: scriptPath set to /var/lib/homegear/scripts/
01/10/18 10:50:01.753 Debug: enableFlows set to 1
01/10/18 10:50:01.753 Debug: flowsPath set to /var/lib/homegear/flows/
01/10/18 10:50:01.754 Debug: flowsDataPath set to /var/lib/homegear/flows/data/
01/10/18 10:50:01.754 Debug: nodeBlueDebugOutput set to 1
01/10/18 10:50:01.754 Debug: libraryPath set to /var/lib/homegear/modules/
01/10/18 10:50:01.754 Debug: firmwarePath set to /usr/share/homegear/firmware/
01/10/18 10:50:01.754 Debug: tempPath set to /var/lib/homegear/tmp/
01/10/18 10:50:01.754 Debug: lockFilePath set to /var/run/homegear/
01/10/18 10:50:01.754 Debug: lockFilePathPermissions set to 504
01/10/18 10:50:01.754 Debug: lockFilePathUser set to homegear
01/10/18 10:50:01.754 Debug: lockFilePathGroup set to homegear
01/10/18 10:50:01.754 Debug: Added replaceClientServerAddress xmlrpc_bin://127.0.0.1:1999 xmlrpc_bin://$remoteip:1999
01/10/18 10:50:01.755 Debug: Added replaceClientServerAddress http://127.0.0.1:9292/bidcos http://$remoteip:9292/bidcos
01/10/18 10:50:01.755 Debug: prioritizeThreads set to 1
01/10/18 10:50:01.755 Debug: secureMemorySize set to 65536
01/10/18 10:50:01.755 Debug: workerThreadWindow set to 3000
01/10/18 10:50:01.755 Debug: scriptEngineMaxThreadsPerScript set to 4
01/10/18 10:50:01.755 Debug: scriptEngineMaxScriptsPerProcess set to 50
01/10/18 10:50:01.755 Debug: scriptEngineThreadCount set to 5
01/10/18 10:50:01.755 Debug: scriptEngineServerMaxConnections set to 10
01/10/18 10:50:01.755 Debug: scriptEngineWatchdogTimeout set to 60000
01/10/18 10:50:01.755 Debug: flowsProcessingThreadCountServer set to 5
01/10/18 10:50:01.755 Debug: flowsProcessingThreadCountNodes set to 10
01/10/18 10:50:01.755 Debug: flowsServerMaxConnections set to 50
01/10/18 10:50:01.755 Debug: maxNodeThreadsPerProcess set to 60
01/10/18 10:50:01.755 Debug: flowsWatchdogTimeout set to 60000
01/10/18 10:50:01.756 Debug: ipcThreadCount set to 5
01/10/18 10:50:01.756 Debug: ipsServerMaxConnections set to 20
01/10/18 10:50:01.756 Debug: cliServerMaxConnections set to 50
01/10/18 10:50:01.756 Debug: rpcServerMaxConnections set to 50
01/10/18 10:50:01.756 Debug: rpcServerThreadPriority set to 0
01/10/18 10:50:01.756 Debug: rpcServerThreadPolicy set to 0
01/10/18 10:50:01.756 Debug: rpcClientMaxThreads set to 50
01/10/18 10:50:01.756 Debug: rpcClientThreadPriority set to 0
01/10/18 10:50:01.756 Debug: rpcClientThreadPolicy set to 0
01/10/18 10:50:01.756 Debug: workerThreadPriority set to 0
01/10/18 10:50:01.756 Debug: workerThreadPolicy set to 0
01/10/18 10:50:01.756 Debug: physicalInterfaceThreadPriority set to 45
01/10/18 10:50:01.756 Debug: physicalInterfaceThreadPolicy set to 1
01/10/18 10:50:01.756 Debug: packetReceivedThreadPriority set to 0
01/10/18 10:50:01.757 Debug: packetReceivedThreadPolicy set to 0
01/10/18 10:50:01.757 Debug: eventThreadCount set to 5
01/10/18 10:50:01.757 Debug: eventThreadPriority set to 0
01/10/18 10:50:01.757 Debug: eventThreadPolicy set to 0
Debug: Trying to connect...
Connected to Homegear (version 0.7.12-1492).
> ls
ID ? Name
0 ? HomeMatic BidCoS
6 ? Sonos
9 ? Kodi
10 ? IPCam
254 ? Miscellaneous
> fs 0
(Family)> pon
(Family)> ls
(Family)> pon
(Family)> ls
(Family)> pon
(Family)> ls
(Family)>
(Taste am Fühler zum Anlernen ist natürlich gdrückt worden / Batterie neu eingelegt worden)
homegear.log
01/10/18 10:49:40.919 Starting IPC server...
01/10/18 10:49:40.919 IPC Server: Debug: Waiting for IPC server's client threads to finish.
01/10/18 10:49:40.926 Start listening for packets...
01/10/18 10:49:42.935 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Connecting to HM-MOD-RPI-PCB...
01/10/18 10:49:42.936 Debug: GPIO 18 set to 0.
01/10/18 10:49:42.937 Startup complete. Waiting for physical interfaces to connect.
01/10/18 10:49:42.937 Module Sonos: Event server "My-Sonos-1234": Info: Started listening on address 10.10.10.78 and port 7373
01/10/18 10:49:42.937 All physical interfaces are connected now.
01/10/18 10:49:42.937 Starting UPnP server...
01/10/18 10:49:42.938 Info: UPnP server: Binding to address: 10.10.10.78
01/10/18 10:49:42.939 UPnP Server: Info: Started listening.
01/10/18 10:49:43.036 Debug: GPIO 18 set to 1.
01/10/18 10:49:43.936 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000C000000436F5F4350555F424C7251
01/10/18 10:49:43.936 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000C000000436F5F4350555F424C7251
01/10/18 10:49:44.936 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0003000003180A
01/10/18 10:49:45.362 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000400000401993D
01/10/18 10:49:45.362 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000400000401993D
01/10/18 10:49:45.374 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000D000000436F
01/10/18 10:49:45.375 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 5F4350555F417070
01/10/18 10:49:45.375 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: D831
01/10/18 10:49:45.375 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000D000000436F5F4350555F417070D831
01/10/18 10:49:45.375 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Co_CPU_App packet received.
01/10/18 10:49:45.376 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD00030001021E0C
01/10/18 10:49:45.378 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000A0001040201
01/10/18 10:49:45.379 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 0003010401BE8A
01/10/18 10:49:45.379 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000A00010402010003010401BE8A
01/10/18 10:49:45.379 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Firmware version: 1.4.1
01/10/18 10:49:45.379 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD000400020A003D10
01/10/18 10:49:45.381 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00040002040119
01/10/18 10:49:45.381 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 16
01/10/18 10:49:45.382 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0004000204011916
01/10/18 10:49:45.382 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD000300030B9239
01/10/18 10:49:45.384 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD000E000304024F
01/10/18 10:49:45.385 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 4551303330363936
01/10/18 10:49:45.385 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 385705
01/10/18 10:49:45.385 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000E000304024F4551303330363936385705
01/10/18 10:49:45.385 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Serial number: OEQ0306968
01/10/18 10:49:45.386 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD000800040E5A55EFC900CC47
01/10/18 10:49:45.388 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00040004040119
01/10/18 10:49:45.389 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 6E
01/10/18 10:49:45.389 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD000400040401196E
01/10/18 10:49:45.389 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0014010503A1FADE81BABE08C1A7DFF9C9E1D02AEC01CC37
01/10/18 10:49:45.394 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0004010504010D
01/10/18 10:49:45.395 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 7A
01/10/18 10:49:45.395 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0004010504010D7A
01/10/18 10:49:45.395 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD0006010600FC7DBABE6E09
01/10/18 10:49:45.398 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD0004010604010D
01/10/18 10:49:45.398 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 46
01/10/18 10:49:45.398 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0004010604010D46
01/10/18 10:49:45.398 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Sending: FD00030007068A17
01/10/18 10:49:45.401 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: FD00040007040119
01/10/18 10:49:45.401 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received. Raw data: 52
01/10/18 10:49:45.401 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Debug: Packet received from HM-MOD-RPI-PCB: FD0004000704011952
01/10/18 10:49:45.402 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Init queue completed. Sending peers...
01/10/18 10:49:45.402 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Info: Peer sending completed.
01/10/18 10:50:01.757 Info: CLI connection accepted. Client number: 13
01/10/18 10:50:01.767 Listening for incoming commands from client number 13.
01/10/18 10:50:42.015 UPnP Server: Debug: Sending notify packets.
01/10/18 10:51:42.009 UPnP Server: Debug: Sending notify packets.
01/10/18 10:51:48.697 Debug: SSDP server: Binding to address: 10.10.10.78
01/10/18 10:51:48.698 Debug: Searching for SSDP devices ...
01/10/18 10:52:19.914 Debug: SSDP server: Binding to address: 10.10.10.78
01/10/18 10:52:19.914 Debug: Searching for SSDP devices ...
01/10/18 10:52:42.085 UPnP Server: Debug: Sending notify packets.
01/10/18 10:52:45.630 Debug: SSDP server: Binding to address: 10.10.10.78
01/10/18 10:52:45.630 Debug: Searching for SSDP devices ...
01/10/18 10:53:11.346 Debug: SSDP server: Binding to address: 10.10.10.78
01/10/18 10:53:11.346 Debug: Searching for SSDP devices ...
01/10/18 10:53:37.062 Debug: SSDP server: Binding to address: 10.10.10.78
01/10/18 10:53:37.062 Debug: Searching for SSDP devices ...
01/10/18 10:53:42.061 UPnP Server: Debug: Sending notify packets.
01/10/18 10:54:02.773 Debug: SSDP server: Binding to address: 10.10.10.78
01/10/18 10:54:02.773 Debug: Searching for SSDP devices ...
01/10/18 10:54:25.404 Info: Connection to CLI client number 13 closed.
01/10/18 10:54:28.490 Debug: SSDP server: Binding to address: 10.10.10.78
01/10/18 10:54:28.490 Debug: Searching for SSDP devices ...
01/10/18 10:54:42.031 UPnP Server: Debug: Sending notify packets.
01/10/18 10:54:43.041 Debug: Joining read thread of CLI client 0
01/10/18 10:54:43.042 Debug: CLI client 0 removed.
root@homegearpi-f7-f6-d5:/home/pi# cat /var/log/homegear/homegear.err
01/10/18 10:49:37.781 Error: Cannot move file: /var/lib/homegear/db.sql.bak3
01/10/18 10:49:37.781 Error: Cannot move file: /var/lib/homegear/db.sql.bak2
01/10/18 10:49:37.782 Error: Cannot move file: /var/lib/homegear/db.sql.bak1
01/10/18 10:49:37.782 Error: Cannot move file: /var/lib/homegear/db.sql.bak0
01/10/18 10:49:37.782 Error copying file /var/lib/homegear/db.sql: Read-only file system
01/10/18 10:49:37.782 Error: Cannot copy file: /var/lib/homegear/db.sql.bak0
01/10/18 10:49:37.788 Warning: Can't execute "VACUUM": attempt to write a readonly database
01/10/18 10:49:37.792 Can't execute "PRAGMA journal_mode=WAL": attempt to write a readonly database
01/10/18 10:49:37.807 Could not set owner on /var/lib/homegear/db.sql.bak1
01/10/18 10:49:37.807 Could not set permissions on /var/lib/homegear/db.sql.bak1
01/10/18 10:49:37.807 Could not set owner on /var/lib/homegear/db.sql.bak0
01/10/18 10:49:37.808 Could not set permissions on /var/lib/homegear/db.sql.bak0
01/10/18 10:49:37.808 Could not set owner on /var/lib/homegear/db.sql
01/10/18 10:49:37.808 Could not set owner on /var/lib/homegear/db.sql.bak2
01/10/18 10:49:37.808 Could not set permissions on /var/lib/homegear/db.sql.bak2
01/10/18 10:49:37.808 Could not set owner on /var/lib/homegear/db.sql.bak3
01/10/18 10:49:37.808 Could not set permissions on /var/lib/homegear/db.sql.bak3
01/10/18 10:49:40.613 Can't execute command "REPLACE INTO devices VALUES(?, ?, ?, ?, ?)": attempt to write a readonly database
01/10/18 10:49:40.652 Warning: Unknown parameter property: label
Ich hatte das Modul vorher per Anleitung geflasht:
root@homegearpi-f7-f6-d5:/home/pi# cd hmcfgusb/
root@homegearpi-f7-f6-d5:/home/pi/hmcfgusb# ./flash-hmmoduart -U /dev/ttyAMA0 ./coprocessor_update.eq3
HM-MOD-UART flasher version 0.103-git
Reading firmware from ../coprocessor_update.eq3...
Firmware with 43 blocks successfully read.
Initializing HM-MOD-UART...
Waiting for bootloader to settle...
HM-MOD-UART opened.
Flashing 43 blocks: |
Firmware update successfull!
Zum Pairen stehen mir zur Verfügung:
- 2x HmIP-STHD Temp. and Humidity Sensor
- 1x HMIP-SWDO Fenster und Türkontakt
hmmm… irgendwie weiß ich nicht weiter: MIr bleiben noch
- Firmware Problem auf dem Modul
- Termostate haben immer noch alte Config trotz reset
Kann da jemand helfen?
Viele Grüße & Danke,
John
