Ich habe das CC1101 Board entsprechend den Anleitungen verbunden und SPI scheint zu funktionieren. Ich bekomme jedoch immer den Fehler “MAX! packet received, but CRC failed.” und das Anlernen klappt nicht. Der Thermostat ist ca. 2 Meter von der Antenne vom CC1101 entfernt.
Anbei das Log (diesem kann man auch meine Konfiguration in max.conf entnehmen):
11/12/16 11:52:15.249 Starting Homegear...
11/12/16 11:52:15.249 Homegear version 0.6.7-1545
11/12/16 11:52:15.250 Git commit SHA of libhomegear-base: -
11/12/16 11:52:15.250 Git branch of libhomegear-base: -
11/12/16 11:52:15.250 Git commit SHA of Homegear: -
11/12/16 11:52:15.250 Git branch of Homegear: -
11/12/16 11:52:15.250 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
11/12/16 11:52:15.251 Info: Core file size now is "4294967295".
11/12/16 11:52:15.251 Info: Setting maximum thread priority to "4294967295" for user with id 0 and group with id 0.
11/12/16 11:52:15.251 Info: Maximum thread priority now is "4294967295".
11/12/16 11:52:15.335 Info: Backing up database...
11/12/16 11:52:15.750 Initializing database...
11/12/16 11:52:15.754 Debug: Loading licensing modules
11/12/16 11:52:15.754 Debug: Loading family modules
11/12/16 11:52:15.754 Info: Loading family module mod_max.so
11/12/16 11:52:15.836 /etc/homegear/families/max.conf
11/12/16 11:52:15.841 Debug: id set to My-MAX-CC1101
11/12/16 11:52:15.841 Debug: default set to 1
11/12/16 11:52:15.842 Debug: deviceType set to cc1100
11/12/16 11:52:15.842 Debug: device set to /dev/spidev0.0
11/12/16 11:52:15.842 Debug: responseDelay set to 45
11/12/16 11:52:15.842 Debug: interruptPin set to 0
11/12/16 11:52:15.847 Debug: GPIO1 set to 25
11/12/16 11:52:15.848 Module MAX: Debug: Loading module...
11/12/16 11:52:15.848 Module MAX: Debug: Creating physical device. Type defined in max.conf is: cc1100
11/12/16 11:52:15.859 Module MAX: TI CC110X "My-MAX-CC1101": Debug: PATABLE will be set to 0xC0
11/12/16 11:52:15.860 Info: Loading family module mod_miscellaneous.so
11/12/16 11:52:15.887 /etc/homegear/families/miscellaneous.conf
11/12/16 11:52:15.888 Module Miscellaneous: Debug: Loading module...
11/12/16 11:52:15.888 Info: Setting up physical interfaces and GPIOs...
11/12/16 11:52:15.888 Debug: Setting up physical device.
11/12/16 11:52:15.888 Module MAX: TI CC110X "My-MAX-CC1101": Debug: CC1100: Setting device permissions
11/12/16 11:52:15.888 Module MAX: TI CC110X "My-MAX-CC1101": Debug: CC1100: Exporting GPIO
11/12/16 11:52:15.889 Debug: Exporting GPIO with index 1 and number 25 for device "cc1100".
11/12/16 11:52:15.889 Module MAX: TI CC110X "My-MAX-CC1101": Debug: CC1100: Setting GPIO permissions
11/12/16 11:52:15.889 Debug: GPIO path for GPIO with index 1 and device cc1100 set to "/sys/class/gpio/gpio25".
11/12/16 11:52:15.890 Info: Dropping privileges to user homegear (113) and group homegear (121)
11/12/16 11:52:15.890 Info: Homegear is (now) running as user with id 113 and group with id 121.
11/12/16 11:52:15.890 Starting script engine server...
11/12/16 11:52:16.311 Script Engine Server: Debug: Waiting for script engine server's client threads to finish.
11/12/16 11:52:16.312 Initializing licensing controller...
11/12/16 11:52:16.313 Loading licensing controller data...
11/12/16 11:52:16.313 Loading devices...
11/12/16 11:52:16.313 Loading XML RPC devices...
11/12/16 11:52:16.317 Loading XML RPC device /etc/homegear/devices/4/BC-SC-Rd-WM-2.xml
11/12/16 11:52:16.343 Loading XML RPC device /etc/homegear/devices/4/BC-TS-Sw-Pl.xml
11/12/16 11:52:16.366 Loading XML RPC device /etc/homegear/devices/4/BC-RT-TRX-CyG-2.xml
11/12/16 11:52:16.389 Loading XML RPC device /etc/homegear/devices/4/BC-RT-TRX-CyG-3.xml
11/12/16 11:52:16.413 Loading XML RPC device /etc/homegear/devices/4/BC-SC-Rd-WM.xml
11/12/16 11:52:16.420 Loading XML RPC device /etc/homegear/devices/4/BC-RT-TRX-CyG.xml
11/12/16 11:52:16.443 Loading XML RPC device /etc/homegear/devices/4/BC-PB-2-WM.xml
11/12/16 11:52:16.445 Loading XML RPC device /etc/homegear/devices/4/BC-TC-C-WM-4.xml
11/12/16 11:52:16.471 Loading XML RPC device /etc/homegear/devices/4/BC-TC-C-WM-2.xml
11/12/16 11:52:16.496 Loading XML RPC device /etc/homegear/devices/4/BC-RT-TRX-CyN.xml
11/12/16 11:52:16.518 Loading device 2
11/12/16 11:52:16.526 Loading XML RPC devices...
11/12/16 11:52:16.536 Loading XML RPC device /etc/homegear/devices/254/Template.xml
11/12/16 11:52:16.543 Loading device 1
11/12/16 11:52:16.543 Start listening for packets...
11/12/16 11:52:16.545 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 30
11/12/16 11:52:16.545 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 1F
11/12/16 11:52:16.545 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 005B
11/12/16 11:52:16.545 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.545 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8000
11/12/16 11:52:16.545 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 005B
11/12/16 11:52:16.545 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 012E
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8100
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 002E
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0246
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8200
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0046
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0307
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8300
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0007
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 04C6
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8400
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 00C6
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0526
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8500
11/12/16 11:52:16.546 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0026
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 06FF
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8600
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 00FF
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 070C
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8700
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 000C
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0845
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8800
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0045
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0900
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8900
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0000
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0A00
11/12/16 11:52:16.547 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8A00
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0B06
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8B00
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0006
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0C00
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8C00
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0000
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0D21
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8D00
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0021
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0E65
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8E00
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0065
11/12/16 11:52:16.548 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 0F6A
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 8F00
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 006A
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 10C8
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9000
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 00C8
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1193
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9100
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0093
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1203
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9200
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0003
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1322
11/12/16 11:52:16.549 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9300
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0022
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 14F8
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9400
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 00F8
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1534
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9500
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0034
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1607
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9600
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0007
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1730
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9700
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0030
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1818
11/12/16 11:52:16.550 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9800
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0018
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1916
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9900
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0016
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1A6C
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9A00
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 006C
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1B03
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9B00
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0003
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1C40
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9C00
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0040
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1D91
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9D00
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0091
11/12/16 11:52:16.551 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1E87
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9E00
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0087
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 1F6B
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 9F00
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 006B
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 20F8
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A000
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 00F8
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2156
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A100
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0056
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2210
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A200
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0010
11/12/16 11:52:16.552 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 23E9
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A300
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 00E9
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 242A
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A400
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 002A
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2500
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A500
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0000
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 261F
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A600
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 001F
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2741
11/12/16 11:52:16.553 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A700
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0041
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2800
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A800
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0000
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2959
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: A900
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0059
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2C81
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: AC00
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0081
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 2D35
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: AD00
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0035
11/12/16 11:52:16.554 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 3EC0
11/12/16 11:52:16.555 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 0F0F
11/12/16 11:52:16.555 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: BE00
11/12/16 11:52:16.555 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 00C0
11/12/16 11:52:16.555 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 3A
11/12/16 11:52:16.555 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 34
11/12/16 11:52:16.555 Module MAX: TI CC110X "My-MAX-CC1101": Debug: CC1100: Setting GPIO direction
11/12/16 11:52:16.555 Module MAX: TI CC110X "My-MAX-CC1101": Debug: CC1100: Setting GPIO edge
11/12/16 11:52:16.556 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: F300
11/12/16 11:52:16.557 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 1000
11/12/16 11:52:16.557 Module MAX: TI CC110X "My-MAX-CC1101": Debug: MAX! packet received, but CRC failed.
11/12/16 11:52:16.557 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 3A
11/12/16 11:52:16.557 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Received: 1F
11/12/16 11:52:16.557 Module MAX: TI CC110X "My-MAX-CC1101": Debug: Sending: 34
11/12/16 11:52:16.557 Initializing RPC client...
11/12/16 11:52:16.557 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001...
11/12/16 11:52:16.560 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled...
11/12/16 11:52:16.560 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
11/12/16 11:52:16.570 RPC Server (Port 2001): Error in file RPC/RPCServer.cpp line 1674 in function void Rpc::RPCServer::getSocketDescriptor(): No IP address could be found: Success
11/12/16 11:52:16.637 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentication enabled...
11/12/16 11:52:16.637 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
11/12/16 11:52:16.638 RPC Server (Port 2002): Error in file RPC/RPCServer.cpp line 1674 in function void Rpc::RPCServer::getSocketDescriptor(): No IP address could be found: Success
11/12/16 11:52:16.666 Starting CLI server...
11/12/16 11:52:16.667 Debug: Waiting for CLI client threads to finish.
11/12/16 11:52:16.667 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
11/12/16 11:52:16.667 Initializing event handler...
11/12/16 11:52:16.667 Loading events...
11/12/16 11:52:16.667 RPC Server (Port 2003): Error in file RPC/RPCServer.cpp line 1674 in function void Rpc::RPCServer::getSocketDescriptor(): No IP address could be found: Success
11/12/16 11:52:16.668 Startup complete. Waiting for physical interfaces to connect.
11/12/16 11:52:16.668 All physical interfaces are connected now.
11/12/16 11:52:16.668 Starting UPnP server...
11/12/16 11:52:16.668 UPnP Server: Error in file UPnP/UPnP.cpp line 188 in function void UPnP::getAddress(): No IP address could be found: No such file or directory
11/12/16 11:52:16.668 UPnP Server: Error: Could not get IP address.
11/12/16 11:52:16.669 Warning: Not starting server, because no suitable RPC server for serving the XML description is available (Necessary settings: No SSL, no auth, webserver enabled).
Kann man daraus zurückschließen, dass der Interrupt von GDO0 auf GPIO25 richtig erkannt wird? Was könnte sonst noch schieflaufen?
