Es gibt keine Flows mehr bei Node-Blue:
Und auch kein AdminUI
01/11/19 08:02:48.691 RPC Server (Port 2001): Warning: SSL is not enabled for this RPC server. It is strongly recommended to disable all unen crypted RPC servers when the connected clients support it.
01/11/19 08:02:48.691 RPC Server (Port 2001): Warning: RPC server has no authorization enabled. Everybody on your local network can login int o this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
01/11/19 08:02:48.695 RPC Server (Port 2002): Warning: RPC server has no authorization enabled. Everybody on your local network can login int o this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
01/11/19 08:02:50.911 Error: A core file exists in Homegear's working directory ("/var/lib/homegear/core"). Please send this file to the Home gear team including information about your system (Linux distribution, CPU architecture), the Homegear version, the current log files and inf ormation what might've caused the error.
01/11/19 08:03:18.825 Node-BLUE Server: Error in file Node-BLUE/NodeBlueServer.cpp line 1685 in function std::__cxx11::string Homegear::NodeB lue::NodeBlueServer::handleGet(std::__cxx11::string&, BaseLib::Http&, std::__cxx11::string&): std::bad_alloc
01/11/19 08:03:18.832 Warning: Requested URL not found: node-blue/flows
01/11/19 08:03:33.849 RPC Server (Port 2001): Error: Broken pipe
01/11/19 08:03:35.170 Node-BLUE Server: Error in file Node-BLUE/NodeBlueServer.cpp line 1685 in function std::__cxx11::string Homegear::NodeB lue::NodeBlueServer::handleGet(std::__cxx11::string&, BaseLib::Http&, std::__cxx11::string&): std::bad_alloc
01/11/19 08:03:35.170 Warning: Requested URL not found: node-blue/flows
01/11/19 08:05:45.430 Node-BLUE Server: Error in file Node-BLUE/NodeBlueServer.cpp line 1685 in function std::__cxx11::string Homegear::NodeB lue::NodeBlueServer::handleGet(std::__cxx11::string&, BaseLib::Http&, std::__cxx11::string&): std::bad_alloc
01/11/19 08:05:45.431 Warning: Requested URL not found: node-blue/flows
01/11/19 08:08:02.593 RPC Server (Port 2001): Error: Broken pipe
01/11/19 08:08:04.130 Node-BLUE Server: Error in file Node-BLUE/NodeBlueServer.cpp line 1685 in function std::__cxx11::string Homegear::NodeB lue::NodeBlueServer::handleGet(std::__cxx11::string&, BaseLib::Http&, std::__cxx11::string&): std::bad_alloc
01/11/19 08:12:10.181 Warning: Requested URL not found: favicon.ico
01/11/19 08:12:15.423 Node-BLUE Server: Error in file Node-BLUE/NodeBlueServer.cpp line 1685 in function std::__cxx11::string Homegear::NodeB lue::NodeBlueServer::handleGet(std::__cxx11::string&, BaseLib::Http&, std::__cxx11::string&): std::bad_alloc
01/11/19 08:12:15.423 Warning: Requested URL not found: node-blue/flows
01/11/19 08:13:05.729 RPC Server (Port 2002): Warning: Could not decode JSON RPC packet:
(Struct length=2)
[editor]
(Struct length=1)
[view]
(Struct length=5)
[view-grid-size]
(Integer) 10
[view-node-status]
(Boolean) 1
[view-show-grid]
(Boolean) 1
[view-show-tips]
(Boolean) 1
[view-snap-grid]
(Boolean) 1
[menu-menu-item-sidebar]
(Boolean) 0
