Heizungsthermostat (HM-CC-RT-DN): Parameter I_VALUE_EXTERN
Hi, ich arbeite zurzeit mit Homegear und einer selbst programmieren Oberfläche und kontrolliere damit meine Heizung.
Kennt jemand die Parameter
[ul]I_VALUE_EXTERN
I_VALUE_INTERN
P_START_VALUE_EXTERN
P_START_VALUE_INTERN
P_VALUE_EXTERN
P_VALUE_INTERN[/ul] des Gerätes HM-CC-RT-DN (Heizungsthermostat).
Kann dazu irgendwie nichts finden!
Außerdem finde ich keine Parameter für die Hysterese.
Danke schon mal im Voraus
[code]GET ALL VALUES
Array
[0] => Array
[ADDRESS] => XXXXXXXX
[CHANNELS] => Array
[0] => Array
[INDEX] => 0
[PARAMSET] => Array
[CENTRAL_ADDRESS_SPOOFED] => Array
[MAX] => 1
[MIN] => 0
[TYPE] => ENUM
[VALUE] => 0
[VALUE_LIST] => Array
[0] => UNSET
[1] => CENTRAL_ADDRESS_SPOOFED
                                        [WRITEABLE] => 1
                                [CONFIG_PENDING] => Array
                                        [TYPE] => BOOL
                                        [VALUE] =>
                                        [WRITEABLE] =>
                                [DEVICE_IN_BOOTLOADER] => Array
                                        [TYPE] => BOOL
                                        [VALUE] =>
                                        [WRITEABLE] =>
                                [INHIBIT] => Array
                                        [TYPE] => BOOL
                                        [VALUE] =>
                                        [WRITEABLE] => 1
                                [LOWBAT] => Array
                                        [TYPE] => BOOL
                                        [VALUE] =>
                                        [WRITEABLE] =>
                                [RSSI_DEVICE] => Array
                                        [MAX] => 2147483647
                                        [MIN] => -2147483648
                                        [TYPE] => INTEGER
                                        [VALUE] => -48
                                        [WRITEABLE] =>
                                [RSSI_PEER] => Array
                                        [MAX] => 2147483647
                                        [TYPE] => INTEGER
                                        [VALUE] => 0
                                        [WRITEABLE] =>
                                [STICKY_UNREACH] => Array
                                        [TYPE] => BOOL
                                        [VALUE] => 1
                                        [WRITEABLE] => 1
                                [UNREACH] => Array
                                        [TYPE] => BOOL
                                        [VALUE] =>
                                        [WRITEABLE] =>
                                [UPDATE_PENDING] => Array
                                        [TYPE] => BOOL
                                        [VALUE] =>
                                        [WRITEABLE] =>
                [1] => Array
                        [INDEX] => 1
                        [PARAMSET] => Array
                [2] => Array
                        [INDEX] => 2
                        [PARAMSET] => Array
                [3] => Array
                        [INDEX] => 3
                        [PARAMSET] => Array
                                [WINDOW_STATE] => Array
                                        [TYPE] => BOOL
                                        [VALUE] =>
                                        [WRITEABLE] => 1
                [4] => Array
                        [INDEX] => 4
                        [PARAMSET] => Array
                                [ACTUAL_TEMPERATURE] => Array
                                        [MAX] => 56
                                        [MIN] => -10
                                        [TYPE] => FLOAT
                                        [VALUE] => 25.6
                                        [WRITEABLE] =>
                                [BATTERY_STATE] => Array
                                        [MAX] => 4.6
                                        [MIN] => 1.5
                                        [TYPE] => FLOAT
                                        [VALUE] => 2.6
                                        [WRITEABLE] =>
                                [BOOST_STATE] => Array
                                        [MAX] => 30
                                        [MIN] => 0
                                        [TYPE] => INTEGER
                                        [VALUE] => 37
                                        [WRITEABLE] =>
                                [CONTROL_MODE] => Array
                                        [MAX] => 3
                                        [MIN] => 0
                                        [TYPE] => ENUM
                                        [VALUE] => 1
                                                [0] => AUTO-MODE
                                                [1] => MANU-MODE
                                                [2] => PARTY-MODE
                                                [3] => BOOST-MODE
                                        [WRITEABLE] =>
                                [FAULT_REPORTING] => Array
                                        [MAX] => 7
                                        [MIN] => 0
                                        [TYPE] => ENUM
                                        [VALUE] => 0
                                                [0] => NO_FAULT
                                                [1] => VALVE_TIGHT
                                                [2] => ADJUSTING_RANGE_TOO_LARGE
                                                [3] => ADJUSTING_RANGE_TOO_SMALL
                                                [4] => COMMUNICATION_ERROR
                                                [5] =>
                                                [6] => LOWBAT
                                                [7] => VALVE_ERROR_POSITION
                                        [WRITEABLE] =>
                                [PARTY_START_DAY] => Array
                                        [MAX] => 31
                                        [MIN] => 1
                                        [TYPE] => INTEGER
                                        [VALUE] => 3
                                        [WRITEABLE] => 1
                                [PARTY_START_MONTH] => Array
                                        [MAX] => 12
                                        [MIN] => 1
                                        [TYPE] => INTEGER
                                        [VALUE] => 1
                                        [WRITEABLE] => 1
                                [PARTY_START_TIME] => Array
                                        [MAX] => 1410
                                        [MIN] => 0
                                        [TYPE] => INTEGER
                                        [VALUE] => 1110
                                        [WRITEABLE] => 1
                                [PARTY_START_YEAR] => Array
                                        [MAX] => 99
                                        [MIN] => 0
                                        [TYPE] => INTEGER
                                        [VALUE] => 16
                                        [WRITEABLE] => 1
                                [PARTY_STOP_DAY] => Array
                                        [MAX] => 31
                                        [MIN] => 1
                                        [TYPE] => INTEGER
                                        [VALUE] => 30
                                        [WRITEABLE] => 1
                                [PARTY_STOP_MONTH] => Array
                                        [MAX] => 12
                                        [MIN] => 1
                                        [TYPE] => INTEGER
                                        [VALUE] => 1
                                        [WRITEABLE] => 1
                                [PARTY_STOP_TIME] => Array
                                        [MAX] => 1410
                                        [MIN] => 0
                                        [TYPE] => INTEGER
                                        [VALUE] => 210
                                        [WRITEABLE] => 1
                                [PARTY_STOP_YEAR] => Array
                                        [MAX] => 99
                                        [MIN] => 0
                                        [TYPE] => INTEGER
                                        [VALUE] => 93
                                        [WRITEABLE] => 1
                                [PARTY_TEMPERATURE] => Array
                                        [MAX] => 30
                                        [MIN] => 5
                                        [TYPE] => FLOAT
                                        [VALUE] => 30.5
                                        [WRITEABLE] => 1
                                [SET_TEMPERATURE] => Array
                                        [MAX] => 30.5
                                        [MIN] => 4.5
                                        [TYPE] => FLOAT
                                        [VALUE] => 30.5
                                        [WRITEABLE] => 1
                                [VALVE_STATE] => Array
                                        [MAX] => 99
                                        [MIN] => 0
                                        [TYPE] => INTEGER
                                        [VALUE] => 10
                                        [WRITEABLE] =>
                [5] => Array
                        [INDEX] => 5
                        [PARAMSET] => Array
                [6] => Array
                        [INDEX] => 6
                        [PARAMSET] => Array
        [FAMILY] => 0
        [ID] => 14
        [TYPE] => HM-CC-RT-DN
GET DEVICE INFO
Array
[ID] => 14
[INTERFACE] => My-CUL
[NAME] => WZ_Thermostat1
[RSSI] => -48
GET ALL METADATA
Array
[DAEMPFUNGSBREITE] => 1.5
[OFFSET] => 6
[OFFSETDIFDOWN] => 0.8
[OFFSETDIFUP] => 0.8
[SOLL] => 19
[SOLLDIFDOWN] => 0.5
[SOLLDIFUP] => 0.5
[VENTILSTELLUNG] => 10
[VENTILSTELLUNGEN] => 100,70,35,10,0
GET PARAMSET
Array
[0] => Array
[MASTER] => Array
[ADAPTIVE_REGULATION] => 0
[BACKLIGHT_ON_TIME] => 10
[BOOST_AFTER_WINDOW_OPEN] =>
[BOOST_POSITION] => 80
[BOOST_TIME_PERIOD] => 1
[BURST_RX] => 1
[BUTTON_LOCK] =>
[BUTTON_RESPONSE_WITHOUT_BACKLIGHT] =>
[CYCLIC_INFO_MSG] => 1
[CYCLIC_INFO_MSG_DIS] => 0
[DAYLIGHT_SAVING_TIME] => 1
[DECALCIFICATION_TIME] => 660
[DECALCIFICATION_WEEKDAY] => 0
[DISPLAY_INFORMATION] => 0
[ENDTIME_FRIDAY_1] => 360
[ENDTIME_FRIDAY_10] => 1440
[ENDTIME_FRIDAY_11] => 1440
[ENDTIME_FRIDAY_12] => 1440
[ENDTIME_FRIDAY_13] => 1440
[ENDTIME_FRIDAY_2] => 540
[ENDTIME_FRIDAY_3] => 1020
[ENDTIME_FRIDAY_4] => 1320
[ENDTIME_FRIDAY_5] => 1440
[ENDTIME_FRIDAY_6] => 1440
[ENDTIME_FRIDAY_7] => 1440
[ENDTIME_FRIDAY_8] => 1440
[ENDTIME_FRIDAY_9] => 1440
[ENDTIME_MONDAY_1] => 360
[ENDTIME_MONDAY_10] => 1440
[ENDTIME_MONDAY_11] => 1440
[ENDTIME_MONDAY_12] => 1440
[ENDTIME_MONDAY_13] => 1440
[ENDTIME_MONDAY_2] => 540
[ENDTIME_MONDAY_3] => 1020
[ENDTIME_MONDAY_4] => 1320
[ENDTIME_MONDAY_5] => 1440
[ENDTIME_MONDAY_6] => 1440
[ENDTIME_MONDAY_7] => 1440
[ENDTIME_MONDAY_8] => 1440
[ENDTIME_MONDAY_9] => 1440
[ENDTIME_SATURDAY_1] => 360
[ENDTIME_SATURDAY_10] => 1440
[ENDTIME_SATURDAY_11] => 1440
[ENDTIME_SATURDAY_12] => 1440
[ENDTIME_SATURDAY_13] => 1440
[ENDTIME_SATURDAY_2] => 1320
[ENDTIME_SATURDAY_3] => 1440
[ENDTIME_SATURDAY_4] => 1440
[ENDTIME_SATURDAY_5] => 1440
[ENDTIME_SATURDAY_6] => 1440
[ENDTIME_SATURDAY_7] => 1440
[ENDTIME_SATURDAY_8] => 1440
[ENDTIME_SATURDAY_9] => 1440
[ENDTIME_SUNDAY_1] => 360
[ENDTIME_SUNDAY_10] => 1440
[ENDTIME_SUNDAY_11] => 1440
[ENDTIME_SUNDAY_12] => 1440
[ENDTIME_SUNDAY_13] => 1440
[ENDTIME_SUNDAY_2] => 1320
[ENDTIME_SUNDAY_3] => 1440
[ENDTIME_SUNDAY_4] => 1440
[ENDTIME_SUNDAY_5] => 1440
[ENDTIME_SUNDAY_6] => 1440
[ENDTIME_SUNDAY_7] => 1440
[ENDTIME_SUNDAY_8] => 1440
[ENDTIME_SUNDAY_9] => 1440
[ENDTIME_THURSDAY_1] => 360
[ENDTIME_THURSDAY_10] => 1440
[ENDTIME_THURSDAY_11] => 1440
[ENDTIME_THURSDAY_12] => 1440
[ENDTIME_THURSDAY_13] => 1440
[ENDTIME_THURSDAY_2] => 540
[ENDTIME_THURSDAY_3] => 1020
[ENDTIME_THURSDAY_4] => 1320
[ENDTIME_THURSDAY_5] => 1440
[ENDTIME_THURSDAY_6] => 1440
[ENDTIME_THURSDAY_7] => 1440
[ENDTIME_THURSDAY_8] => 1440
[ENDTIME_THURSDAY_9] => 1440
[ENDTIME_TUESDAY_1] => 360
[ENDTIME_TUESDAY_10] => 1440
[ENDTIME_TUESDAY_11] => 1440
[ENDTIME_TUESDAY_12] => 1440
[ENDTIME_TUESDAY_13] => 1440
[ENDTIME_TUESDAY_2] => 540
[ENDTIME_TUESDAY_3] => 1020
[ENDTIME_TUESDAY_4] => 1320
[ENDTIME_TUESDAY_5] => 1440
[ENDTIME_TUESDAY_6] => 1440
[ENDTIME_TUESDAY_7] => 1440
[ENDTIME_TUESDAY_8] => 1440
[ENDTIME_TUESDAY_9] => 1440
[ENDTIME_WEDNESDAY_1] => 360
[ENDTIME_WEDNESDAY_10] => 1440
[ENDTIME_WEDNESDAY_11] => 1440
[ENDTIME_WEDNESDAY_12] => 1440
[ENDTIME_WEDNESDAY_13] => 1440
[ENDTIME_WEDNESDAY_2] => 540
[ENDTIME_WEDNESDAY_3] => 1020
[ENDTIME_WEDNESDAY_4] => 1320
[ENDTIME_WEDNESDAY_5] => 1440
[ENDTIME_WEDNESDAY_6] => 1440
[ENDTIME_WEDNESDAY_7] => 1440
[ENDTIME_WEDNESDAY_8] => 1440
[ENDTIME_WEDNESDAY_9] => 1440
[GLOBAL_BUTTON_LOCK] =>
[I_VALUE_EXTERN] => 15
[I_VALUE_INTERN] => 15
[LOCAL_RESET_DISABLE] =>
[LOW_BAT_LIMIT] => 2.1
[MANU_MODE_PRIORITIZATION] => 1
[MIN_MAX_VALUE_NOT_RELEVANT_FOR_MANU_MODE] =>
[MODUS_BUTTON_LOCK] => 1
[PARTY_MODE_PRIORITIZATION] => 1
[P_START_VALUE_EXTERN] => 30
[P_START_VALUE_INTERN] => 30
[P_VALUE_EXTERN] => 30
[P_VALUE_INTERN] => 30
[ROAMING] =>
[SHOW_WEEKDAY] =>
[TEMPERATUREFALL_MODUS] => 4
[TEMPERATUREFALL_VALUE] => 1.3
[TEMPERATUREFALL_WINDOW_OPEN] => 12
[TEMPERATUREFALL_WINDOW_OPEN_TIME_PERIOD] => 15
[TEMPERATURE_COMFORT] => 19
[TEMPERATURE_FRIDAY_1] => 17
[TEMPERATURE_FRIDAY_10] => 17
[TEMPERATURE_FRIDAY_11] => 17
[TEMPERATURE_FRIDAY_12] => 17
[TEMPERATURE_FRIDAY_13] => 17
[TEMPERATURE_FRIDAY_2] => 21
[TEMPERATURE_FRIDAY_3] => 17
[TEMPERATURE_FRIDAY_4] => 21
[TEMPERATURE_FRIDAY_5] => 17
[TEMPERATURE_FRIDAY_6] => 17
[TEMPERATURE_FRIDAY_7] => 17
[TEMPERATURE_FRIDAY_8] => 17
[TEMPERATURE_FRIDAY_9] => 17
[TEMPERATURE_LOWERING] => 5
[TEMPERATURE_MAXIMUM] => 30.5
[TEMPERATURE_MINIMUM] => 4.5
[TEMPERATURE_MONDAY_1] => 17
[TEMPERATURE_MONDAY_10] => 17
[TEMPERATURE_MONDAY_11] => 17
[TEMPERATURE_MONDAY_12] => 17
[TEMPERATURE_MONDAY_13] => 17
[TEMPERATURE_MONDAY_2] => 21
[TEMPERATURE_MONDAY_3] => 17
[TEMPERATURE_MONDAY_4] => 21
[TEMPERATURE_MONDAY_5] => 17
[TEMPERATURE_MONDAY_6] => 17
[TEMPERATURE_MONDAY_7] => 17
[TEMPERATURE_MONDAY_8] => 17
[TEMPERATURE_MONDAY_9] => 17
[TEMPERATURE_OFFSET] => 14
[TEMPERATURE_SATURDAY_1] => 17
[TEMPERATURE_SATURDAY_10] => 17
[TEMPERATURE_SATURDAY_11] => 17
[TEMPERATURE_SATURDAY_12] => 17
[TEMPERATURE_SATURDAY_13] => 17
[TEMPERATURE_SATURDAY_2] => 21
[TEMPERATURE_SATURDAY_3] => 17
[TEMPERATURE_SATURDAY_4] => 17
[TEMPERATURE_SATURDAY_5] => 17
[TEMPERATURE_SATURDAY_6] => 17
[TEMPERATURE_SATURDAY_7] => 17
[TEMPERATURE_SATURDAY_8] => 17
[TEMPERATURE_SATURDAY_9] => 17
[TEMPERATURE_SUNDAY_1] => 17
[TEMPERATURE_SUNDAY_10] => 17
[TEMPERATURE_SUNDAY_11] => 17
[TEMPERATURE_SUNDAY_12] => 17
[TEMPERATURE_SUNDAY_13] => 17
[TEMPERATURE_SUNDAY_2] => 21
[TEMPERATURE_SUNDAY_3] => 17
[TEMPERATURE_SUNDAY_4] => 17
[TEMPERATURE_SUNDAY_5] => 17
[TEMPERATURE_SUNDAY_6] => 17
[TEMPERATURE_SUNDAY_7] => 17
[TEMPERATURE_SUNDAY_8] => 17
[TEMPERATURE_SUNDAY_9] => 17
[TEMPERATURE_THURSDAY_1] => 17
[TEMPERATURE_THURSDAY_10] => 17
[TEMPERATURE_THURSDAY_11] => 17
[TEMPERATURE_THURSDAY_12] => 17
[TEMPERATURE_THURSDAY_13] => 17
[TEMPERATURE_THURSDAY_2] => 21
[TEMPERATURE_THURSDAY_3] => 17
[TEMPERATURE_THURSDAY_4] => 21
[TEMPERATURE_THURSDAY_5] => 17
[TEMPERATURE_THURSDAY_6] => 17
[TEMPERATURE_THURSDAY_7] => 17
[TEMPERATURE_THURSDAY_8] => 17
[TEMPERATURE_THURSDAY_9] => 17
[TEMPERATURE_TUESDAY_1] => 17
[TEMPERATURE_TUESDAY_10] => 17
[TEMPERATURE_TUESDAY_11] => 17
[TEMPERATURE_TUESDAY_12] => 17
[TEMPERATURE_TUESDAY_13] => 17
[TEMPERATURE_TUESDAY_2] => 21
[TEMPERATURE_TUESDAY_3] => 17
[TEMPERATURE_TUESDAY_4] => 21
[TEMPERATURE_TUESDAY_5] => 17
[TEMPERATURE_TUESDAY_6] => 17
[TEMPERATURE_TUESDAY_7] => 17
[TEMPERATURE_TUESDAY_8] => 17
[TEMPERATURE_TUESDAY_9] => 17
[TEMPERATURE_WEDNESDAY_1] => 17
[TEMPERATURE_WEDNESDAY_10] => 17
[TEMPERATURE_WEDNESDAY_11] => 17
[TEMPERATURE_WEDNESDAY_12] => 17
[TEMPERATURE_WEDNESDAY_13] => 17
[TEMPERATURE_WEDNESDAY_2] => 21
[TEMPERATURE_WEDNESDAY_3] => 17
[TEMPERATURE_WEDNESDAY_4] => 21
[TEMPERATURE_WEDNESDAY_5] => 17
[TEMPERATURE_WEDNESDAY_6] => 17
[TEMPERATURE_WEDNESDAY_7] => 17
[TEMPERATURE_WEDNESDAY_8] => 17
[TEMPERATURE_WEDNESDAY_9] => 17
[VALVE_ERROR_RUN_POSITION] => 0
[VALVE_MAXIMUM_POSITION] => 10
[VALVE_OFFSET] => 0
        [VALUES] => Array
                [CENTRAL_ADDRESS_SPOOFED] => 0
                [CONFIG_PENDING] =>
                [INHIBIT] =>
                [LOWBAT] =>
                [RSSI_DEVICE] => -48
                [RSSI_PEER] => 0
                [STICKY_UNREACH] => 1
                [UNREACH] =>
                [UPDATE_PENDING] =>
        [DESC-MASTER] =>
        [DESC-VALUES] => Array
                        [CONTROL] => NONE
                        [DEFAULT] => 0
                        [FLAGS] => 24
                        [ID] => CENTRAL_ADDRESS_SPOOFED
                        [MAX] => 1
                        [MIN] => 0
                        [OPERATIONS] => 7
                        [TAB_ORDER] => 9
                        [TYPE] => ENUM
                        [UNIT] =>
                                [0] => UNSET
                        [FLAGS] => 8
                        [ID] => CONFIG_PENDING
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 5
                        [TAB_ORDER] => 2
                        [TYPE] => BOOL
                        [UNIT] =>
                        [FLAGS] => 8
                        [ID] => DEVICE_IN_BOOTLOADER
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 5
                        [TAB_ORDER] => 7
                        [TYPE] => BOOL
                        [UNIT] =>
                [INHIBIT] => Array
                        [CONTROL] => NONE
                        [FLAGS] => 1
                        [ID] => INHIBIT
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 7
                        [TAB_ORDER] => 6
                        [TYPE] => BOOL
                        [UNIT] =>
                [LOWBAT] => Array
                        [FLAGS] => 8
                        [ID] => LOWBAT
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 5
                        [TAB_ORDER] => 3
                        [TYPE] => BOOL
                        [UNIT] =>
                        [FLAGS] => 1
                        [ID] => RSSI_DEVICE
                        [MAX] => 2147483647
                        [OPERATIONS] => 5
                        [TAB_ORDER] => 4
                        [TYPE] => INTEGER
                        [UNIT] =>
                        [FLAGS] => 1
                        [ID] => RSSI_PEER
                        [MAX] => 2147483647
                        [OPERATIONS] => 5
                        [TAB_ORDER] => 5
                        [TYPE] => INTEGER
                        [UNIT] =>
                        [FLAGS] => 24
                        [ID] => STICKY_UNREACH
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 7
                        [TAB_ORDER] => 1
                        [TYPE] => BOOL
                        [UNIT] =>
                [UNREACH] => Array
                        [FLAGS] => 8
                        [ID] => UNREACH
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 5
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
                        [FLAGS] => 8
                        [ID] => UPDATE_PENDING
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 5
                        [TAB_ORDER] => 8
                        [TYPE] => BOOL
                        [UNIT] =>
[1] => Array
        [MASTER] => Array
                [AES_ACTIVE] =>
        [VALUES] => Array
        [DESC-MASTER] => Array
                [AES_ACTIVE] => Array
                        [DEFAULT] =>
                        [FLAGS] => 2
                        [ID] => AES_ACTIVE
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 3
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
[2] => Array
        [MASTER] => Array
                [AES_ACTIVE] =>
        [VALUES] => Array
                        [DEFAULT] =>
                        [FLAGS] => 2
                        [ID] => AES_ACTIVE
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 3
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
[3] => Array
        [MASTER] => Array
                [AES_ACTIVE] =>
        [VALUES] => Array
                [WINDOW_STATE] =>
                        [DEFAULT] =>
                        [FLAGS] => 2
                        [ID] => AES_ACTIVE
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 3
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
                        [CONTROL] => SWITCH.STATE
                        [DEFAULT] =>
                        [FLAGS] => 1
                        [ID] => WINDOW_STATE
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 3
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
[4] => Array
        [MASTER] => Array
                [AES_ACTIVE] =>
        [VALUES] => Array
                [ACTUAL_TEMPERATURE] => 25.6
                [BATTERY_STATE] => 2.6
                [BOOST_STATE] => 37
                [CONTROL_MODE] => 1
                [FAULT_REPORTING] => 0
                [PARTY_START_DAY] => 3
                [PARTY_START_MONTH] => 1
                [PARTY_START_TIME] => 1110
                [PARTY_START_YEAR] => 16
                [PARTY_STOP_DAY] => 30
                [PARTY_STOP_MONTH] => 1
                [PARTY_STOP_TIME] => 210
                [PARTY_STOP_YEAR] => 93
                [PARTY_TEMPERATURE] => 30.5
                [SET_TEMPERATURE] => 30.5
                [VALVE_STATE] => 10
                        [DEFAULT] =>
                        [FLAGS] => 2
                        [ID] => AES_ACTIVE
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 3
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
        [DESC-VALUES] =>
[5] => Array
        [MASTER] => Array
                [AES_ACTIVE] =>
        [VALUES] => Array
                        [DEFAULT] =>
                        [FLAGS] => 2
                        [ID] => AES_ACTIVE
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 3
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
[6] => Array
        [MASTER] => Array
                [AES_ACTIVE] =>
        [VALUES] => Array
                        [DEFAULT] =>
                        [FLAGS] => 2
                        [ID] => AES_ACTIVE
                        [MAX] => 1
                        [MIN] =>
                        [OPERATIONS] => 3
                        [TAB_ORDER] => 0
                        [TYPE] => BOOL
                        [UNIT] =>
[/code]
Hey Quitte,
die Parameter für den PI-Regler sind leider nicht dokumentiert. Vielleicht findest etwas, wenn du die Parameter googlest?
Christian und ich vermuten, dass es sich bei den EXTERN-Parametern um die Einstellungen handelt, welche verwendet werden, wenn der Stellantrieb an einen Wandthermostaten angelernt sind. Die INTERN-Parameter sind dann entsprechend vermutlich die Einstellungen ohne Wandthermostat.
P_START_VALUE sieht aus wie die Ventilstellung nach einem Geräteneustart in Prozent.
Eine Vergrößerung von P_VALUE_* (Empfindlichkeit, üblicherweise K_P) sorgt dafür, dass die Zieltemperatur schneller erreicht wird, sorgt aber unter Umständen für ein Überschwingen oder sogar eine Instabilität (also dauerhaftes Schwingen) des Regelkreises. Den Wert kannst du entsprechend zunächst groß ansetzen und bei Überschwingen sukzessive wieder verkleinern.
I_VALUE_* (Zeitkonstante) sorgt dafür, dass die über den P-Anteil grob aber schnell eingestellte Temperatur nach einer Zeitkonstanten genau getroffen wird. Je nach Implementierung (T_N bzw. T_I oder K_P/T_N bzw. K_P/T_I?) bewirkt eine Vergrößerug des Wertes ein schnelleres oder langsameres Einpendeln auf die gewünschte Zieltemperatur. Bei zu schnellem Einpendeln kann es ebenfalls zu Instabilität kommen. Da die Grenzen aber recht eng gewählt sind, kannst du vermutlich nicht viel falsch machen. Unter Umständen ist es möglich, die Grenzen in der XML-Datei zu Vergrößern, wobei ich nicht weiß, ob die Firmware des Stellantriebes Werte außerhalb des standardmäßig definierten Wertebereichs akzeptiert.
Letztlich bleibt dir also nur Probieren. Falls du Lust hast, mit den Werten rumzuspielen, poste hier auf jeden Fall deine Ergebnisse!
Sathya und Christian
Danke, das hilft mir weiter!
A post was split to a new topic: HM-Thermostat Schwingen der Temperatur verhinden
