root@homegearpi-93-dc-7f:/home/pi# dpkg -l | grep homegear
ii homegear 0.8.0-2835 armhf Interface program to your smart home devices
ii homegear-adminui 0.1.0-191 all Provides an administrative user interface for Homegear.
ii homegear-beckhoff 0.8.0-2835 armhf Beckhoff module for Homegear
rc homegear-ccu 0.7.40-2948 armhf CCU module for Homegear
ii homegear-enocean 0.8.0-2835 armhf EnOcean module for Homegear
rc homegear-homematicbidcos 0.7.40-2948 armhf HomeMatic BidCoS module for Homegear
rc homegear-homematicwired 0.7.40-2948 armhf HomeMatic BidCoS module for Homegear
rc homegear-insteon 0.7.40-2948 armhf HomeMatic BidCoS module for Homegear
rc homegear-intertechno 0.7.40-2948 armhf Intertechno module for Homegear
rc homegear-ipcam 0.7.40-2948 armhf IPCam module for Homegear
ii homegear-knx 0.8.0-2835 armhf KNX module for Homegear
rc homegear-kodi 0.7.40-2948 armhf Kodi module for Homegear
ii homegear-licensing 0.8.0-2835 armhf Default licensing module for Homegear
ii homegear-management 0.8.0-2835 armhf Management service for Homegear
rc homegear-max 0.7.40-2948 armhf HomeMatic BidCoS module for Homegear
rc homegear-nanoleaf 0.7.40-2948 armhf Nanoleaf module for Homegear
ii homegear-nodes-core 0.8.0-2835 armhf Core nodes for Homegear's Node-BLUE
ii homegear-nodes-extra 0.8.0-2835 armhf Extra nodes for Homegear's Node-BLUE
rc homegear-philipshue 0.7.40-2948 armhf Philips Hue module for Homegear
rc homegear-sonos 0.7.40-2948 armhf HomeMatic BidCoS module for Homegear
ii homegear-ui 0.1.0-120 all Provides an user interface for Homegear.
ii homegear-webssh 0.8.0-2835 armhf Management service for Homegear
ii homegear-zigbee 0.8.0-2835 armhf Zigbee module for Homegear
ii homegear-zwave 0.8.0-2835 armhf Z-Wave module for Homegear
ii libhomegear-base 0.8.0-2835 armhf Base library for Homegear
ii libhomegear-ipc 0.1.2-34 armhf IPC library for Homegear
ii libhomegear-node 0.1.7-43 armhf Node library for Homegear
ii python3-homegear 1.0.14-1 armhf Python module for Homegear
Du hast einen Mix aus 0.7 und 0.8. Du wirst immer in irgendwelche Probleme laufen, die keiner nachvollziehen kann. Bitte bring dein System auf einen einheitlichen Stand, ob 0.7 oder 0.8 ist egal. Einfacher wird allerdings 0.8 sein, da deine Datenbank wahrscheinlich schon auf dem letzten Stand ist.
Naja, einfach die Pakete mit 0.7 deinstallieren, danach die benötigten Pakete mit 0.8 wieder installieren. Deinstallation geht z.B. mit apt oder dpkg, Installation mit dem Installer vom nightly.
The management service tag needed for the configuration could not be found in the network settings file
The management service tag needed for the configuration could not be found in the DNS settings file.
@pmayer da fehlen die Tags in den Dateien. Die sollten so aussehen:
/etc/network/interfaces
# This file describes the network interfaces available on your system
# and how to activate them. For more information, see interfaces(5).
source /etc/network/interfaces.d/*
# The loopback network interface
auto lo
iface lo inet loopback
# The primary network interface
allow-hotplug eth0
#{{{ homegear-management
iface eth0 inet dhcp
#}}} homegear-management
/etc/resolvconf/resolv.conf.d/head
# Dynamic resolv.conf(5) file for glibc resolver(3) generated by resolvconf(8)
# DO NOT EDIT THIS FILE BY HAND -- YOUR CHANGES WILL BE OVERWRITTEN
