Mal ne blöde Frage… Manche coordinator sind mit Z-Stack version 3.0.x und manche mit 3.x kompatibel… wo ist da jetzt der Unterschied?
Meines Wissens nach handelt es sich bei beiden um 3er Z-Stacks, aber die Geräte wo 3.0.x drauf läuft brauchen andere Firmware als die für 3.x.
Siehe:
@Adrian, maybe you can clarify on the differences between 3.0.x and 3.x?
As far as I know, for cc2538 only 3.0.x zstack version is provided. The 3.x is provided for some other chips.
Just as an info, IAR embedded workbench is ‘supported’ for 3.0.x, but I managed to compile the sources with Code Composer Studio as well. It was not exactly easy, but I could do it.
Sincerely,
Adrian Roman
Hey @pmayer
Leider bekomme ich das Modul nicht zum laufen.
@Adrian ist auch ratlos.
Backup homegaer.zip (2,0 KB)
Das wären meine Einstellungen
Und so ist es montiert
11/14/20 18:56:09.743 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE0121000121
11/14/20 18:56:25.823 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:56:39.773 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 18:56:54.803 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00270027
11/14/20 18:56:57.062 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:57:10.193 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 18:57:28.223 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE0121000121
11/14/20 18:57:28.311 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:57:40.413 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE0525360200003C0028
11/14/20 18:57:41.414 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:57:58.253 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 18:57:58.255 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:57:58.255 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 18:57:58.255 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 18:57:59.552 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:58:13.283 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00270027
11/14/20 18:58:13.644 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:58:13.645 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 18:58:13.645 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 18:58:13.645 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:58:13.646 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 1
11/14/20 18:58:13.646 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 18:58:28.673 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 18:58:30.792 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:58:31.675 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:58:31.675 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 18:58:31.676 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 18:58:46.703 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE0121000121
11/14/20 18:59:01.705 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:59:01.705 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 18:59:01.706 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 18:59:02.029 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:59:16.733 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 18:59:16.735 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:59:16.735 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 18:59:16.735 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 18:59:31.763 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00270027
11/14/20 18:59:32.124 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:59:32.124 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 18:59:32.125 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 1
11/14/20 18:59:32.125 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 18:59:33.266 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 18:59:47.153 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 18:59:50.155 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 18:59:50.155 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 18:59:50.156 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:00:04.506 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 19:00:05.183 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE0121000121
11/14/20 19:00:20.185 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:00:20.185 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:00:20.186 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:00:35.213 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 19:00:35.215 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:00:35.215 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:00:35.215 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:00:35.745 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 19:00:50.243 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00270027
11/14/20 19:00:50.604 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:00:50.604 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:00:50.605 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 1
11/14/20 19:00:50.605 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:01:05.633 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 19:01:06.978 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 19:01:08.635 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:01:08.635 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:01:08.636 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:01:23.663 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE0121000121
11/14/20 19:01:38.224 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 19:01:38.665 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:01:38.665 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:01:38.666 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:01:53.693 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 19:01:53.695 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:01:53.695 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:01:53.695 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:02:08.723 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00270027
11/14/20 19:02:08.817 Module Zigbee: Zigbee serial module "cc2538": Warning: Connection to device closed. Trying to reconnect...
11/14/20 19:02:09.462 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 19:02:14.174 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:02:14.174 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:02:14.175 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 1
11/14/20 19:02:14.175 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:02:29.203 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 19:02:32.205 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:02:32.205 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:02:32.206 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:02:40.703 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 19:02:47.233 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE0121000121
11/14/20 19:03:01.961 Info: SIGHUP received. Reloading...
11/14/20 19:03:01.961 Info: Backing up database...
11/14/20 19:03:01.961 Closing database...
11/14/20 19:03:01.962 Debug: Can't execute "COMMIT": cannot commit - no transaction is active
11/14/20 19:03:01.996 Info: Backing up database...
11/14/20 19:03:02.094 Reloading Node-BLUE server...
11/14/20 19:03:02.094 Reloading script engine server...
11/14/20 19:03:02.095 Info: Reload complete.
11/14/20 19:03:02.235 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:03:02.235 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:03:02.236 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:03:11.941 Module Zigbee: Zigbee serial module "cc2538": Warning: tryToSend: !!!Not!!! sending packet, because init is not complete.
11/14/20 19:03:17.263 Module Zigbee: Zigbee serial module "cc2538": Error: No response received to packet: FE00210120
11/14/20 19:03:17.264 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 4
11/14/20 19:03:17.265 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 10
11/14/20 19:03:17.265 Module Zigbee: Zigbee serial module "cc2538": Warning: Unknown start byte received: 0
11/14/20 19:03:29.932 Info: Client with IP ::ffff:192.168.2.34 is calling "init".
Das bekomme ich als Meldung
Danke dir für deine Ideen schon mal
FElix
Hey @dr_snuggles,
habe nur kurz drüber geguckt, aber in der config.txt
fehlt enable_uart=1
. Schau am besten nochmal in die Anleitung, was Pi-seitig gemacht werden muss um die serielle Schnittstelle am GPIO nutzen zu können.
Falls an dem Modul was kaputt sein sollte, tausche ich es natürlich aus
The module seems to receive the packet (hex): 04 10 01 00. This is not a valid zigbee packet, they must start with FE.
I don’t know where that comes from, the first value from it seems to be the packet length.
Hey @pmayer
Wenn du die config auf machst steht es in der 4 letzten Zeile
Enable_uart=1
Und in der Zeile darüber steht das mit dem Bluetooth
Das sollte doch passen?
Hab gestern nochmal meine neuen Pi 4 gestartet und nur das Zigbee Modul eingebunden. Es ist mit den gleichen Fehlern ausgestiegen.
Ich glaube aber trotzdem das irgendwie ein Parameter nicht passt, irgendwie komme ich aber nicht drauf
Felix
Please take a look also on:
The raspberry pi section.
finally I think it partly works
I could create a peer to my device and didn’t have any fault messages.
The issue was between the lines. The doc says check for ttyAMA0 and serial0 in the cmdline.txt
Somehow I had a ttyS0 in this file. I deleted this and it starts working.
What was also wrong in the Doc the tool Raspi-Config has a fault and will disable ttyAMA0 after using it to reactive the Serial port on the uart. You shouldn’t do this with the tool I found some forums where they say it’s abug in code of the raspberry.
After I reactivate this and then manual remove the serial0 line and the ttyS0 from the cmdline it starts to work.
Now the issue is how to communicate with my osram plug in.
Anybody of you both knew which of the 11 channels i have to manupilate to switch this on and off.
Thanks again.
Felix
Great news!
Try:
sudo homgear -r
ls
fs <famliy id of zigbee>
ls
ps <peer id of osram plug>
config print
Otherwhise have a look in the admin interface or try the “variable in”-node in node blue and select the desired peer there.
Yes this gives me about 13 channels with all over 50 parameters but as I tested non of them will switch on or off the plug.
The plug you use is it working fully? I then will try this if you could just send me the model name of it!
Felix
I don’t use one of the Osram Plugs, only have an innr for testing.
Check node-blue. Switching should be easy with the variable-out-node, as long as the device is supported. Maybe @Adrian can clarify on this.
Please supply the output of the config print
If there is no device xml file, there should be there some items with ONOFF. The simple ONOFF is read only and can be used to read the state of the device. There should be also some action items, with TOGGLE and ON and OFF, writing to those should change the state of the device.
Family 26 - peer 1> config print
MASTER
Channel: 9
[SCENES.VIEW_SCENE_RESPONSE.TRANSITION_TIME]: 00 00
[SCENES.VIEW_SCENE.GROUP_ID]: 00 00
[SCENES.STORE_SCENE_RESPONSE.STATUS]: 00
[SCENES.REMOVE_SCENE_RESPONSE.STATUS]: 00
[SCENES.VIEW_SCENE_RESPONSE.EXTENSION_FIELD_SETS]: 00
[SCENES.VIEW_SCENE.SCENE_ID]: 00
[SCENES.SCENE_COUNT]: 00
[SCENES.REMOVE_ALL_SCENES_RESPONSE.STATUS]: 00
[SCENES.REMOVE_SCENE.GROUP_ID]: 00 00
[SCENES.ADD_SCENE_RESPONSE.STATUS]: 00
[SCENES.VIEW_SCENE_RESPONSE.SCENE_NAME]: 00
[SCENES.ADD_SCENE.TRANSITION_TIME]: 00 00
[SCENES.RECALL_SCENE.SCENE_ID]: 00
[SCENES.VIEW_SCENE_RESPONSE.STATUS]: 00
[SCENES.ADD_SCENE.SCENE_NAME]: 00
[SCENES.ADD_SCENE.GROUP_ID]: 00 00
[SCENES.STORE_SCENE.SCENE_ID]: 00
[SCENES.ADD_SCENE.EXTENSION_FIELD_SETS]: 00
[SCENES.CURRENT_GROUP]: 00 00
[SCENES.GET_SCENE_MEMBERSHIP_RESPONSE.STATUS]: 00
[SCENES.CURRENT_SCENE]: 00
[SCENES.GET_SCENE_MEMBERSHIP.GROUP_ID]: 00 00
[SCENES.REMOVE_ALL_SCENES.GROUP_ID]: 00 00
[SCENES.GET_SCENE_MEMBERSHIP_RESPONSE.CAPACITY]: 00
[SCENES.STORE_SCENE.GROUP_ID]: 00 00
[SCENES.GET_SCENE_MEMBERSHIP_RESPONSE.SCENE_LIST]: 00
[SCENES.SCENE_VALID]: 00
[SCENES.ADD_SCENE.SCENE_ID]: 00
[SCENES.NAME_SUPPORT]: 00
[SCENES.NAME_SUPPORT__SUPPORTED]: 00
[SCENES.REMOVE_SCENE.SCENE_ID]: 00
[SCENES.RECALL_SCENE.GROUP_ID]: 00 00
Channel: 12
[ONOFF_REPORTING_CONFIG.ONOFF.MIN_REPORTING_INTERVAL]: 00 00
[ONOFF_REPORTING_CONFIG.ONOFF.MAX_REPORTING_INTERVAL]: 02 58
Channel: 5
[IDENTIFY.IDENTIFY_QUERY_RESPONSE.IDENTIFY_TIME]: 00 00
[IDENTIFY.IDENTIFY.IDENTIFY_TIME]: 00 00
[IDENTIFY.IDENTIFY_TIME]: 00 00
[IDENTIFY.IDENTIFY_QUERY.ACTION]: 00
Channel: 3
[BASIC.ZCL_VERSION]: 01
[BASIC.SW_BUILD_ID]: 56 31 2e 30 34 2e 31 32
[BASIC.MODEL_IDENTIFIER]: 50 6c 75 67 20 30 31
[BASIC.APPLICATION_VERSION]: 0c
[BASIC.MANUFACTURER_NAME]: 4f 53 52 41 4d
[BASIC.STACK_VERSION]: 02
[BASIC.HW_VERSION]: 01
[BASIC.POWER_SOURCE__EMERGENCY_MAINS_AND_TRANSFER_SWITCH]: 00
[BASIC.POWER_SOURCE__UNKNOWN]: 01
[BASIC.DATE_CODE]: 32 30 31 34 30 33 33 31 44 45 4f 53 2a 2a 2a 2a
[BASIC.POWER_SOURCE]: 01
[BASIC.POWER_SOURCE__BATTERY]: 00
[BASIC.POWER_SOURCE__DC_SOURCE]: 00
[BASIC.POWER_SOURCE__MAINS_SINGLE_PHASE]: 00
[BASIC.DEVICE_ENABLED]: 01
[BASIC.POWER_SOURCE__EMERGENCY_MAINS_CONSTANTLY_POWERED]: 00
[BASIC.POWER_SOURCE__MAINS_3_PHASE]: 00
[BASIC.POWER_SOURCE__SECONDARY_POWER_SOURCE]: 00
Channel: 7
[GROUPS.VIEW_GROUP.GROUP_ID]: 00 00
[GROUPS.REMOVE_GROUP_RESPONSE.STATUS]: 00
[GROUPS.REMOVE_GROUP.GROUP_ID]: 00 00
[GROUPS.NAME_SUPPORT__SUPPORTED]: 00
[GROUPS.GET_GROUP_MEMBERSHIP_RESPONSE.CAPACITY]: 00
[GROUPS.REMOVE_ALL_GROUPS.ACTION]: 00
[GROUPS.GET_GROUP_MEMBERSHIP.GROUP_LIST]: 00
[GROUPS.VIEW_GROUP_RESPONSE.STATUS]: 00
[GROUPS.ADD_GROUP.GROUP_NAME]: 00
[GROUPS.ADD_GROUP.GROUP_ID]: 00 00
[GROUPS.ADD_GROUP_IF_IDENTIFYING.GROUP_NAME]: 00
[GROUPS.ADD_GROUP_RESPONSE.STATUS]: 00
[GROUPS.VIEW_GROUP_RESPONSE.GROUP_NAME]: 00
[GROUPS.NAME_SUPPORT]: 00
[GROUPS.ADD_GROUP_IF_IDENTIFYING.GROUP_ID]: 00 00
[GROUPS.GET_GROUP_MEMBERSHIP.GROUP_COUNT]: 00
Channel: 0
[ROUTER]: 01
[MAINS_POWERED]: 01
[END_POINT]: 03 00
[SHORT_ADDR]: f0 31
[LISTENING]: 01
VALUES
Channel: 13
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__REACTIVE_MEASUREMENT]: 00
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__PHASE_C_MEASUREMENT]: 00
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__PHASE_A_MEASUREMENT]: 01
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE]: 00 00 00 08
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__PHASE_B_MEASUREMENT]: 00
[ELECTRICAL_MEASUREMENT.ACTIVE_POWER]: 6d 60
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__ACTIVE_MEASUREMENT]: 0 0
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__POWER_QUALITY_MEASUREM ENT]: 00
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__APPARENT_MEASUREMENT]: 00
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__HARMONICS_MEASUREMENT] : 00
[ELECTRICAL_MEASUREMENT.MEASUREMENT_TYPE__DC_MEASUREMENT]: 00
Channel: 11
[ONOFF.TOGGLE.ACTION]: ff
[ONOFF.OFF.ACTION]: ff
[ONOFF.ON.ACTION]: 00
[ONOFF.ON_TIME]: 00 00
[ONOFF.GLOBAL_SCENE_CONTROL]: 01
[ONOFF.OFF_WAIT_TIME]: 00 00
[ONOFF.ONOFF]: 00
Channel: 15
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.VERSION]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMA TION_RESP__TOUCHLINK_INITIATOR]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMA TION_RESP__ADDRESS_ASSIGNMENT]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.RESPONSE_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.NUMBER_OF_SUBDEVI CES]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.NETWORK_UPDATE_ID ]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.LOGICAL_CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.KEY_BITMASK]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.GROUP_IDENTIFIER_ COUNT]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.ZIGBEE_INFORMATION__LOGICA L_TYPE]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.ZIGBEE_INFORMATION__RX_ON_ WHEN_IDLE]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ_ _FACTORY_NEW]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.NETWORK _UPDATE_ID]: 00
[TOUCHLINK_COMMISSIONING.IDENTIFY_REQUEST.INTER_PAN_TRANSACTION_ ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ_ _ADDRESS_ASSIGNMENT]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.NETWORK _ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.GROUP_I DENTIFIERS_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_NE TWORK_ADDRESS_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_GR OUP_IDENTIFIER_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.EXTENDE D_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.ZIGBEE_INFORMATION]: 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.PROFILE_ID]: 00 00
[TOUCHLINK_COMMISSIONING.RESET_TO_FACTORY_NEW_REQUEST.INTER_PAN_ TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.ENCRYPT ED_NETWORK_KEY]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.RSSI_CORRECTION]: 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST_RESPONSE. GROUP_INFORMATION_RECORDS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_NETWORK_ADDR ESS_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST_RESPONSE. COUNT]: 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST.START_INDEX] : 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.LOGICAL _CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.EXTENDED_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_GROUP_ IDENTIFIER_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.NETWORK_UPDATE_I D]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.PROFILE_ID]: 00 0 0
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST_RESPONSE.SIZ E]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST_RESPONS E.STATUS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.INTER_PAN_TRANSA CTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_NETWOR K_ADDRESS_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.GROUP_IDENT IFIERS_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST_RESPONSE.NUM BER_OF_SUBDEVICES]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.NETWORK_ADDRESS] : 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOTAL_GROUP_IDENT IFIERS]: 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.DEVICE_ID]: 00 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.IEEE_ADDRESS]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMA TION_RESP__TOUCHLINK_PRIORITY_REQUEST]: 00
[TOUCHLINK_COMMISSIONING.IDENTIFY_REQUEST.IDENTIFY_DURATION]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.NETWORK_UPD ATE_ID]: 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST_RESPONSE.DEV ICE_INFORMATION_RECORDS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_GR OUP_IDENTIFIER_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.INTER_P AN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST.START_INDEX]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.ENDPOINT_ID]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST_RESPONSE.STATUS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_NE TWORK_ADDRESS_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST.INTER_PAN_TR ANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST_RESPONSE.COUN T]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_NETWORK_ADDR ESS_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.VERSION]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.KEY_IND EX]: 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST_RESPONSE.ENDP OINT_INFORMATION_RECORDS]: 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.ENDPOINT_ID]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.PAN_ID] : 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.KEY_INDEX]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_GROUP_ IDENTIFIER_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMA TION_RESP]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.GROUP_I DENTIFIERS_END]: 00 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST_RESPONSE.TOTA L]: 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST.START_IND EX]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ_ _LINK_INITIATOR]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.ENCRYPTED_N ETWORK_KEY]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_NETWOR K_ADDRESS_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.GROUP_IDENT IFIERS_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_GROUP_IDENTI FIER_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.INTER_PAN_T RANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST_RESPONSE.ST ATUS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.KEY_INDEX]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.EXTENDED_PA N_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.LOGICAL_CHA NNEL]: 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST_RESPONSE. TOTAL]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.NETWORK_ADD RESS]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.ENCRYPTED_NETWORK _KEY]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.GROUP_IDENTIFIERS _BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.EXTENDED_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.EXTENDED_PAN_ID] : 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.GROUP_IDENTIFIERS _END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.INITIATOR_IEEE_AD DRESS]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.INITIATOR_NETWORK _ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.INTER_PAN_TRANSAC TION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.LOGICAL_CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.DEVICE_ID]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST_RESPONSE.NETWORK_ UPDATE_ID]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_GROUP_IDENTI FIER_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.LOGICAL_CHANNEL] : 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMA TION_RESP__FACTORY_NEW]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ] : 00
Channel: 1
[ONOFF]: 00
[ACTIVEPOWER]: 6d 60
Channel: 0
[UNREACH]: 00
[STICKY_UNREACH]: 00
[CONFIG_PENDING]: 00
[LAST_PACKET_RECEIVED]: 5f bd 4e 7f
That is the output for the config print of the osram plug.
Felix
I see that it has ONOFF in channel 1, this means it has a device xml file. ONOFF there is both readable and writable.
Also ONOFF.TOGGLE.ACTION can be used to toggle the value by writing into it.
But it looks like you have some other issue with the device, some communication one. Hopefully we’ll figure it out.
Hallo @pmayer
ich habe eine der GPIO-Platinen von dir über codM gekauft, die Erstinbetriebnahme gestaltete sich ziemlich verzwickt, (Pi4b mit USB3 SSD) gelang mir aber irgendwann.
Betrieben wird das in einer iobrokerinstallation mit zigbee-modul, der Grund das ich diese Platine einsetzen möchte waren die vielen möglichen Geräte und ganz wichtig, der Einbau" in das Raspi-Gehäuse und damit weniger strippen im Schaltschrank (Antennenkabel als einziges ist ja notwendig)
Antenne ist eine 3.5dB (hab ich zusammen mit der Platine gekauft (Lieferscheinnummer: 20439)
Nach dem erfolgreichen anlernen einiger Geräte funktionierten diese im Testaufbau, nach einem Umzug des Pi4 hat der cc2538 aber keinen Kontakt mehr zu den vorher angelernten Geräten.
ich habe den Schreibtischaufbau mit einem Osram-Plug+, Xiaomi Fenstersensor, Tradfri ColorE27 und einem TradfriDimmer aufgebaut
die Geräte sind dann erst nach einem erneuten Pairing ansprechbar.
Ich möchte nun aber nicht nach jedem abschalten des raspi, durch mein ganzes Haus laufen und alle 50 ZB geräte erneut pairen, ist das Problem bekannt?, ein abstecken des Sticks geht ectl. bei USB, bei der GPIO Platine aber nicht. wie kann ich nun dafür sorgen das nach einem “Kaltstart” des Raspi alles wieder funktioniert?, hab das Modul deswegen erst mal wieder in den Testaufbau gesteckt und im Schaltschrank wieder einen CC2531 (per USB-Verlängerung) in Betrieb.
ich hab das ganze nochmal mit “zigbee2mqtt” ohne iobroker nachgebildet, sobald der RaspBerry stromlos gemacht wurde, (nach shutdown now) sind alle zuvor angelernten Geräte nicht mehr ansprechbar. auch hier nur wiederbelebbar nach erneutem Pairing.
mit freundlichen Grüssen
Sag mal @iobroker_biicii.de, du hast mir diese Nachricht jetzt auf 4 (VIER!) Wegen geschickt. Io.Broker-Forumsnachricht, io.broker-Chat, E-Mail und hier… irgendwann ist mal gut.
Ich antworte dir morgen per E-Mail, zu meinen normalen Arbeitszeiten.
Zigbee und USB3 hat Konfliktpotenzial, schonmal versucht die SSD mittels langem Kabel vom RPi wegzubewegen?
Habe das gleiche Problem.
Wenn du auf GitHub schaust gibt es das wohl häufiger und ist wohl ein Firmware Problem.
Ich such mal den link.
Edit gefunden
Meintest du den?
Ich habe leider momentan 2-3 Leute, die das Problem haben und ich habe noch keine wirkliche Lösung. Das Einzige wo ich gerade froh drum bin, dass die Leute die Firmware selbst ändern können.
Hatte das mal hier dokumentiert:
Ich schaue mir das morgen mal genauer an. Aktuell ist mein Wissensstand aber auch, dass es an der Firmware liegt. Freue mich, wenn ihr mehr wisst als ich.
Alternativ kann man auch mal die JetHome-Firmware draufmachen:
