Hallo und Danke ertmal für diese tolle Software !
Habe folgende Anfängerfragen/Problme
im error log sehe ich: Could not set thread priority. The executing user does not have enough privileges. Please run “ulimit -r 100” before executing Homegear.
hab das raspi image mit openhab installiert, wo muss ich da was setzten damit diese fehlermeldung nicht kommt? -
ebenfalls erfolgreich habe ich mqtt konfiguriert, im log stehen aber ab und an solche fehler:
05/29/16 17:32:48.629 MQTT Client: Error: No response received to packet: 33270020686F6D65676561722F312F6576656E742F312F322F424F4F53545F535441544514255B305D
05/29/16 17:33:10.620 MQTT Client: Error: No response received to packet: 33270020686F6D65676561722F312F6576656E742F312F322F424F4F53545F535441544514665B305D
05/29/16 17:33:21.773 MQTT Client: Error: No response received to packet: 33290020686F6D65676561722F312F6576656E742F312F302F525353495F44455649434514945B2D33335D
05/29/16 17:33:22.093 MQTT Client: Error: No response received to packet: C000
05/29/16 17:33:22.093 MQTT Client: Error: No PINGRESP received.
05/29/16 17:33:49.930 MQTT Client: Error in file MQTT/Mqtt.cpp line 601 in function void Mqtt::processPublish(std::vector&): No closing ‘}’ found. Payload was: 7B226D6574686F64223A2273657456616C7565222C22706172616D73223A5B312C322C225345545F54454D5045524154555245222C32355D2C226964223A36303435
05/29/16 17:33:53.016 MQTT Client: Error: No response received to packet: 33290020686F6D65676561722F312F6576656E742F312F302F525353495F44455649434514CF5B2D33395D
05/29/16 17:35:18.673 MQTT Client: Error: No response received to packet: 33290020686F6D65676561722F312F6576656E742F312F302F525353495F444556494345152B5B2D33355D
05/29/16 17:37:52.917 MQTT Client: Error in file MQTT/Mqtt.cpp line 601 in function void Mqtt::processPublish(std::vector&): No closing ‘}’ found. Payload was: 7B226D6574686F64223A2273657456616C7565222C22706172616D73223A5B312C322C225345545F54454D5045524154555245222C31372E355D2C226964223A31343531
sollten die mir sorgen machen?
- ebenfalls ab und an kommen folgende fehler vor:
05/31/16 18:46:00.467 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: AES handshake failed for packet: 0C43A6413E5675FD44D7013BC8E6
05/31/16 18:46:15.443 Module HomeMatic BidCoS: HM-MOD-RPI-PCB “My-HM-MOD-RPI-PCB”: Warning: AES handshake failed for packet: 0C46A6413E5675FD44D7013DC8E4
Danke und Gruss
Andi
