I was able to pair that motion sensor, but I cannot find a trigger. Do I need a special .xml-file?
Could you please show a config print for the device?
MASTER
Channel: 5
[IDENTIFY.IDENTIFY_QUERY_RESPONSE.IDENTIFY_TIME]: 00 00
[IDENTIFY.IDENTIFY.IDENTIFY_TIME]: 00 00
[IDENTIFY.IDENTIFY_TIME]: 00 00
[IDENTIFY.IDENTIFY_QUERY.ACTION]: 00
Channel: 4
[POWER_CONFIGURATION_REPORTING_CONFIG.BATTERY_PERCENTAGE_REMAINING.REPORTABLE_CHANGE]: 01
[POWER_CONFIGURATION_REPORTING_CONFIG.BATTERY_PERCENTAGE_REMAINING.MAX_REPORTING_INTERVAL]: 0e 10
[POWER_CONFIGURATION_REPORTING_CONFIG.BATTERY_PERCENTAGE_REMAINING.MIN_REPORTING_INTERVAL]: 00 00
Channel: 3
[POWER_CONFIGURATION.BATTERY_VOLTAGE]: 00
[POWER_CONFIGURATION.BATTERY_PERCENTAGE_REMAINING]: 64
Channel: 1
[BASIC.ZCL_VERSION]: 03
[BASIC.MODEL_IDENTIFIER]: 54 52 41 44 46 52 49 20 6d 6f 74 69 6f 6e 20 73 65 6e 73 6f 72
[BASIC.APPLICATION_VERSION]: 20
[BASIC.MANUFACTURER_NAME]: 49 4b 45 41 20 6f 66 20 53 77 65 64 65 6e
[BASIC.STACK_VERSION]: 62
[BASIC.POWER_SOURCE]: 03
[BASIC.HW_VERSION]: 01
[BASIC.POWER_SOURCE__EMERGENCY_MAINS_AND_TRANSFER_SWITCH]: 00
[BASIC.POWER_SOURCE__UNKNOWN]: 01
[BASIC.DATE_CODE]: 32 30 31 39 30 33 30 38
[BASIC.POWER_SOURCE__BATTERY]: 00
[BASIC.SW_BUILD_ID]: 32 2e 30 2e 30 32 32
[BASIC.POWER_SOURCE__DC_SOURCE]: 00
[BASIC.POWER_SOURCE__MAINS_SINGLE_PHASE]: 01
[BASIC.POWER_SOURCE__EMERGENCY_MAINS_CONSTANTLY_POWERED]: 00
[BASIC.POWER_SOURCE__MAINS_3_PHASE]: 00
[BASIC.POWER_SOURCE__SECONDARY_POWER_SOURCE]: 00
Channel: 0
[ROUTER]: 00
[MAINS_POWERED]: 00
[END_POINT]: 01 00
[SHORT_ADDR]: a4 4a
[LISTENING]: 00
VALUES
Channel: 11
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.VERSION]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMATION_RESP__TOUCHLINK_INITIATOR]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMATION_RESP__ADDRESS_ASSIGNMENT]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.RESPONSE_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.NUMBER_OF_SUBDEVICES]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.NETWORK_UPDATE_ID]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.LOGICAL_CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.KEY_BITMASK]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.GROUP_IDENTIFIER_COUNT]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.ZIGBEE_INFORMATION__LOGICAL_TYPE]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.ZIGBEE_INFORMATION__RX_ON_WHEN_IDLE]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ__FACTORY_NEW]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.NETWORK_UPDATE_ID]: 00
[TOUCHLINK_COMMISSIONING.IDENTIFY_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ__ADDRESS_ASSIGNMENT]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.GROUP_IDENTIFIERS_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_NETWORK_ADDRESS_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_GROUP_IDENTIFIER_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.EXTENDED_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.ZIGBEE_INFORMATION]: 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.PROFILE_ID]: 00 00
[TOUCHLINK_COMMISSIONING.RESET_TO_FACTORY_NEW_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.ENCRYPTED_NETWORK_KEY]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.RSSI_CORRECTION]: 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST_RESPONSE.GROUP_INFORMATION_RECORDS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_NETWORK_ADDRESS_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST_RESPONSE.COUNT]: 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST.START_INDEX]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.LOGICAL_CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.EXTENDED_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_GROUP_IDENTIFIER_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.NETWORK_UPDATE_ID]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.PROFILE_ID]: 00 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST_RESPONSE.SIZE]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST_RESPONSE.STATUS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_NETWORK_ADDRESS_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.GROUP_IDENTIFIERS_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST_RESPONSE.NUMBER_OF_SUBDEVICES]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOTAL_GROUP_IDENTIFIERS]: 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.DEVICE_ID]: 00 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.IEEE_ADDRESS]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMATION_RESP__TOUCHLINK_PRIORITY_REQUEST]: 00
[TOUCHLINK_COMMISSIONING.IDENTIFY_REQUEST.IDENTIFY_DURATION]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.NETWORK_UPDATE_ID]: 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST_RESPONSE.DEVICE_INFORMATION_RECORDS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_GROUP_IDENTIFIER_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST.START_INDEX]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.ENDPOINT_ID]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST_RESPONSE.STATUS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.FREE_NETWORK_ADDRESS_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.DEVICE_INFORMATION_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST_RESPONSE.COUNT]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_NETWORK_ADDRESS_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.VERSION]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.KEY_INDEX]: 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST_RESPONSE.ENDPOINT_INFORMATION_RECORDS]: 00
[TOUCHLINK_COMMISSIONING.ENDPOINT_INFORMATION.ENDPOINT_ID]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.KEY_INDEX]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_GROUP_IDENTIFIER_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMATION_RESP]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_END_DEVICE_REQUEST.GROUP_IDENTIFIERS_END]: 00 00
[TOUCHLINK_COMMISSIONING.GET_ENDPOINT_LIST_REQUEST_RESPONSE.TOTAL]: 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST.START_INDEX]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ__LINK_INITIATOR]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.ENCRYPTED_NETWORK_KEY]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.FREE_NETWORK_ADDRESS_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.GROUP_IDENTIFIERS_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_GROUP_IDENTIFIER_RANGE_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST_RESPONSE.STATUS]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.KEY_INDEX]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.EXTENDED_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.LOGICAL_CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.GET_GROUP_IDENTIFIERS_REQUEST_RESPONSE.TOTAL]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_JOIN_ROUTER_REQUEST.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.ENCRYPTED_NETWORK_KEY]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.GROUP_IDENTIFIERS_BEGIN]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.EXTENDED_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.EXTENDED_PAN_ID]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.GROUP_IDENTIFIERS_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.INITIATOR_IEEE_ADDRESS]: 00 00 00 00 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.INITIATOR_NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.LOGICAL_CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.NETWORK_ADDRESS]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.DEVICE_ID]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST_RESPONSE.NETWORK_UPDATE_ID]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_START_REQUEST.FREE_GROUP_IDENTIFIER_RANGE_END]: 00 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.LOGICAL_CHANNEL]: 00
[TOUCHLINK_COMMISSIONING.NETWORK_UPDATE_REQUEST.PAN_ID]: 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST_RESPONSE.TOUCHLINK_INFORMATION_RESP__FACTORY_NEW]: 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.INTER_PAN_TRANSACTION_ID]: 00 00 00 00
[TOUCHLINK_COMMISSIONING.SCAN_REQUEST.TOUCHLINK_INFORMATION_REQ]: 00
Channel: 9
[POLL_CONTROL.SHORT_POLL_INTERVAL]: 00 04
[POLL_CONTROL.CHECK_IN.ACTION]: 00
[POLL_CONTROL.LONG_POLL_INTERVAL]: 00 00 04 88
[POLL_CONTROL.FAST_POLL_TIMEOUT]: 00 28
[POLL_CONTROL.CHECK_IN_INTERVAL]: 00 02 a3 00
Channel: 7
[ALARMS.RESET_ALL_ALARMS.ACTION]: 00
[ALARMS.RESET_ALARM.CLUSTER_ID]: 00 00
[ALARMS.RESET_ALARM.ALARM_CODE]: 00
[ALARMS.ALARM.ALARM_CODE]: 00
[ALARMS.ALARM.CLUSTER_ID]: 00 00
Channel: 0
[UNREACH]: 00
[LOWBAT]: 00
[STICKY_UNREACH]: 00
[CONFIG_PENDING]: 00
[LAST_PACKET_RECEIVED]: 61 c0 7f 4a
