[code]
09/30/15 15:09:55.142 MAX packet received (My-MAX-CUL, RSSI: 0x4D): 0C89044203178D069F750018EE
09/30/15 15:09:55.188 MAX packet received (My-MAX-CUL, RSSI: 0x44): 0E890202069F7503178D0001190018
09/30/15 15:09:56.861 UPnP Server: Debug: Sending notify packets.
09/30/15 15:09:56.864 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/30/15 15:09:56.884 Debug: Sleeping 1288ms before sending response.
09/30/15 15:09:58.173 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/30/15 15:09:58.274 UPnP Server: Debug: Sending notify packets.
09/30/15 15:10:01.016 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/30/15 15:10:01.037 Debug: Sleeping 127ms before sending response.
09/30/15 15:10:01.164 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/30/15 15:10:01.265 UPnP Server: Debug: Sending notify packets.
09/30/15 15:10:01.267 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/30/15 15:10:01.288 Debug: Sleeping 399ms before sending response.
09/30/15 15:10:01.688 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/30/15 15:10:01.789 UPnP Server: Debug: Sending notify packets.
09/30/15 15:10:03.663 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: K
09/30/15 15:10:03.697 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: HHM-LAN-IF,03C7,JEQ0534974,1DB017,631963,096E0E92,0001
09/30/15 15:10:13.668 MAX packet received (My-MAX-CUL, RSSI: 0x59): 0E09020206A1BD0316CF000118002A
09/30/15 15:10:13.670 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:18.713 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: K
09/30/15 15:10:18.739 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: HHM-LAN-IF,03C7,JEQ0534974,1DB017,631963,096E4960,0001
09/30/15 15:10:27.458 RPC Server (Port 2001): Info: Connection from 127.0.0.1:56844 accepted. Client number: 14399
09/30/15 15:10:27.463 RPC Server (Port 2001): Listening for incoming packets from client number 14399.
09/30/15 15:10:27.477 RPC Server (Port 2001): Debug: Packet received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
09/30/15 15:10:27.479 RPC Server (Port 2001): Info: Client number 14399 is calling RPC method: init Parameters:
(String) http://127.0.0.1:8083/fhem/HMRPC_hmrf/request
09/30/15 15:10:27.480 Debug: Server path set to: /fhem/HMRPC_hmrf/request
09/30/15 15:10:27.480 Debug: Server port set to: 8083
09/30/15 15:10:27.487 RPC Server (Port 2001): Response:
(void)
09/30/15 15:10:27.497 RPC Server (Port 2001): Response packet: HTTP/1.1 200 OK
Connection: close
Content-Type: text/xml
Content-Length: 96
<?xml version="1.0"?>
09/30/15 15:10:27.521 RPC Server (Port 2001): Info: Connection to client number 14399 closed.
09/30/15 15:10:31.362 MAX packet received (My-MAX-CUL, RSSI: 0x3A): 0C430442031752069F830028C9
09/30/15 15:10:31.363 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:31.407 MAX packet received (My-MAX-CUL, RSSI: 0x40): 0E430202069F830317520001180D28
09/30/15 15:10:31.409 Info (My-MAX-CUL): Packet processing took 2 ms.
09/30/15 15:10:33.749 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: K
09/30/15 15:10:33.781 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: HHM-LAN-IF,03C7,JEQ0534974,1DB017,631963,096E8418,0001
09/30/15 15:10:39.893 MAX packet received (My-MAX-CUL, RSSI: 0x3B): 0C3B04420317210603420028D8
09/30/15 15:10:39.895 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:39.940 MAX packet received (My-MAX-CUL, RSSI: 0x38): 0E3B02020603420317210001180028
09/30/15 15:10:39.941 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:48.789 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Sending: K
09/30/15 15:10:48.822 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Debug: Packet received from HM-CFG-LAN: HHM-LAN-IF,03C7,JEQ0534974,1DB017,631963,096EBED7,0001
09/30/15 15:10:49.663 RPC Server (Port 2001): Info: Connection from 127.0.0.1:56852 accepted. Client number: 14400
09/30/15 15:10:49.666 RPC Server (Port 2001): Listening for incoming packets from client number 14400.
09/30/15 15:10:49.675 RPC Server (Port 2001): Info: Connection to client number 14400 closed (3).
09/30/15 15:10:49.794 RPC Server (Port 2001): Info: Connection from 127.0.0.1:56854 accepted. Client number: 14401
09/30/15 15:10:49.798 RPC Server (Port 2001): Listening for incoming packets from client number 14401.
09/30/15 15:10:49.818 RPC Server (Port 2001): Debug: Packet received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
09/30/15 15:10:49.820 RPC Server (Port 2001): Info: Client number 14401 is calling RPC method: init Parameters:
(String) CB1
09/30/15 15:10:49.821 Debug: Server path set to: /fhem/HMRPC_hmrf/request
09/30/15 15:10:49.821 Debug: Server port set to: 8083
09/30/15 15:10:49.832 RPC Server (Port 2001): Response:
(void)
09/30/15 15:10:49.833 RPC Server (Port 2001): Response packet: HTTP/1.1 200 OK
Connection: close
Content-Length: 96
09/30/15 15:10:49.859 RPC Server (Port 2001): Info: Connection to client number 14401 closed.
09/30/15 15:10:50.708 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/30/15 15:10:50.729 Debug: Sleeping 2327ms before sending response.
09/30/15 15:10:51.212 MAX packet received (My-MAX-CUL, RSSI: 0x52): 0BDF063004DC1806A6230012
09/30/15 15:10:51.214 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:52.770 MAX packet received (My-MAX-CUL, RSSI: 0x4D): 0BE0063004DC1806A6230010
09/30/15 15:10:52.772 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:53.057 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/30/15 15:10:53.157 UPnP Server: Debug: Sending notify packets.
09/30/15 15:10:53.160 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
09/30/15 15:10:53.180 Debug: Sleeping 4239ms before sending response.
09/30/15 15:10:54.147 MAX packet received (My-MAX-CUL, RSSI: 0x3F): 0CAA044206A37D069FED0018CD
09/30/15 15:10:54.149 Info (My-MAX-CUL): Packet processing took 2 ms.
09/30/15 15:10:54.192 MAX packet received (My-MAX-CUL, RSSI: 0x48): 0EAA0202069FED06A37D0001390018
09/30/15 15:10:54.194 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:55.685 MAX packet received (My-MAX-CUL, RSSI: 0x48): 0BE0063004DC1806A6230050
09/30/15 15:10:55.686 Info (My-MAX-CUL): Packet processing took 1 ms.
09/30/15 15:10:57.420 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
09/30/15 15:10:57.521 UPnP Server: Debug: Sending notify packets.
09/30/15 15:10:59.807 RPC Server (Port 2001): Debug: Joining read thread of client 79
09/30/15 15:10:59.807 RPC Server (Port 2001): Debug: Client 79 removed.
09/30/15 15:10:59.808 RPC Server (Port 2001): Debug: Joining read thread of client 80
09/30/15 15:10:59.808 RPC Server (Port 2001): Debug: Client 80 removed.
09/30/15 15:10:59.809 RPC Server (Port 2001): Debug: Joining read thread of client 81
09/30/15 15:10:59.809 RPC Server (Port 2001): Debug: Client 81 removed.
09/30/15 15:10:59.838 Info: Calling RPC method “system.listMethods” on server http://127.0.0.1.
09/30/15 15:10:59.839 Parameters:
(String) CB1
09/30/15 15:10:59.840 Debug: Calling getFileDescriptor…
09/30/15 15:10:59.840 Info: Connecting to host 127.0.0.1 on port 8083…
09/30/15 15:10:59.848 Info: Connected to host 127.0.0.1 on port 8083. Client number is: 14402
09/30/15 15:10:59.849 Sending packet: POST /fhem/HMRPC_hmrf/request HTTP/1.1
User-Agent: Homegear 0.6.0
Host: 127.0.0.1:8083
Content-Length: 142
Connection: close
system.listMethodsCB1
09/30/15 15:10:59.882 Debug: Received packet from server 127.0.0.1:
<?xml version="1.0" encoding="us-ascii"?>[/code]
Jetzt aber
Das Code Feld scheint eingeschränkt in der Größe
das ganze Log ist im Anhang als Datei
homegear.log (104 KB)
