Hi everybody,
I have the following setup:
- Raspberry pi
- Waveshare RS485 adapter - http://www.wvshare.com/product/RS485-Board-3.3V.htm
- various wired Homematic devices
- HomeGear
- OpenHAB
The RS485 module described in Homegear documentation (https://www.homegear.eu/index.php/RS485_Serial_Module) has two separate pins for “driver enable” and “receiver enable” however my module has only one pin described as RSE.
I have tried all the combinations of setup in physical interfaces.conf to make it work but no luck. When I try to search for the devices on the bus, the log is full of errors:
03/22/15 22:34:09.155 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: RS485 bus is still free... sending... (Packet: FDFFFFFFFF9800000001037A6D72)
03/22/15 22:34:09.155 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FDFFFFFFFF9800000001037A6D72)
03/22/15 22:34:09.155 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FDFFFFFFFF9800000001037A6D72
03/22/15 22:34:09.209 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 22:34:09.511 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: RS485 bus is still free... sending... (Packet: FDFFFFFFFF9A00000001037AC10E)
03/22/15 22:34:09.511 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FDFFFFFFFF9A00000001037AC10E)
03/22/15 22:34:09.511 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FDFFFFFFFF9A00000001037AC10E
03/22/15 22:34:09.566 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 22:34:09.870 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FD0000000003026C76)
03/22/15 22:34:09.870 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FD0000000003026C76
03/22/15 22:34:09.924 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 22:34:09.940 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FD0000000003026C76)
03/22/15 22:34:09.940 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FD0000000003026C76
03/22/15 22:34:09.994 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 22:34:10.010 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FD0000000003026C76)
03/22/15 22:34:10.016 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FD0000000003026C76
03/22/15 22:34:10.070 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 22:34:10.116 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: Waiting for RS485 bus to become free... (Packet: FDFFFFFFFF9C00000001035A05CC)
03/22/15 22:34:10.317 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: RS485 bus is free now. Waiting randomly for 42ms... (Packet: FDFFFFFFFF9C00000001035A05CC)
03/22/15 22:34:10.359 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: RS485 bus is still free... sending... (Packet: FDFFFFFFFF9C00000001035A05CC)
03/22/15 22:34:10.360 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FDFFFFFFFF9C00000001035A05CC)
03/22/15 22:34:10.360 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FDFFFFFFFF9C00000001035A05CC
03/22/15 22:34:10.413 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 22:34:10.715 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: RS485 bus is still free... sending... (Packet: FDFFFFFFFF9E00000001035AA9B0)
03/22/15 22:34:10.716 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FDFFFFFFFF9E00000001035AA9B0)
03/22/15 22:34:10.716 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FDFFFFFFFF9E00000001035AA9B0
03/22/15 22:34:10.770 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 22:34:11.071 Module HomeMatic Wired: Info: Search completed. Found 0 devices.
Seems like there is a problem switching RX / TX mode. When I create an event on the RS485 bus (pushing the button which is connected to RS485 Homematic module) it is somehow detected by Homegear, but…
03/22/15 21:42:30.971 HomeMatic Wired packet received: FDFFFFFFFF9800004E29064B070036C7C8
03/22/15 21:42:30.972 Info (Wired): Packet processing took 1 ms.
03/22/15 21:42:30.993 HomeMatic Wired packet received: FDFFFFFFFF9A00004E291241071200030648455130313439333339AF54
03/22/15 21:42:30.993 Info (Wired): Packet processing took 0 ms.
03/22/15 21:42:30.993 Module HomeMatic Wired: Info: New device detected on bus.
03/22/15 21:42:30.997 Info: Can't execute command (Error-no.: 1): no such savepoint: peer46
03/22/15 21:42:31.056 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: Waiting for RS485 bus to become free... (Packet: FD00004E291A0000000106520000104C70)
03/22/15 21:42:31.207 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: RS485 bus is free now. Waiting randomly for 20ms... (Packet: FD00004E291A0000000106520000104
C70)
03/22/15 21:42:31.227 Module HomeMatic Wired: Debug: HomeMatic Wired Device 0x4: RS485 bus is still free... sending... (Packet: FD00004E291A0000000106520000104C70)
03/22/15 21:42:31.227 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FD00004E291A0000000106520000104C70)
03/22/15 21:42:31.227 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FD00004E291A0000000106520000104C70
03/22/15 21:42:31.279 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 21:42:31.380 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FD00004E291A0000000106520000104C70)
03/22/15 21:42:31.380 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FD00004E291A0000000106520000104C70
03/22/15 21:42:31.431 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 21:42:31.532 Module HomeMatic Wired: RS485 Module "Wired": Debug: RS485 device: Got lock for sending... (Packet: FD00004E291A0000000106520000104C70)
03/22/15 21:42:31.532 Module HomeMatic Wired: RS485 Module "Wired": Info: Sending: FD00004E291A0000000106520000104C70
03/22/15 21:42:31.583 Module HomeMatic Wired: RS485 Module "Wired": Error sending HomeMatic Wired packet: No sending detected.
03/22/15 21:42:31.691 Module HomeMatic Wired: Error: HomeMatic Wired Central: Could not pair device with address 0x00004E29. Could not read master config from EEPROM.
Can this Waveshare module be used with Homegear? How should it be configured in physical interfaces.conf? Please help, I’ve already spent many hours trying
Wireless BidCos devices are working fine with the CUL stick.
Thank you very much
Jan
