Hi
when starting homegear the first messages I see are the following in the homegear.err:
11/03/16 18:17:03.465 Module HomeMatic BidCoS: COC "A3E298": Warning: !!!Not!!! sending packet, because init sequence is not complete: 0E69A011FD0801370EEF0201000000 11/03/16 18:17:03.468 Module HomeMatic BidCoS: COC "A3E298": Warning: !!!Not!!! sending packet, because init sequence is not complete: 0EAFA011FD080137CF240201C80000 11/03/16 18:17:03.469 Module HomeMatic BidCoS: COC "A3E298": Warning: !!!Not!!! sending packet, because init sequence is not complete: 0E90A011FD080137C2F50201C80000 11/03/16 18:17:03.471 Module HomeMatic BidCoS: COC "A3E298": Warning: !!!Not!!! sending packet, because init sequence is not complete: 0E86A011FD080137C5440201C80000 11/03/16 18:17:03.472 Module HomeMatic BidCoS: COC "A3E298": Warning: !!!Not!!! sending packet, because init sequence is not complete: 0E75A011FD080137038A0201C80000
when doing a debug I see the following in homegear.log around the same timestamp:
11/03/16 18:17:02.893 Module HomeMatic BidCoS: Info: Central address set to 0xFD0801. 11/03/16 18:17:02.898 Module HomeMatic BidCoS: Loading peer 1 11/03/16 18:17:02.916 Module HomeMatic BidCoS: Debug: AES key of peer 1 is current. 11/03/16 18:17:02.917 Module HomeMatic BidCoS: Loading peer 2 11/03/16 18:17:02.925 Debug: Could not set parameter LOWBAT on channel 0 for peer 2. Parameter does not exist. 11/03/16 18:17:02.926 Module HomeMatic BidCoS: Loading peer 3 11/03/16 18:17:02.934 Debug: Could not set parameter LOWBAT on channel 0 for peer 3. Parameter does not exist. 11/03/16 18:17:02.934 Module HomeMatic BidCoS: Loading peer 4 11/03/16 18:17:02.943 Debug: Could not set parameter LOWBAT on channel 0 for peer 4. Parameter does not exist. 11/03/16 18:17:02.943 Module HomeMatic BidCoS: Loading peer 5 11/03/16 18:17:02.951 Debug: Could not set parameter LOWBAT on channel 0 for peer 5. Parameter does not exist. 11/03/16 18:17:02.952 Module HomeMatic BidCoS: Loading peer 6 11/03/16 18:17:02.960 Debug: Could not set parameter LOWBAT on channel 0 for peer 6. Parameter does not exist. 11/03/16 18:17:02.960 Module HomeMatic BidCoS: Loading peer 7 11/03/16 18:17:02.964 Module HomeMatic BidCoS: Loading peer 8 11/03/16 18:17:02.967 Module HomeMatic BidCoS: Loading peer 9
the peers which are complained about are:
2 β β 37CF24 β MEQ0270691 β 00AC β HM-ES-PMSw1-Pl β 2.5 β No β No β No 3 β β 37C2F5 β MEQ0270420 β 00AC β HM-ES-PMSw1-Pl β 2.5 β No β No β No 4 β β 37C544 β MEQ0270274 β 00AC β HM-ES-PMSw1-Pl β 2.5 β No β No β No 5 β β 37038A β MEQ0272739 β 00AC β HM-ES-PMSw1-Pl β 2.5 β No β No β No 6 β β 370EEF β MEQ0274053 β 00AC β HM-ES-PMSw1-Pl β 2.5 β No β No β No
so far it seems not to have any impact, just curious as the HM-ES-PMSw1-Pl does not have any LOWBAT.
running on an Raspberry Pi 3 Model B
homegear -v
Homegear version 0.7.15-1580
Copyright (c) 2013-2017 Sathya LauferGit commit SHA of libhomegear-base: -
Git branch of libhomegear-base: -
Git commit SHA of Homegear: -
Git branch of Homegear: -PHP (License: PHP License):
This product includes PHP software, freely available from http://www.php.net/software/
Copyright (c) 1999-2017 The PHP Group. All rights reserved.
uname -a
Linux lemonpi 4.14.22-v7+ #1096 SMP Mon Feb 26 19:14:22 GMT 2018 armv7l GNU/Linux
cheers
