Hi
when using node-blue I see the following error message in the homegear.err:
01/24/18 19:23:54.283 Warning: Requested URL not found: favicon.ico
01/24/18 19:24:05.145 Warning: Requested URL not found: /var/lib/homegear/flows/www/vendor/vendor.css
01/24/18 19:24:05.317 Warning: Requested URL not found: /var/lib/homegear/flows/www/vendor/jsonata/jsonata.min.js
01/24/18 19:24:05.796 Warning: Requested URL not found: /var/lib/homegear/flows/www/vendor/jsonata/jsonata.min.js
I think the first one is OK as no favicon.ico is installed.
the 2nd referenced to an empty file:
file /var/lib/homegear/flows/www/vendor/vendor.css
/var/lib/homegear/flows/www/vendor/vendor.css: empty
the 3rd one is not existing:
root@lemonpi:/var/log/homegear# file /var/lib/homegear/flows/www/vendor/jsonata/jsonata.min.js
/var/lib/homegear/flows/www/vendor/jsonata/jsonata.min.js: cannot open `/var/lib/homegear/flows/www/vendor/jsonata/jsonata.min.jsâ (No such file or directory)
I see some references in the /var/lib/homegear/flows/www/index.php.
is this on purpose and will be used later?
cheers
Jipp
