nach dem ersten Start der Version 070 (nach Upgrade von 060) habe ich folgendes Warnig im Fehlerprotokoll:
08/09/16 00:38:11.545 User name not found.
08/09/16 00:38:11.547 User name not found.
08/09/16 00:38:13.632 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 1 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.633 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 1 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.633 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 1 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.635 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 1 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.684 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 2 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.684 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 2 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.684 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 2 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.685 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 2 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.734 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 3 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.735 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 3 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.735 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 3 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.736 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 3 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.790 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 4 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.791 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 4 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.791 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 4 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.792 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 4 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.843 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 5 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.843 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 5 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.844 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 5 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.845 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 5 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.898 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 6 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.899 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 6 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.899 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 6 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.899 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 6 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.941 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 7 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.942 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 7 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.942 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 7 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.942 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 7 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.984 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 10 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.984 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 10 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.985 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 10 Channel: 0 Parameter set type: 1
08/09/16 00:38:13.985 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 10 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.033 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 12 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.033 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 12 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.033 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 12 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.034 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 12 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.076 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 13 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.076 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 13 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.076 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 13 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.077 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 13 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.125 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 14 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.125 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 14 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.126 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 14 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.127 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 14 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.185 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 15 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.186 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 15 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.186 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 15 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.187 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 15 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.247 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 16 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.247 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 16 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.248 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 16 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.249 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 16 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.294 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 17 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.295 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 17 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.295 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 17 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.295 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 17 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.328 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 18 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.329 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 18 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.329 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 18 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.329 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 18 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.379 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 19 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.379 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 19 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.379 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 19 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.380 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 19 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.431 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 20 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.432 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 20 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.432 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 20 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.432 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 20 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.470 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 21 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.470 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 21 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.471 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 21 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.471 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 21 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.505 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 23 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.506 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 23 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.506 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 23 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.507 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 23 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.536 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 24 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.537 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 24 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.537 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 24 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.537 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 24 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.569 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 25 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.570 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 25 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.570 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 25 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.570 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 25 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.604 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 26 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.604 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 26 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.605 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 26 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.605 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 26 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.650 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 27 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.652 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 27 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.652 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 27 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.652 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 27 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.695 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 28 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.696 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 28 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.696 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 28 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.696 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 28 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.732 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 29 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.733 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 29 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.733 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 29 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.733 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 29 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.772 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_1, because no corresponding RPC parameter was found. Peer: 30 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.772 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_2, because no corresponding RPC parameter was found. Peer: 30 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.772 Warning: Deleting parameter CENTRAL_ADDRESS_BYTE_3, because no corresponding RPC parameter was found. Peer: 30 Channel: 0 Parameter set type: 1
08/09/16 00:38:14.773 Warning: Deleting parameter PAIRED_TO_CENTRAL, because no corresponding RPC parameter was found. Peer: 30 Channel: 0 Parameter set type: 1
Welche Handlungsanweisung verbirgt sich dahiner
LG
portboy
