With the homematic manager I bind a Max thermostat and a Max Radiator together. If I manual change the temperature on the thermostat the radiator follows the thermostat.
The problem is when I change the temperature of thermostat in Home assistant the radiator does not follow.
Is there something else what I must configure in the homematic manager?
