ich bin neu hier im Forum und habe mich in der vergangenen Woche an die Installation von Homegear gemacht. Leider komme ich beim Zugriff auf die CLI nicht weiter.
Mein Hardwareaufbau:
- Raspberry 3 B
- SCC - Modul von Busware
Die Konfigruation habe ich entsprechender Anleitung durchgeführt. Beim Starten von Homegear erhalte ich folgende Logs:
root@raspberrypi:/home/pi# homegear
06/05/16 18:01:08.153 Loading RPC server settings from /etc/homegear/rpcservers.conf
06/05/16 18:01:08.154 Loading RPC client settings from /etc/homegear/rpcclients.conf
06/05/16 18:01:08.156 Starting Homegear...
06/05/16 18:01:08.156 Homegear version 0.6.0-1327
06/05/16 18:01:08.156 Git commit SHA of libhomegear-base: c8c50171ec169e6ebd1163aa690e40e04886c1b0
06/05/16 18:01:08.156 Git commit SHA of Homegear: 62c992e9eb3ed5c7c7eddc44d60cb87bd1fb33c8
06/05/16 18:01:08.157 Info: Loading family module mod_miscellaneous.so
06/05/16 18:01:08.160 /etc/homegear/families/miscellaneous.conf
06/05/16 18:01:08.161 Info: Loading family module mod_homematicbidcos.so
06/05/16 18:01:08.179 /etc/homegear/families/homematicbidcos.conf
06/05/16 18:01:08.180 Warning: Running as root. The authors of Homegear recommend running Homegear as user.
06/05/16 18:01:08.180 Info: Setting allowed core file size to "4294967295" for user with id 0 and group with id 0.
06/05/16 18:01:08.181 Info: Core file size now is "4294967295".
06/05/16 18:01:08.181 Info: Setting maximum thread priority to "0" for user with id 0 and group with id 0.
06/05/16 18:01:08.181 Info: Maximum thread priority now is "0".
06/05/16 18:01:08.190 Info: Backing up database...
06/05/16 18:01:08.194 Can't execute "PRAGMA journal_mode=DELETE": database is locked
06/05/16 18:01:08.290 Initializing database...
06/05/16 18:01:08.293 Starting script engine server...
06/05/16 18:01:08.325 Initializing licensing controller...
06/05/16 18:01:08.326 Loading licensing controller data...
06/05/16 18:01:08.326 Loading devices...
06/05/16 18:01:08.326 Loading XML RPC devices...
06/05/16 18:01:09.237 Loading device 2
06/05/16 18:01:09.238 Module HomeMatic BidCoS: Info: Central address set to 0xFD462B.
06/05/16 18:01:09.239 Loading XML RPC devices...
06/05/16 18:01:09.241 Loading device 1
06/05/16 18:01:09.241 Start listening for packets...
Beim Ausführen des Befehls “ps -A | grep homegear” erhalte ich die folgende Ausgabe.
root@raspberrypi:/home/pi# ps -A | grep homegear
946 ? 00:00:00 homegear
947 ? 01:07:37 homegear
5291 pts/0 00:06:07 homegear
Wenn ich jetzt jedoch den CLI Befehel “homegear -r” ausführe, erhalte ich die Ausgabe:
root@raspberrypi:/home/pi# homegear -r
06/05/16 18:08:58.063 Could not connect to socket. Error: No such file or directory
Ich bin etwas ratlos, da ich alle Schritte analog zur Anleitung durchgeführt hatte…
Kann hier jemand helfen?
Vielen Dank!
Grüße,
Simon
