Hi Sathya,
I wanted to play around with your HomeGearLib.NET library, but it seems to behaving weirdly… Probably me using in wrong.
It does not show all variable updates, but disconnects and connects again every once in a while and does show 2 or maybe a little more updates and then disconnects again.
I have tried to use your HomegearLibTest to see if this makes a difference, but it does not.
I have entered, Homegear Hostname/Port and Callback Server Port and Hostname (ssl unchecked and port changed to 2001).
Variable updated: Device type: "HM-CC-TC", ID: 10, Channel: 1, Variable Name: "TEMPERATURE", Value: 22
Variable updated: Device type: "HM-CC-TC", ID: 6, Channel: 0, Variable Name: "RSSI_DEVICE", Value: -56
Variable updated: Device type: "HM-CC-TC", ID: 3, Channel: 1, Variable Name: "TEMPERATURE", Value: 22,6
Connected to Homegear.
Disconnected from Homegear.
Variable updated: Device type: "HM-CC-RT-DN", ID: 58, Channel: 0, Variable Name: "RSSI_DEVICE", Value: -66
Variable updated: Device type: "HM-CC-RT-DN", ID: 47, Channel: 4, Variable Name: "ACTUAL_TEMPERATURE", Value: 19,3
Variable updated: Device type: "HM-CC-TC", ID: 10, Channel: 0, Variable Name: "RSSI_DEVICE", Value: -56
Variable updated: Device type: "HM-CC-TC", ID: 9, Channel: 1, Variable Name: "TEMPERATURE", Value: 22,4
Variable updated: Device type: "HM-CC-TC", ID: 8, Channel: 0, Variable Name: "RSSI_DEVICE", Value: -63
Variable updated: Device type: "HM-CC-TC", ID: 3, Channel: 1, Variable Name: "TEMPERATURE", Value: 22,5
Variable updated: Device type: "HM-CC-TC", ID: 10, Channel: 0, Variable Name: "RSSI_DEVICE", Value: -55
Variable updated: Device type: "HM-CC-TC", ID: 6, Channel: 0, Variable Name: "RSSI_DEVICE", Value: -55
Variable updated: Device type: "HM-CC-RT-DN", ID: 59, Channel: 0, Variable Name: "RSSI_DEVICE", Value: -60
Reload complete. Received 55 devices.
that’s what I get using both my code (which I mainly stole from your HomeGearLibTest
) and HomeGearLibTest itself.
Any hints what might be wrong?
Cheers,
Chris
