ich probiere ein Update auf 0.6 zu machen. Beim Befehl
dpkg -i libhomegear-base_current_debian_wheezy_armhf.deb
scheitert die Installation mit folgender Meldung:
[code]Selecting previously unselected package libhomegear-base.
(Reading database … 117745 files and directories currently installed.)
Preparing to unpack libhomegear-base_current_debian_wheezy_armhf.deb …
Unpacking libhomegear-base (0.6.0-1346) …
dpkg: dependency problems prevent configuration of libhomegear-base:
libhomegear-base depends on libgnutlsxx27; however:
Package libgnutlsxx27 is not installed.
dpkg: error processing package libhomegear-base (–install):
dependency problems - leaving unconfigured
libhomegear-base
[/code]
Wenn ich probiere dies nachzuinstallieren kommt folgendes:
[code]sudo apt-get install libgnutlsxx27
Reading package lists… Done
Building dependency tree
Reading state information… Done
Package libgnutlsxx27 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package ‘libgnutlsxx27’ has no installation candidate
[/code]
Hier bleibe ich stecken…Keine Idee wie es weiter gehen könnte. Kann mir jemand helfen? Danke!!!
