Ich habe seit ein paar Tagen das Problem, dass Homegear regelmässig unerreichbar ist.
Folgendes sind meine Änderungen gewesen:
- Upgrade auf 0.8.0-2245
- Installation homegear-managment (ich wollte eine Gateway anbinden)
Folgender Effekt tritt auf (vorher kein Log-Eintrag, ich bin auf loglevel 3):
06/22/18 06:25:40.213 Info: Backing up database...
06/22/18 06:25:40.283 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:40.383 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:40.484 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:40.584 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:40.685 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:40.785 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:40.886 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:40.986 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.087 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.188 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.288 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.389 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.489 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.590 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.690 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.791 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.858 Error (My-CC1101-Module): More than 1000 packets are queued to be processed. Your packet processing is too slow. Dropping packet.
06/22/18 06:25:41.891 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:41.992 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:42.082 Error (My-CC1101-Module): More than 1000 packets are queued to be processed. Your packet processing is too slow. Dropping packet.
06/22/18 06:25:42.095 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:42.194 Error (My-CC1101-Module): More than 1000 packets are queued to be processed. Your packet processing is too slow. Dropping packet.
06/22/18 06:25:42.196 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:42.297 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
06/22/18 06:25:42.397 RPC Server (Port 2001): Error: There are too many clients connected to me. Closing incoming connection. You can increase the number of allowed connections in main.conf.
Das wiederholt sich bis ich das System neu starte.
Kann es sein, dass das Backup der Datenbank einen Teil von homegear ausser Betrieb setzt und dass der Crash dadurch erzeugt wird?
Ich habe jetzt homegear-management deinstalliert, mal schauen was beim nächsten Backup um 16:25 passiert.
