Hello everybody,
I’m running openhabian on a Raspberry Pi3 B+ and Homegear 0.7.27-1824 with HM-MOD-RPI-PCB.
I had a little trouble to get the HM-MOD-RPI-PCB running. Now the module seems to talk to homegear but they don’t unterstand each other. ![]()
I can’t pair any devices (I’m trying with a HM-LC-Bl1PBU-FM). The logs keep saying:
08/06/18 22:33:03.266 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A
08/06/18 22:33:03.266 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...
I was was wondering if the HM-MOD-RPI-PCB is working correctly, so I installed Raspberrymatic. Pairing worked right away and according to other posts in various forums Raspberry should have done a firmware update to the module. I think I saw something like that in the Raspberrymatic logs but I’m not sure about it.
I followed the “official” configuration instructions and read almost every post in this forum about the HM-MOD-RPI-PCB.
I disabled the serial interfaces:
And some kind of communication between the Pi and the module seem to work. Here are my config and the log files:
[General]
moduleEnabled = true
[General]
centralAddress = 0xFD0AB0
rfKey = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
## incremented by 1
currentRfKeyIndex = 1
## old and the new one.
## risk.
id = My-HM-MOD-RPI-PCB
## to new peers.
deviceType = hm-mod-rpi-pcb
device = /dev/ttyAMA0
responseDelay = 95
## Default: gpio1 = 0
## "18" for HM-MOD-RPI-PCB
gpio1 = 18
homegear.log (33,7 KB)
homegear.err
08/06/18 18:17:34.210 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A
08/06/18 18:17:34.210 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...
08/06/18 18:17:35.780 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
08/06/18 18:17:43.923 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No response received to packet: FD0003000003180A
08/06/18 18:17:43.923 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: Unknown packet received in response to init packet. Reconnecting...
08/06/18 18:17:45.492 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
$ ls -la /dev/tty*
crw-rw---- 1 homegear homegear 204, 64 Aug 6 18:22 /dev/ttyAMA0
crw------- 1 root root 5, 3 Aug 6 18:13 /dev/ttyprintk
crw-rw---- 1 root dialout 4, 64 Aug 6 18:13 /dev/ttyS0
$ cat /etc/udev/rules.d/99-com.rules
##SUBSYSTEM=="input", GROUP="input", MODE="0660"
##SUBSYSTEM=="i2c-dev", GROUP="i2c", MODE="0660"
##SUBSYSTEM=="spidev", GROUP="spi", MODE="0660"
##SUBSYSTEM=="bcm2835-gpiomem", GROUP="gpio", MODE="0660"
#SUBSYSTEM=="gpio*", PROGRAM="/bin/sh -c '\
chown -R root:gpio /sys/class/gpio && chmod -R 770 /sys/class/gpio;\
chown -R root:gpio /sys/devices/virtual/gpio && chmod -R 770 /sys/devices/virtual/gpio;\
chown -R root:gpio /sys$devpath && chmod -R 770 /sys$devpath\
KERNEL=="ttyAMA[01]", PROGRAM="/bin/sh -c '\
ALIASES=/proc/device-tree/aliases; \
if cmp -s $ALIASES/uart0 $ALIASES/serial0; then \
echo 0;\
elif cmp -s $ALIASES/uart0 $ALIASES/serial1; then \
echo 1; \
else \
exit 1; \
fi\
'", SYMLINK+="serial%c"
KERNEL=="ttyS0", PROGRAM="/bin/sh -c '\
if cmp -s $ALIASES/uart1 $ALIASES/serial0; then \
echo 0; \
elif cmp -s $ALIASES/uart1 $ALIASES/serial1; then \
echo 1; \
else \
exit 1; \
fi \
$ cat /boot/cmdline.txt
dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=1fff3176-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
$ cat /boot/config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
#hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
#hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
#config_hdmi_boost=4
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=on
gpu_mem=16
enable_uart=1
dtoverlay=pi3-miniuart-bt
dtparam=spi=on
dtparam=i2c_arm=on
Does anyone has an idea?
Regards
Martin
