I just started into the world of home automatisation using Homematic. I successfully configured homegear to connect to the Lan Gateway (HM-LGW-O-TW-W-EU). However, I cannot get any device paired with it (HM-WDS10-TH-0, HM-LC-Sw1-Pl). There are some debug outputs from homegear, but “peers list” doesn’t show any device.
I reseted the device before using (although they were brand new). Is it correct that I configured homegear with a roandom rfkey initally?
Find below the debug output. At 20:18:11.992 something is received after pressing the pair button.
02/02/16 20:18:01.883 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300BE081C39
02/02/16 20:18:01.891 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500BE040200D463
02/02/16 20:18:01.891 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:03.519 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2001): K57
02/02/16 20:18:03.525 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received on port 2001: >K57
02/02/16 20:18:03.525 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2001.
02/02/16 20:18:06.896 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300BF089A3A
02/02/16 20:18:06.904 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500BF0402004060
02/02/16 20:18:06.904 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:11.910 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300C008983C
02/02/16 20:18:11.917 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500C0040200CC77
02/02/16 20:18:11.917 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:11.992 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD002001A1050000348484003194B800000013003D4C45513130363930393270030100F6C2
02/02/16 20:18:11.992 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x34): 1A8484003194B800000013003D4C45513130363930393270030100
02/02/16 20:18:11.992 Module HomeMatic BidCoS: Creating SAVEPOINT BidCoSQueue3249336_1
02/02/16 20:18:11.992 Module HomeMatic BidCoS: Debug: Sending peer to LGW "My-HM-LGW": Address 3194B8, AES enabled 0, AES map 00.
02/02/16 20:18:11.992 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000901C1063194B8000000B051
02/02/16 20:18:12.001 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000401C10408821F
02/02/16 20:18:12.051 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000901C2063194B8000000805B
02/02/16 20:18:12.059 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000401C204088223
02/02/16 20:18:12.092 Module HomeMatic BidCoS: Debug: Postponing deletion of queue 1 for BidCoS peer with address 0x3194B8, because it is still in use (2 referring objects).
02/02/16 20:18:12.109 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000901C3063194B8000000905D
02/02/16 20:18:12.119 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001C3040701010001FFFFFFFFFFFFFFFF0315
02/02/16 20:18:12.119 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000901C4063194B8000000E04F
02/02/16 20:18:12.130 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001C4040701010001FFFFFFFFFFFFFFFF0407
02/02/16 20:18:12.130 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000801C50A3194B80001451B
02/02/16 20:18:12.144 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000401C50401027A
02/02/16 20:18:12.144 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000901C6063194B8000000C043
02/02/16 20:18:12.155 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001C6040701010001FFFFFFFFFFFFFFFF060B
02/02/16 20:18:12.155 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000901C7063194B8000000D045
02/02/16 20:18:12.166 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001C7040701010001FFFFFFFFFFFFFFFF070D
02/02/16 20:18:12.166 Module HomeMatic BidCoS: Debug: Setting physical device's wake up flag.
02/02/16 20:18:12.166 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Info: Sending (My-HM-LGW): 102CA001FD04503194B800050000000000
02/02/16 20:18:12.167 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000901C8063194B80001012661
02/02/16 20:18:12.167 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD001501C90200002CA001FC7D04503194B8000500000000007317
02/02/16 20:18:12.179 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001C8040701010001FFFFFFFFFFFFFFFF082F
02/02/16 20:18:12.179 Module HomeMatic BidCoS: Info: Pushing pending queues.
02/02/16 20:18:12.179 Info (My-HM-LGW): Packet processing took 187 ms.
02/02/16 20:18:12.209 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000401C904020280
02/02/16 20:18:12.209 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet was sent successfully: 102CA001FD04503194B800050000000000
02/02/16 20:18:13.536 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2001): K58
02/02/16 20:18:13.543 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received on port 2001: >K58
02/02/16 20:18:13.543 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2001.
02/02/16 20:18:13.994 Module HomeMatic BidCoS: Debug: Deleting queue 1 for BidCoS peer with address 0x3194B8
02/02/16 20:18:13.995 Module HomeMatic BidCoS: Releasing SAVEPOINT BidCoSQueue3249336_1
02/02/16 20:18:16.214 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300CA08A43C
02/02/16 20:18:16.221 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500CA0402004477
02/02/16 20:18:16.221 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:21.227 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300CB08223F
02/02/16 20:18:21.234 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500CB040200D074
02/02/16 20:18:21.234 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:23.546 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001501A2050000512C8610226B8D0000000AA0D70D0058FA36
02/02/16 20:18:23.546 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x51): 0F2C8610226B8D0000000AA0D70D0058
02/02/16 20:18:23.547 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:23.554 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2001): K59
02/02/16 20:18:23.560 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received on port 2001: >K59
02/02/16 20:18:23.561 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2001.
02/02/16 20:18:23.665 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000F01A3050000534AA1121C9F66226B8D968C
02/02/16 20:18:23.665 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x53): 094AA1121C9F66226B8D
02/02/16 20:18:23.665 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:23.795 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001A4050000514A8002226B8D1C9F660036A8
02/02/16 20:18:23.795 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x51): 0A4A8002226B8D1C9F6600
02/02/16 20:18:23.795 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:26.798 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300CC08B03C
02/02/16 20:18:26.806 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500CC0402003C77
02/02/16 20:18:26.806 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:31.812 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300CD08363F
02/02/16 20:18:31.819 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500CD040200A874
02/02/16 20:18:31.819 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:31.881 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001501A505000050008610227F410000000AA8E60D00586075
02/02/16 20:18:31.881 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x50): 0F008610227F410000000AA8E60D0058
02/02/16 20:18:31.881 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:31.999 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000F01A60500005356A1121C9F66227F4125A2
02/02/16 20:18:31.999 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x53): 0956A1121C9F66227F41
02/02/16 20:18:31.999 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:32.129 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001A705000050568002227F411C9F6600617D
02/02/16 20:18:32.129 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x50): 0A568002227F411C9F6600
02/02/16 20:18:32.129 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:33.572 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2001): K5A
02/02/16 20:18:33.578 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received on port 2001: >K5a
02/02/16 20:18:33.578 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2001.
02/02/16 20:18:36.133 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300CE083C3F
02/02/16 20:18:36.141 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500CE0402009474
02/02/16 20:18:36.141 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:41.147 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300CF08BA3C
02/02/16 20:18:41.154 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500CF0402000077
02/02/16 20:18:41.154 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:41.816 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001501A80500004CE586102267FB0000000AB0F40E04585696
02/02/16 20:18:41.816 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x4C): 0FE586102267FB0000000AB0F40E0458
02/02/16 20:18:41.817 Info (My-HM-LGW): Packet processing took 1 ms.
02/02/16 20:18:41.935 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000F01A90500005328A1121C9F662267FB6D77
02/02/16 20:18:41.935 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x53): 0928A1121C9F662267FB
02/02/16 20:18:41.935 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:42.064 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001001AA0500004C2880022267FB1C9F66007686
02/02/16 20:18:42.065 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x4C): 0A2880022267FB1C9F6600
02/02/16 20:18:42.065 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:43.590 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2001): K5B
02/02/16 20:18:43.596 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received on port 2001: >K5b
02/02/16 20:18:43.596 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2001.
02/02/16 20:18:44.778 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001501AB0500005100861028E2160000000A88B80E00401ACC
02/02/16 20:18:44.779 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x51): 0F00861028E2160000000A88B80E0040
02/02/16 20:18:44.779 Info (My-HM-LGW): Packet processing took 0 ms.
02/02/16 20:18:46.781 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Sending (Port 2000): FD000300D008783F
02/02/16 20:18:46.788 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD000500D00402008C71
02/02/16 20:18:46.788 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Keep alive response received on port 2000.
02/02/16 20:18:48.103 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Debug: Packet received from HM-LGW on port 2000: FD001501AC05000045ED8610224E030000000AA0DBCA01584843
02/02/16 20:18:48.103 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: 0x45): 0FED8610224E030000000AA0DBCA0158
02/02/16 20:18:48.104 Info (My-HM-LGW): Packet processing took 0 ms.
Habe nun auch versucht, das Gateway zu reseten. Hat aber nichts gebracht. Interessanterweise blinkt die LED nach 6 Sekunden reset langsam und beim nächsten 3 Sekunden reset schnell. Dies ist entgegen der Anleitung!?
sorry for the late replay. There was too much to do the last weeks, so I didn’t have the time to reply to forum posts …
It seems, there are no responses to the sent packets. This is a known problem. Just set “sendFix” in “/etc/homegear/families/homematicbidcos.conf” to “true”, then it should work. Also make sure, your devices are factory resetted.
i also tried to move from my Homematic CCU to Homegear in order to allow an integration into openhab. Unfortunately, I seem to have the same or a similar problem as described here. I also have the LAN gateway. Everything worked ok on the CCU and I had also changed the RF AES key.
With homegear I started with the official 0.5.25 version. Connection to the LAN gateway worked, but I could not pair any devices. No error, but nothing in “ls”. Then I wanted to test the sendFix, but did not find the parameter. So I upgraded to the latest nightly 0.6.0-1279, where I did find it. However, now I get another error:
04/01/16 13:54:40.895 Startup complete. Waiting for physical interfaces to connect.
04/01/16 13:54:40.895 All physical interfaces are connected now.
04/01/16 13:54:40.895 Starting UPnP server...
04/01/16 13:54:40.896 Info: UPnP server: Binding to address: 172.17.30.13
04/01/16 13:54:40.896 UPnP Server: Info: Started listening.
04/01/16 13:54:49.916 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Info: Init queue completed. Sending peers...
04/01/16 13:54:49.916 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Info: Peer sending completed.
04/01/16 13:54:51.124 Info: CLI connection accepted. Client number: 8
04/01/16 13:55:19.505 HomeMatic BidCoS packet received (My-HM-LGW, RSSI: -75 dBm): 1AC084003872E80000001200A64D45513031363233353440040000
04/01/16 13:55:19.506 Module HomeMatic BidCoS: Info: Pushing pending queues.
04/01/16 13:55:19.565 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Info: Sending (My-HM-LGW): 1055A001FD12513872E800050000000000
04/01/16 13:55:21.279 Module HomeMatic BidCoS: HM-LGW "My-HM-LGW": Info: AES handshake failed for packet, because either the response data of the last handshake packet didn't match or the last handshake packet wasn't received: 1055A001FD12513872E800050000000000
Is there a chance to get that working, or should I go back to the CCU?
