I am running Openhabian on Raspberry Pi 3.
I have installed the homegear 0.7 as described in the official manual.
The hardware used is CC11011 with arduino nano running nanoCUL V3.
11/16/17 10:11:22.471 Debug: enableUPnP set to 1
11/16/17 10:11:22.472 Debug: caPath set to /etc/homegear/homegearca.crt
11/16/17 10:11:22.472 Debug: certPath set to /etc/homegear/homegear.crt
11/16/17 10:11:22.472 Debug: keyPath set to /etc/homegear/homegear.key
11/16/17 10:11:22.472 Debug: loadDHParamsFromFile set to 1
11/16/17 10:11:22.472 Debug: dhParamPath set to /etc/homegear/dh1024.pem
11/16/17 10:11:22.472 Debug: deviceDescriptionPath set to /etc/homegear/devices/
11/16/17 10:11:22.472 Debug: clientSettingsPath set to /etc/homegear/rpcclients.conf
11/16/17 10:11:22.472 Debug: serverSettingsPath set to /etc/homegear/rpcservers.conf
11/16/17 10:11:22.472 Debug: mqttSettingsPath set to /etc/homegear/mqtt.conf
11/16/17 10:11:22.472 Debug: familyConfigPath set to /etc/homegear/families/
11/16/17 10:11:22.472 Debug: phpIniPath set to /etc/homegear/php.ini
11/16/17 10:11:22.472 Debug: gpioPath set to /sys/class/gpio/
11/16/17 10:11:22.472 Debug: scriptPath set to /var/lib/homegear/scripts/
11/16/17 10:11:22.472 Debug: enableFlows set to 1
11/16/17 10:11:22.472 Debug: flowsPath set to /var/lib/homegear/flows/
11/16/17 10:11:22.472 Debug: flowsDataPath set to /var/lib/homegear/flows/data/
11/16/17 10:11:22.472 Debug: nodeBlueDebugOutput set to 1
11/16/17 10:11:22.472 Debug: libraryPath set to /var/lib/homegear/modules/
11/16/17 10:11:22.472 Debug: firmwarePath set to /usr/share/homegear/firmware/
11/16/17 10:11:22.472 Debug: tempPath set to /var/lib/homegear/tmp/
11/16/17 10:11:22.472 Debug: lockFilePath set to /var/run/homegear/
11/16/17 10:11:22.472 Debug: lockFilePathPermissions set to 504
11/16/17 10:11:22.473 Debug: lockFilePathUser set to homegear
11/16/17 10:11:22.473 Debug: lockFilePathGroup set to homegear
11/16/17 10:11:22.473 Debug: Added replaceClientServerAddress xmlrpc_bin://127.0.0.1:1999 xmlrpc_bin://$remoteip:1999
11/16/17 10:11:22.473 Debug: Added replaceClientServerAddress http://127.0.0.1:9292/bidcos http://$remoteip:9292/bidcos
11/16/17 10:11:22.473 Debug: prioritizeThreads set to 1
11/16/17 10:11:22.473 Debug: secureMemorySize set to 65536
11/16/17 10:11:22.473 Debug: workerThreadWindow set to 3000
11/16/17 10:11:22.473 Debug: scriptEngineMaxThreadsPerScript set to 4
11/16/17 10:11:22.473 Debug: scriptEngineMaxScriptsPerProcess set to 50
11/16/17 10:11:22.473 Debug: scriptEngineThreadCount set to 5
11/16/17 10:11:22.473 Debug: scriptEngineServerMaxConnections set to 10
11/16/17 10:11:22.473 Debug: flowsProcessingThreadCountServer set to 5
11/16/17 10:11:22.473 Debug: flowsProcessingThreadCountNodes set to 10
11/16/17 10:11:22.473 Debug: flowsServerMaxConnections set to 50
11/16/17 10:11:22.473 Debug: maxNodeThreadsPerProcess set to 60
11/16/17 10:11:22.473 Debug: ipcThreadCount set to 5
11/16/17 10:11:22.473 Debug: ipsServerMaxConnections set to 20
11/16/17 10:11:22.473 Debug: cliServerMaxConnections set to 50
11/16/17 10:11:22.473 Debug: rpcServerMaxConnections set to 50
11/16/17 10:11:22.473 Debug: rpcServerThreadPriority set to 0
11/16/17 10:11:22.473 Debug: rpcServerThreadPolicy set to 0
11/16/17 10:11:22.473 Debug: rpcClientMaxThreads set to 50
11/16/17 10:11:22.473 Debug: rpcClientThreadPriority set to 0
11/16/17 10:11:22.474 Debug: rpcClientThreadPolicy set to 0
11/16/17 10:11:22.474 Debug: workerThreadPriority set to 0
11/16/17 10:11:22.474 Debug: workerThreadPolicy set to 0
11/16/17 10:11:22.474 Debug: physicalInterfaceThreadPriority set to 45
11/16/17 10:11:22.474 Debug: physicalInterfaceThreadPolicy set to 1
11/16/17 10:11:22.474 Debug: packetReceivedThreadPriority set to 0
11/16/17 10:11:22.474 Debug: packetReceivedThreadPolicy set to 0
11/16/17 10:11:22.474 Debug: eventThreadCount set to 5
11/16/17 10:11:22.474 Debug: eventThreadPriority set to 0
11/16/17 10:11:22.474 Debug: eventThreadPolicy set to 0
Debug: Trying to connect...
11/16/17 10:11:22.474 Debug: Socket closed. Trying again...
Connected to Homegear (version 0.7.10-1397).
Connection closed.
I get this error message when I run the homegear. Connection is closed after 1-2 seconds. If I type " fs 0" , it says “Cannot connect to Socket” .I have also tried restarting and the status shows running.
my Configuration file looks like this-
########## General Settings  ##########
[General]
centralAddress = 0xFD0001
#English-Forums # Specify a 16 byte (32 characters) long AES key here to protect your wireless communication
## incremented by 1
currentRfKeyIndex = 1
## old and the new one.
## risk.
[TI CC1101 Module]
id = My-CC1101
## to new peers.
##default = true
deviceType = cc1100
device = /dev/spidev0.0
interruptPin=0
gpio1=25
responseDelay = 100
The end of homegear log file is attached below.
I am new to this area. Kindly help in debugging this problem.
Thanks.
log.txt (2.3 KB)
Update : I think I had mistaken RPi + CC1101 configuration for hardware I am using. I changed it to CUL hardware configuration and the error is gone.
But, I am not able to connect to the device yet. I will try and update here if I am successful.
