RPC Server (Port 2003): Error: Server could not start listening on port 2003: Address already in use
ich bekomme im Log immer diesen Fehler angezeigt. Laut netstat -l ist der Port allerdings nicht belegt.
Unter ioBroker kann ich homegear korrekt ansprechen. Der Fehler ist aber so häufig, dass das Logfile
sehr groß wird…
service homegear liefert folgende Ausgabe:
● homegear.service - Homegear
Loaded: loaded (/lib/systemd/system/homegear.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-02-27 12:12:32 GMT; 25min ago
Process: 22295 ExecStartPre=/etc/homegear/homegear-start.sh (code=exited, status=0/SUCCESS)
Main PID: 22297 (homegear)
Tasks: 105
Memory: 42.2M
CGroup: /system.slice/homegear.service
├─22297 /usr/bin/homegear -u homegear -g homegear -p /var/run/homegear/homegear.pid
└─23408 homegear -c /etc/homegear/ -rse
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.286 Debug (MQTT settings): retain set to 1
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.286 Debug (MQTT settings): processingThreadCount set to 5
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.286 Debug (MQTT settings): plainTopic set to 1
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.286 Debug (MQTT settings): jsonTopic set to 1
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.286 Debug (MQTT settings): jsonobjTopic set to 1
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.286 Debug (MQTT settings): enableSSL set to
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.286 Info: Setting allowed core file size to “4294967295” for user with id 0 and group with id 0.
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.287 Info: Core file size now is “4294967295”.
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.287 Info: Setting maximum thread priority to “4294967295” for user with id 0 and group with id 0.
Feb 27 12:12:32 raspberrypi homegear[22297]: 02/27/20 12:12:32.287 Info: Maximum thread priority now is “4294967295”.
Kann mir jemand helfen den Fehler abzustellen?
Grüße
Elmar
Zeig mal kurz welche Pakete du installiert hast: dpkg -l | grep homegear. Welche aus dieser Liste brauchst du wirklich?
Und, schau mal in deine rpcservers.conf. Welche der dort einkommentierten RPC-Server wird wirklich gebraucht?
Was sagt netstat -tulpn? Stell das debuglevel in der main.conf mal runter. Das gast du gerade auf 5, so wie’s aussieht.
So hier die Ausgabe:
Aktive Internetverbindungen (Nur Server)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      548/iobroker.js-con
tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      548/iobroker.js-con
tcp        0      0 192.168.178.26:2004     0.0.0.0:*               LISTEN      1065/io.hm-rpc.0
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      556/sshd
tcp6       0      0 :::2001                 :::*                    LISTEN      2540/homegear
tcp6       0      0 :::8081                 :::*                    LISTEN      851/io.admin.0
tcp6       0      0 :::2002                 :::*                    LISTEN      2540/homegear
tcp6       0      0 :::8082                 :::*                    LISTEN      1586/io.web.0
tcp6       0      0 :::2003                 :::*                    LISTEN      2540/homegear
tcp6       0      0 :::8084                 :::*                    LISTEN      1571/io.socketio.0
tcp6       0      0 :::22                   :::*                    LISTEN      556/sshd
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           349/avahi-daemon: r
udp        0      0 239.255.255.250:1900    0.0.0.0:*                           2540/homegear
udp        0      0 0.0.0.0:5003            0.0.0.0:*                           1616/io.mysensors.0
udp        0      0 0.0.0.0:60901           0.0.0.0:*                           349/avahi-daemon: r
udp        0      0 0.0.0.0:68              0.0.0.0:*                           546/dhcpcd
udp6       0      0 :::5353                 :::*                                349/avahi-daemon: r
udp6       0      0 :::34557                :::*                                349/avahi-daemon: r
udp6       0      0 :::546                  :::*                                546/dhcpcd
Den Server auf Port 2003 habe ich auskommentiert, jetzt ist der Fehler weg aber wieso war er überhaupt da? Den Debug-Level hatte ich auf 5 gesetzt, da ich auch ein Aktuallisierungsproblem bei ioBroker habe…
Der RPC-Server ist defaultmäßig an: Homegear/misc/Config Directory/rpcservers.conf at master · Homegear/Homegear · GitHub
Ich frage mich viel mehr, warum er nicht starten konnte, also warum der Port schon belegt gewesein sein soll.
