Recommendet Hardware to replace MAX CUBE
Hello there,
I tried already to replace my MAX Cube with Homegear and some CUL Stick, that didn’t work.
Now, the winter is coming and I need a solution for my broken MAX CUBE.
Can someone give me some recommendation for a Hardware to replace the MAX CUBE.
I am using openHAB on a Raspi 3+, I would like to connect my MAX thermostats, the MAX Wall thermostat and the window shutter.
I would be really thankful if someone could suggest some hardware, that would actually work with MAX and Homegear on a Raspi…
Thanks
Should be plenty of options:
https://doc.homegear.eu/homegear-homematicbidcos/configuration.html#communication-modules
Except of the homematic modules everyone of them should work.
I personally recommend the CC1101 SPI route.
Will have to build some more, but I sell these: CC1101 Raspberry Pi SPI Modul V0.4 | Homegear | Automation | cod.m Shop
