Auf meinem Pi2 startet homegear nicht mehr nach einem Update auf Version 0.7.5-1247. Es ein falscher Eintrag in dem service. Ich kann es nicht mit systemctl starten:
root@openhab:/lib/systemd/system# systemctl status homegear
● homegear.service - Homegear
Loaded: loaded (/lib/systemd/system/homegear.service; enabled)
Active: failed (Result: core-dump) since Do 2017-07-13 21:19:37 CEST; 24h ago
Main PID: 4379 (code=dumped, signal=SEGV)
Jul 13 21:28:45 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Jul 13 21:29:54 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Jul 13 21:29:55 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Jul 13 21:33:57 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Jul 13 21:33:58 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Jul 13 23:16:26 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Jul 13 23:16:33 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Jul 13 23:16:40 openhab systemd[1]: [/lib/systemd/system/homegear.service:18] Unknown lvalue 'TasksMax' in section 'Service'
Nachdem ich den TasksMax auskommentiert habe und daemon-reload ausgeführt, startet homegear mittels systemctl.
root@openhab:/lib/systemd/system# systemctl start homegear
Active: active (running) since Fr 2017-07-14 21:39:29 CEST; 17s ago
Main PID: 5251 (homegear)
CGroup: /system.slice/homegear.service
└─5251 /usr/bin/homegear -u homegear -g homegear -p /var/run/homegear/homegear.pid
Jul 14 21:39:29 openhab systemd[1]: Started Homegear.
Jul 14 21:39:30 openhab homegear[5251]: 07/14/17 21:39:30.615 Loading RPC server settings from /etc/homegear/rpcservers.conf
Jul 14 21:39:30 openhab homegear[5251]: 07/14/17 21:39:30.618 Loading RPC client settings from /etc/homegear/rpcclients.conf
Jul 14 21:39:40 openhab systemd[1]: Started Homegear.
Eventuell müsste man diesen Eintrag bei älteren Systemen entfernen. Auf meinem Pi läuft Raspian Jessie (8). Die Systemd Version ist 215. Der TasksMax Parameter wurde aber erst mit Version 228 eingeführt. systemd v228 NEWS
das TasksMax erklärt das Problem nicht. Da es noch kein vollständiges Raspbian Stretch gibt, läuft bei mir auch noch Jessie mit systemd-Version 215. Aus irgendeinem Grund ist Homegear bei dir beim Start mit Signal 11 abgestürzt: code=dumped, signal=SEGV.
In /var/lib/homegear müsste eine core-Datei liegen. Um Herauszufinden, was passiert ist, würde mir Folgendes helfen:
hmm, das hilft leider nicht weiter - es fehlen die Debuginformationen oder die Coredatei passt nicht zur installierten Homegearversion… Sind libc6-dbg und libstdc++6-4.9-dbg installiert? Wenn du TasksMax wieder reinnimmst, wird dann ein neues Coredump erstellt?
