So far I got the CCD, the touchscreen and the CUL drivers loaded and homegear starts up using the tty of the CUL. However I cannot pair any homematic devices doing:
families select 0
devices select central
pairing on
All devices were previously paired to the CCD/CUL with a FHEM installation, so I did a factory reset on all homematic devices. Is there any way to further debug the pairing?
I also just updated the firmware on the CCD to CUL_VER_161. Still no luck.
after a successful pairing you can see the new device with “ls”.
Also, on the CLI look into the file /var/log/homegear/homegear.log. If you need more information in the log file just change the logging level in the file /etc/homegear/main.conf at the line debugLevel = 6 (default is 4 and higher means more details)
