Problems with nanoCUL and Homegear
Hello All,
I’m havig difficulties to pair a MAX! thermostate to Homegear via a nanoCUL…
The CUL seems to be ok.
homematicbidcos.conf looks like this:
centralAddress = 0xFD21FB
[CUL]
id = traxCUL868
deviceType = cul
device = /dev/ttyUSB0
responseDelay = 40
minicom gives me the following information:
V
V 1.67 nanoCUL868
C99
72E2E0DE9CAFF0C
45000006002165A
C8930322F8340733
18166C43401876B
F85610AC2B181141
00597FE81350B00
When i start the pairing mode on the thermostate minicom gives me this output:
Z1700040019E029000000001001A04F45513136383837393614
A1776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE21
776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE22
1776D8E0C5159505DCDCDCCCED7D336E701C3B2A2C232AEE23
homgear.log says this:
01/22/19 12:08:44.965 Module HomeMatic BidCoS: Info: Pairing mode enabled.
01/22/19 12:08:44.976 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getInstallMode (2) Parameters:
01/22/19 12:08:44.985 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listDevices (2) Parameters:
01/22/19 12:08:44.989 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getDeviceInfo (2) Parameters:
01/22/19 12:08:44.992 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getAllSystemVariables (2) Parameters:
01/22/19 12:08:44.995 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: getAllScripts (2) Parameters:
01/22/19 12:08:51.211 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:08:51.245 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:06.249 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:06.253 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:21.257 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:21.261 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:36.268 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:36.272 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:09:44.948 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: setInstallMode (2) Parameters:
(Boolean) 0
(Integer) 60
(Integer) 1
01/22/19 12:09:44.994 Module HomeMatic BidCoS: Info: Pairing mode disabled.
01/22/19 12:09:51.275 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:09:51.279 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:06.284 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:06.288 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:21.292 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:21.295 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:36.300 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:36.303 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:10:51.307 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:10:51.311 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:05.101 RPC Server (Port 2001): Info: Client number 73 is calling RPC method: setInstallMode (2) Parameters:
(Boolean) 1
(Integer) 60
(Integer) 1
01/22/19 12:11:05.101 Module HomeMatic BidCoS: Info: Pairing mode enabled.
01/22/19 12:11:06.319 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.31.5:36850 accepted. Client number: 137
01/22/19 12:11:06.320 RPC Server (Port 2001): Info: RPC server client id for client number 137 is: 6
01/22/19 12:11:06.321 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:06.324 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:21.328 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:21.332 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:36.340 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:36.343 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:46.796 IPC Server: Info: Connection to IPC server’s client number 126 closed.
01/22/19 12:11:51.347 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:11:51.350 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:11:59.915 IPC Server: Info: IPC client 2 removed.
01/22/19 12:12:05.121 Module HomeMatic BidCoS: Info: Pairing mode disabled.
01/22/19 12:12:06.354 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:06.358 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:12:21.363 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:21.368 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:12:36.372 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:36.376 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:12:51.381 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:12:51.384 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:06.388 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:13:06.392 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:15.111 IPC Server: Info: Connection accepted. Client number: 147
01/22/19 12:13:15.112 IPC Server: Info: Client 3 successfully registered RPC method “cliOutput” (this method is registered by 1 client(s)).
01/22/19 12:13:15.113 IPC Server: Info: Client 3 successfully registered RPC method “cliOutput-3” (this method is registered by 1 client(s)).
01/22/19 12:13:21.396 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:13:21.400 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:36.125 IPC Server: Info: Connection to IPC server’s client number 147 closed.
01/22/19 12:13:36.404 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: ping (2) Parameters:
(String) 062e9544
01/22/19 12:13:36.407 RPC Server (Port 2001): Info: Client number 137 is calling RPC method: listBidcosInterfaces (2) Parameters:
01/22/19 12:13:37.859 IPC Server: Info: Connection accepted. Client number: 150
01/22/19 12:13:37.860 IPC Server: Info: Client 4 successfully registered RPC method “cliOutput” (this method is registered by 1 client(s)).
01/22/19 12:13:37.861 IPC Server: Info: Client 4 successfully registered RPC method “cliOutput-4” (this method is registered by 1 client(s)).
01/22/19 12:13:40.172 IPC Server: Info: Connection to IPC server’s client number 150 closed.
Any help is appreciated.
Thanks in Advance
Florian
Auch hier kann ich dir leider nicht helfen, aber wenn Du möchtest, kannst Du hier auch auf Deutsch fragen.
Thomas
See [solved] nanoCUL + Homegear + MAX pairing nicht möglich
