Probleme beim Aufsetzen von homegear
Hallo!
Habe vor kurzem probiert homegear auf meiner Debian-Installation zum Laufen zu bekommen (mit einem nanoCul). Soweit sah beim starten im log alles relativ gut aus:
03/11/17 10:02:20.931 Debug: debugLevel set to 5
03/11/17 10:02:20.931 Debug: memoryDebugging set to 1
03/11/17 10:02:20.931 Debug: devLog set to 0
03/11/17 10:02:20.931 Debug: enableCoreDumps set to 1
03/11/17 10:02:20.931 Debug: setDevicePermissions set to 1
03/11/17 10:02:20.931 Debug: workingDirectory set to /var/lib/homegear/
03/11/17 10:02:20.931 Debug: socketPath set to /var/run/homegear/
03/11/17 10:02:20.931 Debug: dataPath set to /var/lib/homegear/
03/11/17 10:02:20.931 readsPerScript set to
03/11/17 10:02:20.931 Debug: dataPathUser set to root
03/11/17 10:02:20.931 Debug: dataPathGroup set to root
03/11/17 10:02:20.931 Debug: databaseMemoryJournal set to 0
03/11/17 10:02:20.931 Debug: databaseWALJournal set to 1
03/11/17 10:02:20.931 Debug: databaseSynchronous set to 1
03/11/17 10:02:20.931 Debug: databaseMaxBackups set to 10
03/11/17 10:02:20.931 Debug: logfilePath set to /var/log/homegear/
03/11/17 10:02:20.931 Debug: enableUPnP set to 1
03/11/17 10:02:20.931 Debug: uPnPIpAddress set to 0.0.0.0
03/11/17 10:02:20.931 Debug: ssdpIpAddress set to 0.0.0.0
03/11/17 10:02:20.931 Debug: ssdpPort set to 1950
03/11/17 10:02:20.931 Debug: certPath set to /etc/homegear/homegear.crt
03/11/17 10:02:20.931 Debug: keyPath set to /etc/homegear/homegear.key
03/11/17 10:02:20.931 Debug: loadDHParamsFromFile set to 1
03/11/17 10:02:20.931 Debug: dhParamPath set to /etc/homegear/dh1024.pem
03/11/17 10:02:20.931 Debug: deviceDescriptionPath set to /etc/homegear/devices/
03/11/17 10:02:20.931 Debug: clientSettingsPath set to /etc/homegear/rpcclients.conf
03/11/17 10:02:20.932 Debug: serverSettingsPath set to /etc/homegear/rpcservers.conf
03/11/17 10:02:20.932 Debug: mqttSettingsPath set to /etc/homegear/mqtt.conf
03/11/17 10:02:20.932 Debug: familyConfigPath set to /etc/homegear/families/
03/11/17 10:02:20.932 Debug: phpIniPath set to /etc/homegear/php.ini
03/11/17 10:02:20.932 Debug: gpioPath set to /sys/class/gpio/
03/11/17 10:02:20.932 Debug: scriptPath set to /var/lib/homegear/scripts/
03/11/17 10:02:20.932 Debug: scriptPathUser set to root
03/11/17 10:02:20.932 Debug: scriptPathGroup set to root
03/11/17 10:02:20.932 Debug: flowsPath set to /var/lib/homegear/flows/
03/11/17 10:02:20.932 Debug: flowNodesPath set to /var/lib/homegear/flowNodes/
03/11/17 10:02:20.932 Debug: libraryPath set to /var/lib/homegear/modules/
03/11/17 10:02:20.932 Debug: firmwarePath set to /usr/share/homegear/firmware/
03/11/17 10:02:20.932 Debug: tempPath set to /var/lib/homegear/tmp/
03/11/17 10:02:20.932 Debug: lockFilePath set to /var/run/homegear/
03/11/17 10:02:20.932 "
03/11/17 10:02:20.932 Debug: Added replaceClientServerAddress xmlrpc_bin://127.0.0.1:1999 xmlrpc_bin://$remoteip:1999
03/11/17 10:02:20.932 Debug: Added replaceClientServerAddress http://127.0.0.1:9292/bidcos http://$remoteip:9292/bidcos
03/11/17 10:02:20.932 Debug: prioritizeThreads set to 1
03/11/17 10:02:20.932 Debug: workerThreadWindow set to 3000
03/11/17 10:02:20.932 Debug: scriptEngineMaxThreadsPerScript set to 4
03/11/17 10:02:20.932 Debug: scriptEngineMaxScriptsPerProcess set to 50
03/11/17 10:02:20.932 Debug: scriptEngineThreadCount set to 10
03/11/17 10:02:20.932 Debug: scriptEngineServerMaxConnections set to 10
03/11/17 10:02:20.932 Debug: flowsThreadCount set to 10
03/11/17 10:02:20.932 Debug: flowsServerMaxConnections set to 20
03/11/17 10:02:20.932 Debug: maxFlowsPerProcess set to 40
03/11/17 10:02:20.932 Debug: cliServerMaxConnections set to 50
03/11/17 10:02:20.932 Debug: rpcServerMaxConnections set to 50
03/11/17 10:02:20.932 Debug: rpcServerThreadPriority set to 0
03/11/17 10:02:20.932 Debug: rpcServerThreadPolicy set to 0
03/11/17 10:02:20.932 Debug: rpcClientMaxThreads set to 50
03/11/17 10:02:20.932 Debug: rpcClientThreadPriority set to 0
03/11/17 10:02:20.932 Debug: rpcClientThreadPolicy set to 0
03/11/17 10:02:20.932 Debug: workerThreadPriority set to 0
03/11/17 10:02:20.932 Debug: workerThreadPolicy set to 0
03/11/17 10:02:20.932 Debug: physicalInterfaceThreadPriority set to 45
03/11/17 10:02:20.932 Debug: physicalInterfaceThreadPolicy set to 1
03/11/17 10:02:20.932 Debug: packetReceivedThreadPriority set to 0
03/11/17 10:02:20.932 Debug: packetReceivedThreadPolicy set to 0
03/11/17 10:02:20.932 Debug: eventThreadCount set to 5
03/11/17 10:02:20.932 Debug: eventThreadPriority set to 0
03/11/17 10:02:20.932 Debug: eventThreadPolicy set to 0
03/11/17 10:02:20.932 Loading RPC server settings from /etc/homegear/rpcservers.conf
03/11/17 10:02:20.932 Debug: interface of server RPCServer1 set to 0.0.0.0
03/11/17 10:02:20.932 Debug: port of server RPCServer1 set to 3001
03/11/17 10:02:20.932 Debug: xmlrpcServer of server RPCServer1 set to 1
03/11/17 10:02:20.932 Debug: jsonrpcServer of server RPCServer1 set to 1
03/11/17 10:02:20.932 Debug: webServer of server RPCServer1 set to 1
03/11/17 10:02:20.932 Debug: contentPath of RPC server RPCServer1 set to /var/lib/homegear/www/rpc/
03/11/17 10:02:20.932 Debug: webSocket of server RPCServer1 set to 0
03/11/17 10:02:20.932 Debug: ssl of server RPCServer1 set to 0
03/11/17 10:02:20.932 Debug: authType of server RPCServer1 set to 0
03/11/17 10:02:20.932 Debug: websocketauthtype of server RPCServer1 set to 2
03/11/17 10:02:20.932 Debug: webSocket of server RPCServer1 set to 1
03/11/17 10:02:20.932 Debug: webSocket of server RPCServer3 set to 1
03/11/17 10:02:20.932 Loading RPC client settings from /etc/homegear/rpcclients.conf
03/11/17 10:02:20.932 Debug: hostname of RPC client ExampleClient set to myhostname
03/11/17 10:02:20.932 Debug: caFile of RPC client ExampleClient set to /path/to/ca-certficate
03/11/17 10:02:20.932 Debug: verifyCertificate of RPC client ExampleClient set to 1
03/11/17 10:02:20.932 Debug: forceSSL of RPC client ExampleClient set to 1
03/11/17 10:02:20.932 Debug: authType of RPC client ExampleClient set to 1
03/11/17 10:02:20.932 Debug: userName of RPC client ExampleClient set to myuser
03/11/17 10:02:20.932 Debug: password of RPC client ExampleClient was set.
03/11/17 10:02:20.932 Debug: retries of RPC client ExampleClient set to 3
03/11/17 10:02:20.932 Debug (MQTT settings): enabled set to 0
03/11/17 10:02:20.932 Debug (MQTT settings): brokerHostname set to localhost
03/11/17 10:02:20.932 Debug (MQTT settings): brokerPort set to 1883
03/11/17 10:02:20.932 Debug (MQTT settings): clientName set to Homegear
03/11/17 10:02:20.932 Debug (MQTT settings): homegearId set to 1234-5678-9abc
03/11/17 10:02:20.932 Debug (MQTT settings): retain set to 1
03/11/17 10:02:20.932 Debug (MQTT settings): processingThreadCount set to 5
03/11/17 10:02:20.932 Debug (MQTT settings): plainTopic set to 1
03/11/17 10:02:20.932 Debug (MQTT settings): jsonTopic set to 1
03/11/17 10:02:20.932 Debug (MQTT settings): jsonobjTopic set to 1
03/11/17 10:02:20.932 Debug (MQTT settings): enableSSL set to
03/11/17 10:02:20.932 Starting Homegear...
03/11/17 10:02:20.932 Homegear version 0.6.19-956
03/11/17 10:02:20.932 Git commit SHA of libhomegear-base: -
03/11/17 10:02:20.932 Git branch of libhomegear-base:     -
03/11/17 10:02:20.932 Git commit SHA of Homegear:         -
03/11/17 10:02:20.932 Git branch of Homegear:             -
03/11/17 10:02:20.932 Info: Setting allowed core file size to "18446744073709551615" for user with id 0 and group with id 0.
03/11/17 10:02:20.932 Info: Core file size now is "18446744073709551615".
03/11/17 10:02:20.932 Info: Setting maximum thread priority to "0" for user with id 0 and group with id 0.
03/11/17 10:02:20.932 Info: Maximum thread priority now is "0".
03/11/17 10:02:20.933 Info: Backing up database...
03/11/17 10:02:21.172 Initializing database...
03/11/17 10:02:21.172 Debug: Loading licensing modules
03/11/17 10:02:21.172 Debug: Loading family modules
03/11/17 10:02:21.172 Info: Loading family module mod_miscellaneous.so
03/11/17 10:02:21.173 /etc/homegear/families/miscellaneous.conf
03/11/17 10:02:21.173 Module Miscellaneous: Debug: Loading module...
03/11/17 10:02:21.173 Info: Loading family module mod_homematicbidcos.so
03/11/17 10:02:21.175 /etc/homegear/families/homematicbidcos.conf
03/11/17 10:02:21.175 Debug: Loading section "General"
03/11/17 10:02:21.175 Debug: Family setting centraladdress set to 0xfd2233
03/11/17 10:02:21.175 Debug: Family setting rfkey set to 0011ff33445566778899aabbccddeeff
03/11/17 10:02:21.175 Debug: Family setting currentrfkeyindex set to 1
03/11/17 10:02:21.175 Debug: Family setting processbroadcastwithaesenabled set to false
03/11/17 10:02:21.175 Debug: Loading section "CUL"
03/11/17 10:02:21.175 Debug: id set to ECT-CUL
03/11/17 10:02:21.175 Debug: default set to 1
03/11/17 10:02:21.175 Debug: deviceType set to cul
03/11/17 10:02:21.175 Debug: device set to /dev/ttyUSB0
03/11/17 10:02:21.175 Debug: responseDelay set to 95
03/11/17 10:02:21.175 Module HomeMatic BidCoS: Debug: Loading module...
03/11/17 10:02:21.175 Module HomeMatic BidCoS: Debug: Creating physical device. Type defined in homematicbidcos.conf is: cul
03/11/17 10:02:21.175 Warning: Running as root. The authors of Homegear recommend running Homegear as user.
03/11/17 10:02:21.175 Starting script engine server...
03/11/17 10:02:21.179 Script Engine Server: Debug: Waiting for script engine server's client threads to finish.
03/11/17 10:02:21.179 Initializing licensing controller...
03/11/17 10:02:21.179 Loading licensing controller data...
03/11/17 10:02:21.179 Loading devices...
03/11/17 10:02:21.179 Loading XML RPC devices...
03/11/17 10:02:21.179 Loading XML RPC device /etc/homegear/devices/0/rf_bl.xml
03/11/17 10:02:21.181 Loading XML RPC device /etc/homegear/devices/0/rf_pbi.xml
03/11/17 10:02:21.181 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644.xml
03/11/17 10:02:21.183 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_le_v1_3.xml
03/11/17 10:02:21.184 Loading XML RPC device /etc/homegear/devices/0/rf_resc_win_pcb_sc.xml
03/11/17 10:02:21.184 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_e_v1_7.xml
03/11/17 10:02:21.185 Loading XML RPC device /etc/homegear/devices/0/rf_rc_19.xml
03/11/17 10:02:21.185 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir_v1_5.xml
03/11/17 10:02:21.185 Loading XML RPC device /etc/homegear/devices/0/rf_s_644.xml
03/11/17 10:02:21.186 Loading XML RPC device /etc/homegear/devices/0/rf_rc_dis.xml
03/11/17 10:02:21.186 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_7.xml
03/11/17 10:02:21.187 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644_le_v2_4.xml
03/11/17 10:02:21.190 Loading XML RPC device /etc/homegear/devices/0/rf_fs_ba.xml
03/11/17 10:02:21.190 Loading XML RPC device /etc/homegear/devices/0/rf_scd_v1_0.xml
03/11/17 10:02:21.190 Loading XML RPC device /etc/homegear/devices/0/rf_wds30_ot2.xml
03/11/17 10:02:21.191 Loading XML RPC device /etc/homegear/devices/0/rf_rc.xml
03/11/17 10:02:21.191 Loading XML RPC device /etc/homegear/devices/0/rf_s_8_ba.xml
03/11/17 10:02:21.191 Loading XML RPC device /etc/homegear/devices/0/rf_dis_ep_wm55.xml
03/11/17 10:02:21.192 Loading XML RPC device /etc/homegear/devices/0/rf_cc_vd.xml
03/11/17 10:02:21.192 Loading XML RPC device /etc/homegear/devices/0/rf_rhs_le_v1_6.xml
03/11/17 10:02:21.192 Loading XML RPC device /etc/homegear/devices/0/rf_s_4_ba.xml
03/11/17 10:02:21.193 Loading XML RPC device /etc/homegear/devices/0/rf_rc-sec4-2.xml
03/11/17 10:02:21.193 Loading XML RPC device /etc/homegear/devices/0/rf_rep.xml
03/11/17 10:02:21.194 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_le_v1_0.xml
03/11/17 10:02:21.194 Loading XML RPC device /etc/homegear/devices/0/rf_sen_ep.xml
03/11/17 10:02:21.194 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644.xml
03/11/17 10:02:21.197 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sfa.xml
03/11/17 10:02:21.197 Loading XML RPC device /etc/homegear/devices/0/rf_ks550.xml
03/11/17 10:02:21.198 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw_le_v2_4.xml
03/11/17 10:02:21.198 Loading XML RPC device /etc/homegear/devices/0/rf_4dis.xml
03/11/17 10:02:21.199 Loading XML RPC device /etc/homegear/devices/0/rf_cfm.xml
03/11/17 10:02:21.200 Loading XML RPC device /etc/homegear/devices/0/rf_bl_le_v2_3.xml
03/11/17 10:02:21.201 Loading XML RPC device /etc/homegear/devices/0/rf_es_pmsw.xml
03/11/17 10:02:21.202 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn_bom.xml
03/11/17 10:02:21.204 Loading XML RPC device /etc/homegear/devices/0/rf_dis_wm55.xml
03/11/17 10:02:21.204 Loading XML RPC device /etc/homegear/devices/0/rf_tis_le_v1_0.xml
03/11/17 10:02:21.204 Loading XML RPC device /etc/homegear/devices/0/rf_rc_2_fm.xml
03/11/17 10:02:21.204 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v2_3.xml
03/11/17 10:02:21.205 Loading XML RPC device /etc/homegear/devices/0/rf_s_ba.xml
03/11/17 10:02:21.205 Loading XML RPC device /etc/homegear/devices/0/rf_cm.xml
03/11/17 10:02:21.206 Loading XML RPC device /etc/homegear/devices/0/rf_keymatic.xml
03/11/17 10:02:21.206 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_3.xml
03/11/17 10:02:21.207 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644_le_v2_4.xml
03/11/17 10:02:21.210 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644.xml
03/11/17 10:02:21.210 Loading XML RPC device /etc/homegear/devices/0/rf_tis.xml
03/11/17 10:02:21.210 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd_schueco.xml
03/11/17 10:02:21.210 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_v1_5.xml
03/11/17 10:02:21.211 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2.xml
03/11/17 10:02:21.211 Loading XML RPC device /etc/homegear/devices/0/rf_em_8.xml
03/11/17 10:02:21.211 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1tconf_644_le_v2_4.xml
03/11/17 10:02:21.214 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1l_644.xml
03/11/17 10:02:21.216 Loading XML RPC device /etc/homegear/devices/0/rf_d_le_v1_9.xml
03/11/17 10:02:21.217 Loading XML RPC device /etc/homegear/devices/0/rf_ws550.xml
03/11/17 10:02:21.217 Loading XML RPC device /etc/homegear/devices/0/rf_sci_3.xml
03/11/17 10:02:21.217 Loading XML RPC device /etc/homegear/devices/0/rf_rhs.xml
03/11/17 10:02:21.217 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644.xml
03/11/17 10:02:21.220 Loading XML RPC device /etc/homegear/devices/0/rf_pb-2-wm55_ge_v1_4.xml
03/11/17 10:02:21.220 Loading XML RPC device /etc/homegear/devices/0/rf_rgbw.xml
03/11/17 10:02:21.221 Loading XML RPC device /etc/homegear/devices/0/rf_roto_wdf_solar.xml
03/11/17 10:02:21.222 Loading XML RPC device /etc/homegear/devices/0/rf_rc-4-2.xml
03/11/17 10:02:21.222 Loading XML RPC device /etc/homegear/devices/0/rf_sc.xml
03/11/17 10:02:21.223 Loading XML RPC device /etc/homegear/devices/0/rf_sc_le_v1_6.xml
03/11/17 10:02:21.223 Loading XML RPC device /etc/homegear/devices/0/rf_sec_mdir.xml
03/11/17 10:02:21.223 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_644_le_v2_4.xml
03/11/17 10:02:21.225 Loading XML RPC device /etc/homegear/devices/0/rf_s550ia.xml
03/11/17 10:02:21.225 Loading XML RPC device /etc/homegear/devices/0/rf_bl_644.xml
03/11/17 10:02:21.227 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc_le_v1_9.xml
03/11/17 10:02:21.228 Loading XML RPC device /etc/homegear/devices/0/rf_rc-4-3_single_on.xml
03/11/17 10:02:21.229 Loading XML RPC device /etc/homegear/devices/0/rf_ou_led16_ge_v1_1.xml
03/11/17 10:02:21.229 Loading XML RPC device /etc/homegear/devices/0/rf_cf.xml
03/11/17 10:02:21.230 Loading XML RPC device /etc/homegear/devices/0/rf_es_tx_wm_le_v1_0.xml
03/11/17 10:02:21.230 Loading XML RPC device /etc/homegear/devices/0/rf_ash550.xml
03/11/17 10:02:21.230 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd.xml
03/11/17 10:02:21.230 Loading XML RPC device /etc/homegear/devices/0/rf_rc_12.xml
03/11/17 10:02:21.230 Loading XML RPC device /etc/homegear/devices/0/rf_rd.xml
03/11/17 10:02:21.231 Loading XML RPC device /etc/homegear/devices/0/rf_s_1conf_644_le_v2_1.xml
03/11/17 10:02:21.231 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir_wm55.xml
03/11/17 10:02:21.231 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644.xml
03/11/17 10:02:21.234 Loading XML RPC device /etc/homegear/devices/0/rf_cc_tc.xml
03/11/17 10:02:21.236 Loading XML RPC device /etc/homegear/devices/0/rf_st_6_sh.xml
03/11/17 10:02:21.236 Loading XML RPC device /etc/homegear/devices/0/rf_sen_wa_od.xml
03/11/17 10:02:21.236 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1t_fm_lf.xml
03/11/17 10:02:21.237 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_0.xml
03/11/17 10:02:21.238 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t.xml
03/11/17 10:02:21.238 Loading XML RPC device /etc/homegear/devices/0/rf_tc_it_wm-w-eu.xml
03/11/17 10:02:21.242 Loading XML RPC device /etc/homegear/devices/0/rf_ddc.xml
03/11/17 10:02:21.243 Loading XML RPC device /etc/homegear/devices/0/rf_s_mega168.xml
03/11/17 10:02:21.243 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sco.xml
03/11/17 10:02:21.243 Loading XML RPC device /etc/homegear/devices/0/rf_sen_db.xml
03/11/17 10:02:21.243 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_0.xml
03/11/17 10:02:21.244 Loading XML RPC device /etc/homegear/devices/0/rf_sc_e_v1_7.xml
03/11/17 10:02:21.245 Loading XML RPC device /etc/homegear/devices/0/rf_oligo_smart_iq.xml
03/11/17 10:02:21.251 Loading XML RPC device /etc/homegear/devices/0/rf_dim_1pwm_644_le_v2_4.xml
03/11/17 10:02:21.253 Loading XML RPC device /etc/homegear/devices/0/rf_rc_single_on.xml
03/11/17 10:02:21.253 Loading XML RPC device /etc/homegear/devices/0/rf_rc-key4-2.xml
03/11/17 10:02:21.254 Loading XML RPC device /etc/homegear/devices/0/rf_dim_t_le_v1_9.xml
03/11/17 10:02:21.254 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644.xml
03/11/17 10:02:21.255 Loading XML RPC device /etc/homegear/devices/0/rf_s_2conf_644.xml
03/11/17 10:02:21.256 Loading XML RPC device /etc/homegear/devices/0/rf_hm-wds100-c6-o-2.xml
03/11/17 10:02:21.256 Loading XML RPC device /etc/homegear/devices/0/rf_winmatic.xml
03/11/17 10:02:21.257 Loading XML RPC device /etc/homegear/devices/0/rf_cfm_tw.xml
03/11/17 10:02:21.258 Loading XML RPC device /etc/homegear/devices/0/rf_sen_mdir.xml
03/11/17 10:02:21.258 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2l_644_le_v2_4.xml
03/11/17 10:02:21.261 Loading XML RPC device /etc/homegear/devices/0/rf_es_tx_wm.xml
03/11/17 10:02:21.261 Loading XML RPC device /etc/homegear/devices/0/rf_bl_conf_644_e_v2_1.xml
03/11/17 10:02:21.262 Loading XML RPC device /etc/homegear/devices/0/rf_s.xml
03/11/17 10:02:21.263 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sd_2.xml
03/11/17 10:02:21.263 Loading XML RPC device /etc/homegear/devices/0/rf_cc_rt_dn.xml
03/11/17 10:02:21.264 Loading XML RPC device /etc/homegear/devices/0/rf_dim_2t_644.xml
03/11/17 10:02:21.267 Loading XML RPC device /etc/homegear/devices/0/rf_wds_v1_1.xml
03/11/17 10:02:21.267 Loading XML RPC device /etc/homegear/devices/0/rf_rd_le_v1_3.xml
03/11/17 10:02:21.267 Loading XML RPC device /etc/homegear/devices/0/rf_sen_li.xml
03/11/17 10:02:21.267 Loading XML RPC device /etc/homegear/devices/0/rf_sec_sir_wm.xml
03/11/17 10:02:21.269 Loading XML RPC device /etc/homegear/devices/0/rf_swi.xml
03/11/17 10:02:21.269 Loading XML RPC device /etc/homegear/devices/0/rf_wds40_th_i_2.xml
03/11/17 10:02:21.269 Loading XML RPC device /etc/homegear/devices/0/rf_d.xml
03/11/17 10:02:21.270 Loading XML RPC device /etc/homegear/devices/0/rf_s_le_v1_5.xml
03/11/17 10:02:21.271 Loading device 1
03/11/17 10:02:21.271 Module HomeMatic BidCoS: Info: Central address set to 0xFD2233.
03/11/17 10:02:21.271 Loading XML RPC devices...
03/11/17 10:02:21.271 Loading XML RPC device /etc/homegear/devices/254/Template.xml
03/11/17 10:02:21.271 Loading device 3
03/11/17 10:02:21.271 Start listening for packets...
Als ich jedoch probierte danach über homegear -r mich zu verbinden bekam ich folgenden output:
03/11/17 10:09:42.686 Debug: debugLevel set to 5
03/11/17 10:09:42.686 Debug: memoryDebugging set to 1
03/11/17 10:09:42.686 Debug: devLog set to 0
03/11/17 10:09:42.686 Debug: enableCoreDumps set to 1
03/11/17 10:09:42.686 Debug: setDevicePermissions set to 1
03/11/17 10:09:42.686 Debug: workingDirectory set to /var/lib/homegear/
03/11/17 10:09:42.686 Debug: socketPath set to /var/run/homegear/
03/11/17 10:09:42.686 Debug: dataPath set to /var/lib/homegear/
03/11/17 10:09:42.686 readsPerScript set to
03/11/17 10:09:42.686 Debug: dataPathUser set to root
03/11/17 10:09:42.686 Debug: dataPathGroup set to root
03/11/17 10:09:42.686 Debug: databaseMemoryJournal set to 0
03/11/17 10:09:42.686 Debug: databaseWALJournal set to 1
03/11/17 10:09:42.686 Debug: databaseSynchronous set to 1
03/11/17 10:09:42.686 Debug: databaseMaxBackups set to 10
03/11/17 10:09:42.686 Debug: logfilePath set to /var/log/homegear/
03/11/17 10:09:42.686 Debug: enableUPnP set to 1
03/11/17 10:09:42.686 Debug: uPnPIpAddress set to 0.0.0.0
03/11/17 10:09:42.686 Debug: ssdpIpAddress set to 0.0.0.0
03/11/17 10:09:42.686 Debug: ssdpPort set to 1950
03/11/17 10:09:42.686 Debug: certPath set to /etc/homegear/homegear.crt
03/11/17 10:09:42.686 Debug: keyPath set to /etc/homegear/homegear.key
03/11/17 10:09:42.686 Debug: loadDHParamsFromFile set to 1
03/11/17 10:09:42.686 Debug: dhParamPath set to /etc/homegear/dh1024.pem
03/11/17 10:09:42.686 Debug: deviceDescriptionPath set to /etc/homegear/devices/
03/11/17 10:09:42.686 Debug: clientSettingsPath set to /etc/homegear/rpcclients.conf
03/11/17 10:09:42.686 Debug: serverSettingsPath set to /etc/homegear/rpcservers.conf
03/11/17 10:09:42.687 Debug: mqttSettingsPath set to /etc/homegear/mqtt.conf
03/11/17 10:09:42.687 Debug: familyConfigPath set to /etc/homegear/families/
03/11/17 10:09:42.687 Debug: phpIniPath set to /etc/homegear/php.ini
03/11/17 10:09:42.687 Debug: gpioPath set to /sys/class/gpio/
03/11/17 10:09:42.687 Debug: scriptPath set to /var/lib/homegear/scripts/
03/11/17 10:09:42.687 Debug: scriptPathUser set to root
03/11/17 10:09:42.687 Debug: scriptPathGroup set to root
03/11/17 10:09:42.687 Debug: flowsPath set to /var/lib/homegear/flows/
03/11/17 10:09:42.687 Debug: flowNodesPath set to /var/lib/homegear/flowNodes/
03/11/17 10:09:42.687 Debug: libraryPath set to /var/lib/homegear/modules/
03/11/17 10:09:42.687 Debug: firmwarePath set to /usr/share/homegear/firmware/
03/11/17 10:09:42.687 Debug: tempPath set to /var/lib/homegear/tmp/
03/11/17 10:09:42.687 Debug: lockFilePath set to /var/run/homegear/
03/11/17 10:09:42.687 "
03/11/17 10:09:42.687 Debug: Added replaceClientServerAddress xmlrpc_bin://127.0.0.1:1999 xmlrpc_bin://$remoteip:1999
03/11/17 10:09:42.687 Debug: Added replaceClientServerAddress http://127.0.0.1:9292/bidcos http://$remoteip:9292/bidcos
03/11/17 10:09:42.687 Debug: prioritizeThreads set to 1
03/11/17 10:09:42.687 Debug: workerThreadWindow set to 3000
03/11/17 10:09:42.687 Debug: scriptEngineMaxThreadsPerScript set to 4
03/11/17 10:09:42.687 Debug: scriptEngineMaxScriptsPerProcess set to 50
03/11/17 10:09:42.687 Debug: scriptEngineThreadCount set to 10
03/11/17 10:09:42.687 Debug: scriptEngineServerMaxConnections set to 10
03/11/17 10:09:42.687 Debug: flowsThreadCount set to 10
03/11/17 10:09:42.687 Debug: flowsServerMaxConnections set to 20
03/11/17 10:09:42.687 Debug: maxFlowsPerProcess set to 40
03/11/17 10:09:42.687 Debug: cliServerMaxConnections set to 50
03/11/17 10:09:42.687 Debug: rpcServerMaxConnections set to 50
03/11/17 10:09:42.687 Debug: rpcServerThreadPriority set to 0
03/11/17 10:09:42.687 Debug: rpcServerThreadPolicy set to 0
03/11/17 10:09:42.687 Debug: rpcClientMaxThreads set to 50
03/11/17 10:09:42.687 Debug: rpcClientThreadPriority set to 0
03/11/17 10:09:42.687 Debug: rpcClientThreadPolicy set to 0
03/11/17 10:09:42.687 Debug: workerThreadPriority set to 0
03/11/17 10:09:42.687 Debug: workerThreadPolicy set to 0
03/11/17 10:09:42.687 Debug: physicalInterfaceThreadPriority set to 45
03/11/17 10:09:42.687 Debug: physicalInterfaceThreadPolicy set to 1
03/11/17 10:09:42.687 Debug: packetReceivedThreadPriority set to 0
03/11/17 10:09:42.687 Debug: packetReceivedThreadPolicy set to 0
03/11/17 10:09:42.687 Debug: eventThreadCount set to 5
03/11/17 10:09:42.687 Debug: eventThreadPriority set to 0
03/11/17 10:09:42.687 Debug: eventThreadPolicy set to 0
Debug: Trying to connect...
03/11/17 10:09:42.687 Debug: Socket closed. Trying again...
03/11/17 10:09:44.688 Could not connect to socket. Error: No such file or directory
Hat vielleicht jemand eine Idee woran das Problem liegen kann?
Hmmm… Das sieht alles gut aus. Was “funktioniert” denn nicht?
Vor allem das ich nur einen Fehler bekomme, wenn ich homegear -r ausführe. Ist am Ende vom zweiten Log ersichtlich (Socket error)
Hmm. Der Socket Error ist der einzige Fehler, den ich sehe. Das andere sind alles übliche Debugmeldungen. Anscheinend hast du das Debuglevel recht hoch. 3 sollte da in der main.conf normal sein.
Welchen Weg bist du denn fürs Installieren gegangen?
Bin da nach dieser Anleitung hier vorgegangen:
https://doc.homegear.eu/data/homegear/installation.html
Was hast du für ein Debian und welche Pakete hast du installiert?
Folgende Version:
Distributor ID: Debian
Description: Debian GNU/Linux 8.7 (jessie)
Release: 8.7
Codename: jessie
Aktuell hab ich nur homegear-homematicbidcos installiert. Der nanoCul war übrigens davor schon an einer CCU im Einsatz - sollte also somit funktionieren.
  • Kannst du sicher stellen, dass du die Jessie-Pakete installiert hast?
  • Hast du homegear als Dienst gestartet oder von Hand?
  • Was sagt service --status-all?
  • Wie sieht das Log mit Debuglevel 3 aus?
Weil ausser deinem homegear -r Fehler sehe ich keinen…
Nach ein paar mal neu starten und ab/anstecken des cul scheint homegear nun problemlos zu starten.
Hab nun leider das Problem das beim pairing nicht wirklich viel passiert. Hab homegear in den pairing modus versetzt - jedoch passiert dann nicht viel weiter.
Log Datei (Level 3):
03/12/17 10:32:31.984 Starting Homegear...
03/12/17 10:32:31.984 Homegear version 0.6.19-956
03/12/17 10:32:31.984 Git commit SHA of libhomegear-base: -
03/12/17 10:32:31.984 Git branch of libhomegear-base:     -
03/12/17 10:32:31.984 Git commit SHA of Homegear:         -
03/12/17 10:32:31.984 Git branch of Homegear:             -
03/12/17 10:32:32.363 Loading device 1
03/12/17 10:32:32.364 Loading device 3
03/12/17 10:32:34.769 Startup complete. Waiting for physical interfaces to connect.
03/12/17 10:32:34.769 All physical interfaces are connected now.
Ganz ganz komisch.
Beim Pairing wäre Loglevel 5 interessant, weil du nur damit die Pakete die hoffentlich empfangen werden, sehen kannst.
Hätte hier mal einen Ausschnitte eines Logs vom Verbinden/Versuch des Pairens über das CLI:
03/12/17 19:16:22.512 Info: CLI connection accepted. Client number: 107
03/12/17 19:16:22.512 Listening for incoming commands from client number 107.
03/12/17 19:16:46.281 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
03/12/17 19:16:46.301 Debug: Sleeping 2926ms before sending response.
03/12/17 19:16:49.227 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
03/12/17 19:16:49.328 UPnP Server: Debug: Sending notify packets.
03/12/17 19:16:49.328 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
03/12/17 19:16:49.348 Debug: Sleeping 2096ms before sending response.
03/12/17 19:16:51.445 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
03/12/17 19:16:51.545 UPnP Server: Debug: Sending notify packets.
03/12/17 19:17:44.605 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
03/12/17 19:17:44.625 Debug: Sleeping 3491ms before sending response.
03/12/17 19:17:48.116 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
03/12/17 19:17:48.216 UPnP Server: Debug: Sending notify packets.
03/12/17 19:17:48.217 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
03/12/17 19:17:48.237 Debug: Sleeping 4444ms before sending response.
03/12/17 19:17:52.681 UPnP Server: Debug: Sending discovery response packets to 239.255.255.250 on port 1900
03/12/17 19:17:52.782 UPnP Server: Debug: Sending notify packets.
03/12/17 19:18:12.613 Debug (ECT-CUL): Packet 0D2E84101A4D290000000602C800 enters raisePacketReceived.
03/12/17 19:18:12.613 Debug (ECT-CUL): Packet 0D2E84101A4D290000000602C800 is now passed to the EventHandler.
03/12/17 19:18:12.587 HomeMatic BidCoS packet received (ECT-CUL, RSSI: -75 dBm): 0D2E84101A4D290000000602C800
03/12/17 19:18:12.621 Devlog (ECT-CUL): Getting peer for packet 0D2E84101A4D290000000602C800.
03/12/17 19:18:12.621 Devlog (ECT-CUL): Packet 0D2E84101A4D290000000602C800 is now passed to _receivedPackets.set.
03/12/17 19:18:12.621 Devlog (ECT-CUL): _receivedPackets.set finished.
03/12/17 19:18:12.621 Debug (ECT-CUL): Packet processing of packet 0D2E84101A4D290000000602C800 took 8 ms.
03/12/17 19:18:41.678 UPnP Server: Debug: Discovery packet received from 239.255.255.250:1900
03/12/17 19:18:41.698 Debug: Sleeping 2058ms before sending response.
Meine Eingabe in die Konsole:
> families select 0
(Family)> pairing on
(Family)> peers list
(Family)>
Ganz ganz komische Nummer… @sathya, kannst du daszu was sagen?
Hab nun auch noch den nanoCul noch mit screen getestet und bekomme dort folgenden output (gestartet mit screen /dev/ttyUSB0 38400).
Eingabe von V:
V 1.67 nanoCUL868
Eingabe von C35:
C35 = 0D / 13
Eingabe von X67:
p 3 368 352 544 592 11 6 6 23 54934014C00164
T54267D67FF23
p 3 400 352 576 544 11 6 6 23 54935F4CFFF348
T54267D77FFFA
T54264269DC23
p 3 352 400 528 592 12 6 6 23 5493508D2DC86C
T54264279DCFA
T542643690023
p 3 384 336 576 544 12 6 6 23 549350ED200194
T5426437900FA
T54264B670023
p 3 320 400 544 576 11 6 6 23 549352CCF001C4
T54264B7700FA
T542644690023
p 3 320 432 496 608 11 6 6 23 5493510D200198
T5426447900FA
T54264B670023
p 3 368 352 560 576 12 6 6 23 549352CCF001C4
T54264B7700FA
T54267E670024
p 3 384 336 576 560 12 6 6 23 54935F8CF0035C
T54267E7700FA
T54267E7700FA
Auf der CCU2 zeigt sich ein gleiches Bild - kann dort den Stick ohne große Probleme verwenden.
Hallo @TheEggi,
Im ersten Log hängt er offenbar beim Initialisieren des nanoCUL - warum auch immer. Deswegen konntest du über “homegear -r” auch nicht das CLI starten. Wenn du den nanoCUL aus der Konfigurationsdatei entfernt hättest, hätte der Start auch sehr wahrscheinlich geklappt.
Im Log vom Pairing sehe ich kein Anlernpaket - so als ob keine Anlerntaste am Gerät gedrückt wurde. Hast du eine HomeMatic-Fernbedienung? Wenn du diese betätigst, werden die Pakete zuverlässig im Log angezeigt? Hast du ein 868MHz-Funkmodul? Die Symptomatik würde auch dazu passen, dass du ein 433MHz-Modul verwendest.
Das Problem ist wohl ein ganz anderes - meine Annahme war, dass unter Homegear bei der Homematic-Family auch die FHT20 (im Grunde nur zwei bestehende FHT80b) supported werden - was aber nicht der Fall ist. Habe das ganze nun mit Max!-Geräten getested und die wurden ohne Probleme erkannt.
Gibt es schon jemanden der FHT20-Geräte erfolgreich eingebunden hat?
Das geht über ein PHP-Skript bzw. ein PHP-Gerät, welches die Daten vom CUL auswertet. Siehe dazu das OpenWeatherMap-Beispiel (https://github.com/Homegear/Homegear-OpenWeatherMap/blob/master/OpenWeatherMap.xml) und das FS20-Beispiel in der Referenz (https://ref.homegear.eu/php.html#HomegearSerialreadline).
Hab nun noch ein wenig weiter herum probiert und bin leider zu folgendem Problem gekommen:
  • Habe einen nanoCul der mit den Max!-Komponenten problemlos funktioniert, wenn ich jedoch den genau gleichen Stick für Homematic verwenden möchte (und natürlich nur exklusive für Homematic) bleibt Homegear beim Startup mit dem oben geposteten log hängen.
  • Homematic bekomme ich nur zum Laufen, wenn ich den CC1101 direkt an den Raspberry anhänge.
