HW: MAX cube flashed with a-culfw 1.26.8 (latest) or 1.25.01 configured as CUL or CUNx
SW: homegear stable or nightly running in docker (responseDelay=40)
I have the following issue observed in the log:
02/22/21 12:10:39.672 Module MAX: Debug: Sending packet 0B030540FD11CF140C2E016B immediately, because it seems it is no response (no packet information found).
If the third attempt is failed then I got the “no answer from device” and set-value operation is failed on the thermostat.
The whole messages is attached:
nopacketinfo.log (4.3 KB)
The same is working with nanoCUL (hw flased with culfw 1.67) with same devices, same config, same homegear versions.
- Do you have an idea what could be wrong here?
- Is there any possibility to get older homegear version from dockerhub to try eg. by referreing to a version eg. 0.7.30 ?
I have seen several posts that MAXCube still alive with a-culfw and homegear, so I would like to have a try to understand the problem here and try to fix it. ![]()
Thanks
Regards
Tamás
Sofar nothing to troubleshoot on this further.
