ich versuche mit dem Homematic Konfigurator meine Aktoren einzubinden.
Leider funktioniert dies nicht.
Es kommt die Meldung ‘Die Webseite wurde nicht gefunden’ Http 404
Unten rechts in der Ecke steht aber 'Verbunden mit xmlrpc://192.168.100.125:2001’
Im Log steht
08/18/14 12:13:28.567 Info: Loading family module mod_homematicbidcos.so
08/18/14 12:13:28.673 Info: Loading family module mod_homematicwired.so
08/18/14 12:13:28.743 Info: Loading family module mod_max.so
08/18/14 12:13:28.983 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Info: Enabling AES encryption for communication with HM-CFG-LAN.
08/18/14 12:13:28.984 Initializing database...
08/18/14 12:13:29.004 Start listening for packets...
08/18/14 12:13:29.005 Initializing family controller...
08/18/14 12:13:29.006 Module HomeMatic BidCoS: Loading XML RPC devices...
08/18/14 12:13:29.901 Warning: Unknown type for "conversion": ccrtdn_party
08/18/14 12:13:30.972 Warning: Unknown type for "conversion": ccrtdn_party
08/18/14 12:13:31.313 Info: Not initializing device family HomeMatic Wired, bacause no physical interface was found.
08/18/14 12:13:31.314 Info: Not initializing device family MAX!, bacause no physical interface was found.
08/18/14 12:13:31.314 Loading devices...
08/18/14 12:13:31.316 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 1
08/18/14 12:13:31.320 Module HomeMatic BidCoS: Loading peer 1
08/18/14 12:13:31.336 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 2
08/18/14 12:13:31.343 Initializing RPC client...
08/18/14 12:13:31.343 Starting XML RPC server RPCServer1 listening on 192.168.100.125:2001...
08/18/14 12:13:31.352 Starting CLI server...
08/18/14 12:13:31.353 Initializing event handler...
08/18/14 12:13:31.353 Loading events...
08/18/14 12:13:31.355 Startup complete.
08/18/14 12:13:31.357 RPC Server (Port 2001): Info: RPC Server started listening on address 192.168.100.125 and port 2001
08/18/14 12:13:31.544 RPC Server (Port 2001): Info: Connection from 192.168.100.148:60828 accepted. Client number: 2
08/18/14 12:13:31.545 RPC Server (Port 2001): Info: Client number 2 is calling RPC method: listBidcosInterfaces Parameters:
08/18/14 12:13:31.547 RPC Server (Port 2001): Info: Connection to client number 2 closed.
08/18/14 12:13:32.019 Info: Connecting to host 192.168.100.31 on port 1000...
08/18/14 12:13:32.548 RPC Server (Port 2001): Info: Connection from 192.168.100.148:60829 accepted. Client number: 4
08/18/14 12:13:32.549 RPC Server (Port 2001): Info: Client number 4 is calling RPC method: listBidcosInterfaces Parameters:
08/18/14 12:13:32.551 RPC Server (Port 2001): Info: Connection to client number 4 closed.
08/18/14 12:13:32.871 Info: Connected to host 192.168.100.31 on port 1000. Client number is: 3
Was könnte ich hier falsch machen ?
Version ist 0.5.6
Im Error Log steht nur
08/18/14 12:13:30.973 Warning: Unknown type for "conversion": ccrtdn_party
Mit dem 'Test.php lässt sich diese Aufruf ausführen.
Ergebnis :
Array
[0] => Array
[ADDRESS] => VBC2281669
[CONNECTED] => 1
[DEFAULT] => 1
[DESCRIPTION] => Homegear default BidCoS interface
Nochmal mit Debug=5
08/18/14 13:42:21.771 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Debug: Sending (encrypted): K
08/18/14 13:42:21.806 Module HomeMatic BidCoS: LAN-Konfigurationsadapter "My-HM-CFG-LAN": Debug: Packet received from HM-CFG-LAN (encrypted): HHM-LAN-IF,03C4,GEQXXXXXXXX,12D2B9,FD0931,007F127F,0001,00^M
08/18/14 13:42:22.326 RPC Server (Port 2001): Info: Connection from 192.168.100.148:63399 accepted. Client number: 4
08/18/14 13:42:22.327 RPC Server (Port 2001): Listening for incoming packets from client number 4.
08/18/14 13:42:22.329 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
08/18/14 13:42:22.330 RPC Server (Port 2001): Info: Client number 4 is calling RPC method: listBidcosInterfaces Parameters:
08/18/14 13:42:22.332 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC2281669
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
(String) Homegear default BidCoS interface
08/18/14 13:42:22.347 RPC Server (Port 2001): Response binary:
42696E0100000087000001000000000100000101000000040000000741444452455353000000030000000A5642433232383136363900000009434F4E4E454354454400000002010000000744454641554C5400000002010000000B4445534352495054494F4E0000000300000021486F6D65676561722064656661756C7420426964436F5320696E74657266616365
08/18/14 13:42:22.354 RPC Server (Port 2001): Info: Connection to client number 4 closed.
mfg.
Jürgen
