ich verzweifele bei der Konfiguration von Homegear auf einem PI3 mit HM-MOD-RPI-PCB.
Die Installation klappt, allerdings kann ich keine Geräte mit Homegear pairen.
Ich hatte auf diesem PI Homegear allerdings schon mal funktionstüchtig. Dann habe ich auf YAHM gewechselt. Nun möchte ich doch wieder zurück zu Homegear, was aber nicht klappen möchte.
Im error-Log von Homegear sehe ich folgende Meldungen:
01/10/18 21:58:50.974 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
01/10/18 21:58:52.799 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
01/10/18 21:58:54.936 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (3). Trying to reconnect...
01/10/18 21:58:55.937 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
01/10/18 21:59:24.901 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
01/10/18 21:59:27.038 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: CRC (8C3F) failed on packet received from HM-MOD-RPI-PCB: FD000C000000436F000C000000436F4350555F424C72
01/10/18 21:59:57.002 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
01/10/18 21:59:58.067 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
01/10/18 22:00:00.208 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (3). Trying to reconnect...
01/10/18 22:00:01.209 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Connection closed (1). Trying to reconnect...
01/10/18 22:00:30.168 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Error: No init packet received.
01/10/18 22:00:32.306 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too small packet received: 0C000000436F
01/10/18 22:00:32.307 Module HomeMatic BidCoS: HM-MOD-RPI-PCB "My-HM-MOD-RPI-PCB": Warning: Too large packet received: 5F4350555F424C72
Der Inhalt meiner /boot/config.txt:
dtparam=audio=on
dtoverlay=pi3-miniuart-bt
enable_uart=1
dtparam=spi=on
dtparam=i2c_arm=on
Der Inhalt meiner /boot/cmdline.txt:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=57add5f2-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
Und zum Schluss homematicbidcod.conf:
id = My-HM-MOD-RPI-PCB
## to new peers.
#default = true
deviceType = hm-mod-rpi-pcb
device = /dev/ttyAMA0
responseDelay = 95
## Default: gpio1 = 0
## "18" for HM-MOD-RPI-PCB
gpio1 = 18
Update
Ich habe auch schon versucht, die Firmware vom HM-MOD-RPI-PCB zu aktualisieren, wie es hier beschrieben ist.
Das kommt bei mir genau so weit:
root@raspberrypi:~/hmcfgusb# ./flash-hmmoduart -U /dev/ttyAMA0 coprocessor_update.eq3
HM-MOD-UART flasher version 0.103-git
Reading firmware from coprocessor_update.eq3...
Firmware with 43 blocks successfully read.
Initializing HM-MOD-UART...
Danke für die Hilfe!
Marcel
