So, ich habe jetzt noch einmal versucht upzugraden, bin allerdings jetzt wieder auf 0.8.0-2427.
Weder mit 0.8.0-2455 noch mit 2468 funktioniert die Hue-Bridge. Folgende Fehlermeldung erscheint bei jedem Peer beim Starten von Homegear.
01/14/19 19:30:03.701 Info: Disposing family module mod_philipshue.so
01/14/19 19:31:52.467 Info: Loading family module mod_philipshue.so
01/14/19 19:31:52.474 /etc/homegear/families/philipshue.conf
01/14/19 19:31:55.764 Module Philips hue: Loading peer 117
01/14/19 19:31:55.766 Module Philips hue: Error: Could not find correct physical interface for peer 117. The peer might not work correctly.
01/14/19 19:31:55.778 Module Philips hue: Loading peer 118
01/14/19 19:31:55.780 Module Philips hue: Error: Could not find correct physical interface for peer 118. The peer might not work correctly.
01/14/19 19:31:55.790 Module Philips hue: Loading peer 119
01/14/19 19:31:55.792 Module Philips hue: Error: Could not find correct physical interface for peer 119. The peer might not work correctly.
01/14/19 19:31:55.802 Module Philips hue: Loading peer 120
01/14/19 19:31:55.804 Module Philips hue: Error: Could not find correct physical interface for peer 120. The peer might not work correctly.
01/14/19 19:31:55.815 Module Philips hue: Loading peer 121
01/14/19 19:31:55.817 Module Philips hue: Error: Could not find correct physical interface for peer 121. The peer might not work correctly.
01/14/19 19:31:55.827 Module Philips hue: Loading peer 123
01/14/19 19:31:55.830 Module Philips hue: Error: Could not find correct physical interface for peer 123. The peer might not work correctly.
01/14/19 19:31:55.840 Module Philips hue: Loading peer 124
01/14/19 19:31:55.842 Module Philips hue: Error: Could not find correct physical interface for peer 124. The peer might not work correctly.
01/14/19 19:31:55.852 Module Philips hue: Loading peer 125
01/14/19 19:31:55.854 Module Philips hue: Error: Could not find correct physical interface for peer 125. The peer might not work correctly.
... usw.
Als ich 2455 installiert habe, habe ich den Fehler schon gesehen. Ich konnte es nur nicht exakt dem Build zuordnen, da ich auch an Flows.json rumgedoktort habe. Dann bin ich schnell zurück auf 2427, genau wie gerade auch.
@sathya, kannst du das irgendwie nachvollziehen? Oder brauchst Du mehr input? Das ist ein Showstopper für mich, bis das nicht gelöst ist kann ich nicht upgraden.
