ich möchte meinen HM-LC-Dim1T-FM Dimmaktor (Peer 1) mit einen HM-SwI-3-FM (Peer 2) pairen. Anscheinend funktioniert das Pairing von Peer 2 nicht so richtig:
[code]12/19/14 03:00:45.015 Info: CLI connection accepted. Client number: 2108
12/19/14 03:00:45.017 Script output: #!/usr/bin/env php
12/19/14 03:00:45.018 RPC Server (Port 2001): Info: RPC Method called: addLink Parameters:
(Integer) 2
(Integer) 1
(Integer) 1
(Integer) 1
12/19/14 03:00:45.027 Module HomeMatic BidCoS: Info: Parameter EXPECT_AES of peer 2 and channel 1 was set to 0x00.
12/19/14 03:00:45.029 Module HomeMatic BidCoS: Info: Parameter PEER_NEEDS_BURST of peer 2 and channel 1 was set to 0x00.
12/19/14 03:00:45.036 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1059A001FD124F252F920102FD124F0100
12/19/14 03:00:45.698 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: No response to packet after 3 tries: 1059A001FD124F252F920102FD124F0100
12/19/14 03:00:50.060 Module HomeMatic BidCoS: Info: Parameter LONG_ACTION_TYPE of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.063 Module HomeMatic BidCoS: Info: Parameter LONG_COND_VALUE_HI of peer 1 and channel 1 was set to 0x64.
12/19/14 03:00:50.065 Module HomeMatic BidCoS: Info: Parameter LONG_COND_VALUE_LO of peer 1 and channel 1 was set to 0x32.
12/19/14 03:00:50.067 Module HomeMatic BidCoS: Info: Parameter LONG_CT_OFF of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.069 Module HomeMatic BidCoS: Info: Parameter LONG_CT_OFFDELAY of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.072 Module HomeMatic BidCoS: Info: Parameter LONG_CT_ON of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.074 Module HomeMatic BidCoS: Info: Parameter LONG_CT_ONDELAY of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.076 Module HomeMatic BidCoS: Info: Parameter LONG_CT_RAMPOFF of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.079 Module HomeMatic BidCoS: Info: Parameter LONG_CT_RAMPON of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.081 Module HomeMatic BidCoS: Info: Parameter LONG_DIM_MAX_LEVEL of peer 1 and channel 1 was set to 0xC8.
12/19/14 03:00:50.083 Module HomeMatic BidCoS: Info: Parameter LONG_DIM_MIN_LEVEL of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.085 Module HomeMatic BidCoS: Info: Parameter LONG_DIM_STEP of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.088 Module HomeMatic BidCoS: Info: Parameter LONG_JT_OFF of peer 1 and channel 1 was set to 0x10.
12/19/14 03:00:50.090 Module HomeMatic BidCoS: Info: Parameter LONG_JT_OFFDELAY of peer 1 and channel 1 was set to 0x10.
12/19/14 03:00:50.094 Module HomeMatic BidCoS: Info: Parameter LONG_JT_ON of peer 1 and channel 1 was set to 0x11.
12/19/14 03:00:50.097 Module HomeMatic BidCoS: Info: Parameter LONG_JT_ONDELAY of peer 1 and channel 1 was set to 0x11.
12/19/14 03:00:50.099 Module HomeMatic BidCoS: Info: Parameter LONG_JT_RAMPOFF of peer 1 and channel 1 was set to 0x10.
12/19/14 03:00:50.101 Module HomeMatic BidCoS: Info: Parameter LONG_JT_RAMPON of peer 1 and channel 1 was set to 0x11.
12/19/14 03:00:50.104 Module HomeMatic BidCoS: Info: Parameter LONG_MULTIEXECUTE of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.106 Module HomeMatic BidCoS: Info: Parameter LONG_OFFDELAY_BLINK of peer 1 and channel 1 was set to 0x20.
12/19/14 03:00:50.108 Module HomeMatic BidCoS: Info: Parameter LONG_OFFDELAY_NEWTIME of peer 1 and channel 1 was set to 0x04.
12/19/14 03:00:50.110 Module HomeMatic BidCoS: Info: Parameter LONG_OFFDELAY_OLDTIME of peer 1 and channel 1 was set to 0x04.
12/19/14 03:00:50.113 Module HomeMatic BidCoS: Info: Parameter LONG_OFFDELAY_STEP of peer 1 and channel 1 was set to 0x0A.
12/19/14 03:00:50.115 Module HomeMatic BidCoS: Info: Parameter LONG_OFFDELAY_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.117 Module HomeMatic BidCoS: Info: Parameter LONG_OFF_LEVEL of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.119 Module HomeMatic BidCoS: Info: Parameter LONG_OFF_TIME of peer 1 and channel 1 was set to 0xFF.
12/19/14 03:00:50.122 Module HomeMatic BidCoS: Info: Parameter LONG_OFF_TIME_MODE of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.124 Module HomeMatic BidCoS: Info: Parameter LONG_ONDELAY_MODE of peer 1 and channel 1 was set to 0x20.
12/19/14 03:00:50.126 Module HomeMatic BidCoS: Info: Parameter LONG_ONDELAY_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.128 Module HomeMatic BidCoS: Info: Parameter LONG_ON_LEVEL of peer 1 and channel 1 was set to 0xC8.
12/19/14 03:00:50.131 Module HomeMatic BidCoS: Info: Parameter LONG_ON_LEVEL_PRIO of peer 1 and channel 1 was set to 0x20.
12/19/14 03:00:50.134 Module HomeMatic BidCoS: Info: Parameter LONG_ON_MIN_LEVEL of peer 1 and channel 1 was set to 0x14.
12/19/14 03:00:50.136 Module HomeMatic BidCoS: Info: Parameter LONG_ON_TIME of peer 1 and channel 1 was set to 0xFF.
12/19/14 03:00:50.138 Module HomeMatic BidCoS: Info: Parameter LONG_ON_TIME_MODE of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.140 Module HomeMatic BidCoS: Info: Parameter LONG_RAMPOFF_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.142 Module HomeMatic BidCoS: Info: Parameter LONG_RAMPON_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.145 Module HomeMatic BidCoS: Info: Parameter LONG_RAMP_START_STEP of peer 1 and channel 1 was set to 0x0A.
12/19/14 03:00:50.147 Module HomeMatic BidCoS: Info: Parameter SHORT_ACTION_TYPE of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.149 Module HomeMatic BidCoS: Info: Parameter SHORT_COND_VALUE_HI of peer 1 and channel 1 was set to 0x64.
12/19/14 03:00:50.152 Module HomeMatic BidCoS: Info: Parameter SHORT_COND_VALUE_LO of peer 1 and channel 1 was set to 0x32.
12/19/14 03:00:50.155 Module HomeMatic BidCoS: Info: Parameter SHORT_CT_OFF of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.157 Module HomeMatic BidCoS: Info: Parameter SHORT_CT_OFFDELAY of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.159 Module HomeMatic BidCoS: Info: Parameter SHORT_CT_ON of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.161 Module HomeMatic BidCoS: Info: Parameter SHORT_CT_ONDELAY of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.164 Module HomeMatic BidCoS: Info: Parameter SHORT_CT_RAMPOFF of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.166 Module HomeMatic BidCoS: Info: Parameter SHORT_CT_RAMPON of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.168 Module HomeMatic BidCoS: Info: Parameter SHORT_DIM_MAX_LEVEL of peer 1 and channel 1 was set to 0xC8.
12/19/14 03:00:50.170 Module HomeMatic BidCoS: Info: Parameter SHORT_DIM_MIN_LEVEL of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.173 Module HomeMatic BidCoS: Info: Parameter SHORT_DIM_STEP of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.175 Module HomeMatic BidCoS: Info: Parameter SHORT_JT_OFF of peer 1 and channel 1 was set to 0x10.
12/19/14 03:00:50.177 Module HomeMatic BidCoS: Info: Parameter SHORT_JT_OFFDELAY of peer 1 and channel 1 was set to 0x10.
12/19/14 03:00:50.179 Module HomeMatic BidCoS: Info: Parameter SHORT_JT_ON of peer 1 and channel 1 was set to 0x11.
12/19/14 03:00:50.182 Module HomeMatic BidCoS: Info: Parameter SHORT_JT_ONDELAY of peer 1 and channel 1 was set to 0x11.
12/19/14 03:00:50.184 Module HomeMatic BidCoS: Info: Parameter SHORT_JT_RAMPOFF of peer 1 and channel 1 was set to 0x10.
12/19/14 03:00:50.186 Module HomeMatic BidCoS: Info: Parameter SHORT_JT_RAMPON of peer 1 and channel 1 was set to 0x11.
12/19/14 03:00:50.188 Module HomeMatic BidCoS: Info: Parameter SHORT_OFFDELAY_BLINK of peer 1 and channel 1 was set to 0x20.
12/19/14 03:00:50.191 Module HomeMatic BidCoS: Info: Parameter SHORT_OFFDELAY_NEWTIME of peer 1 and channel 1 was set to 0x04.
12/19/14 03:00:50.193 Module HomeMatic BidCoS: Info: Parameter SHORT_OFFDELAY_OLDTIME of peer 1 and channel 1 was set to 0x04.
12/19/14 03:00:50.195 Module HomeMatic BidCoS: Info: Parameter SHORT_OFFDELAY_STEP of peer 1 and channel 1 was set to 0x0A.
12/19/14 03:00:50.197 Module HomeMatic BidCoS: Info: Parameter SHORT_OFFDELAY_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.200 Module HomeMatic BidCoS: Info: Parameter SHORT_OFF_LEVEL of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.202 Module HomeMatic BidCoS: Info: Parameter SHORT_OFF_TIME of peer 1 and channel 1 was set to 0xFF.
12/19/14 03:00:50.204 Module HomeMatic BidCoS: Info: Parameter SHORT_OFF_TIME_MODE of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.207 Module HomeMatic BidCoS: Info: Parameter SHORT_ONDELAY_MODE of peer 1 and channel 1 was set to 0x20.
12/19/14 03:00:50.209 Module HomeMatic BidCoS: Info: Parameter SHORT_ONDELAY_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.211 Module HomeMatic BidCoS: Info: Parameter SHORT_ON_LEVEL of peer 1 and channel 1 was set to 0xC8.
12/19/14 03:00:50.213 Module HomeMatic BidCoS: Info: Parameter SHORT_ON_LEVEL_PRIO of peer 1 and channel 1 was set to 0x20.
12/19/14 03:00:50.215 Module HomeMatic BidCoS: Info: Parameter SHORT_ON_MIN_LEVEL of peer 1 and channel 1 was set to 0x14.
12/19/14 03:00:50.218 Module HomeMatic BidCoS: Info: Parameter SHORT_ON_TIME of peer 1 and channel 1 was set to 0xFF.
12/19/14 03:00:50.220 Module HomeMatic BidCoS: Info: Parameter SHORT_ON_TIME_MODE of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.223 Module HomeMatic BidCoS: Info: Parameter SHORT_RAMPOFF_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.225 Module HomeMatic BidCoS: Info: Parameter SHORT_RAMPON_TIME of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.227 Module HomeMatic BidCoS: Info: Parameter SHORT_RAMP_START_STEP of peer 1 and channel 1 was set to 0x0A.
12/19/14 03:00:50.229 Module HomeMatic BidCoS: Info: Parameter UI_HINT of peer 1 and channel 1 was set to 0x00.
12/19/14 03:00:50.248 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 105DA001FD124F324E880101252F920100
12/19/14 03:00:50.461 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3E): 0A5D8002324E88FD124F00
12/19/14 03:00:50.521 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1032A001FD124F324E880105324E880103
12/19/14 03:00:50.851 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x40): 0A328002324E88FD124F00
12/19/14 03:00:50.910 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1933A001FD124F324E88010801000200030004320564060007FF
12/19/14 03:00:51.252 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x40): 0A338002324E88FD124F00
12/19/14 03:00:51.311 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1934A001FD124F324E880108080009FF0A000B110C110D110E20
12/19/14 03:00:51.655 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x40): 0A348002324E88FD124F00
12/19/14 03:00:51.714 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1935A001FD124F324E8801080F00101411C8120A130014001500
12/19/14 03:00:52.047 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3F): 0A358002324E88FD124F00
12/19/14 03:00:52.106 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1936A001FD124F324E88010816C81700180A19041A0481008200
12/19/14 03:00:52.445 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3F): 0A368002324E88FD124F00
12/19/14 03:00:52.504 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1937A001FD124F324E880108830084328564860087FF880089FF
12/19/14 03:00:52.849 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3F): 0A378002324E88FD124F00
12/19/14 03:00:52.908 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1938A001FD124F324E8801088A008B118C118D118E208F009014
12/19/14 03:00:53.241 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3F): 0A388002324E88FD124F00
12/19/14 03:00:53.300 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 1939A001FD124F324E88010891C8920A93009400950096C89700
12/19/14 03:00:53.645 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3D): 0A398002324E88FD124F00
12/19/14 03:00:53.704 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 113AA001FD124F324E880108980A99049A04
12/19/14 03:00:54.036 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3E): 0A3A8002324E88FD124F00
12/19/14 03:00:54.095 Module HomeMatic BidCoS: LAN-Konfigurationsadapter “My-HM-CFG-LAN”: Info: Sending (My-HM-CFG-LAN): 0B3BA001FD124F324E880106
12/19/14 03:00:54.434 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3F): 0A3B8002324E88FD124F00
12/19/14 03:00:54.435 Module HomeMatic BidCoS: Info: Queue 39 is empty and there are no pending queues.
12/19/14 03:00:55.261 Script output:
12/19/14 03:01:29.210 Info: CLI connection accepted. Client number: 2110
[/code]
Das Verhalten nach dem Pairen ist dann auch nicht richtig: Ich kann den Aktor zwar vom Schalter anschalten, abschalten geht aber nur direkt von Homegear, nicht vom Schalter aus. Laut Log sendet der Schalter bei jeder Betätigung ein Press-Signal. Der Aktor reagiert auch darauf und sendet seinen aktuellen Status - der Level bleibt angeschaltet. Hier das Log von zwei aufeinanderfolgenden Schalterbestätigungen - der Level bleibt in beiden Fällen gleich, das Licht schaltet sich also nicht ab:
12/19/14 03:15:18.030 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3F): 0B94A440252F92324E88016F
12/19/14 03:15:18.033 Module HomeMatic BidCoS: Info: INSTALL_TEST of HomeMatic BidCoS peer 2 with serial number KEQ1062403:1 was set to 0x6F.
12/19/14 03:15:18.035 Module HomeMatic BidCoS: Info: PRESS of HomeMatic BidCoS peer 2 with serial number KEQ1062403:1 was set to 0x6F.
12/19/14 03:15:18.163 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3E): 0E948002324E88252F920101C8003F
12/19/14 03:15:18.166 Module HomeMatic BidCoS: Info: DIRECTION of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:18.168 Module HomeMatic BidCoS: Info: ERROR_OVERHEAT of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:18.170 Module HomeMatic BidCoS: Info: ERROR_OVERLOAD of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:18.173 Module HomeMatic BidCoS: Info: ERROR_REDUCED of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:18.175 Module HomeMatic BidCoS: Info: LEVEL of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0xC8.
12/19/14 03:15:18.177 Module HomeMatic BidCoS: Info: WORKING of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:21.044 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3A): 0B95A040252F92324E880170
12/19/14 03:15:21.047 Module HomeMatic BidCoS: Info: INSTALL_TEST of HomeMatic BidCoS peer 2 with serial number KEQ1062403:1 was set to 0x70.
12/19/14 03:15:21.049 Module HomeMatic BidCoS: Info: PRESS of HomeMatic BidCoS peer 2 with serial number KEQ1062403:1 was set to 0x70.
12/19/14 03:15:21.178 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x40): 0E958002324E88252F920101C8003A
12/19/14 03:15:21.182 Module HomeMatic BidCoS: Info: DIRECTION of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:21.184 Module HomeMatic BidCoS: Info: ERROR_OVERHEAT of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:21.186 Module HomeMatic BidCoS: Info: ERROR_OVERLOAD of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:21.188 Module HomeMatic BidCoS: Info: ERROR_REDUCED of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:21.190 Module HomeMatic BidCoS: Info: LEVEL of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0xC8.
12/19/14 03:15:21.193 Module HomeMatic BidCoS: Info: WORKING of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:23.678 HomeMatic BidCoS packet received (My-HM-CFG-LAN, RSSI: 0x3E): 0D96A410324E88FD124F0601C800
12/19/14 03:15:23.681 Module HomeMatic BidCoS: Info: DIRECTION of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:23.683 Module HomeMatic BidCoS: Info: ERROR_OVERHEAT of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:23.685 Module HomeMatic BidCoS: Info: ERROR_OVERLOAD of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:23.687 Module HomeMatic BidCoS: Info: ERROR_REDUCED of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
12/19/14 03:15:23.689 Module HomeMatic BidCoS: Info: LEVEL of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0xC8.
12/19/14 03:15:23.692 Module HomeMatic BidCoS: Info: WORKING of HomeMatic BidCoS peer 1 with serial number LEQ0990608:1 was set to 0x00.
