Openhab2 and Homegear Portconflict
I try running Openhab2 and Homegear and investigating a port conflict.
Openhab Forum link
$ sudo netstat -nlp | grep 5353
udp        0      0 0.0.0.0:5353            0.0.0.0:*                           391/avahi-daemon: r
udp6       0      0 :::5353                 :::*                                723/java
udp6       0      0 :::5353                 :::*                                391/avahi-daemon: r
Is it possible that homegear needs this avahi-daemon?
the java task is openhab2
Hi @Arsur,
avahi is a network service, see https://en.wikipedia.org/wiki/Avahi_(software) and it comes with Raspbian or most other linux distros by default.
If you don’t need it simply disable/uninstall Avahi. In the meantime I would try to get rid of Java using UDP6:5353…
Cheers,
mhm okay i had another error thought it would be something with homegear, which isnt the case… can be closed
