OH 2 und LOWBAT Channel
Moin Zusammen,
ich hab da ein Problem mit dem LOWBAT Channel. In Homegear (0.7-1346 aus Raspi) werden die Batteriestatus angezeigt. Sathya hatte das ja freundlicher Weise eingebaut. In openHAB2 kommt allerdings kein LOWBAT Status an.
Hier mal ein auszu aus den letzten LOWBat meldungen im Log
06/06/16 09:14:31.441 Module HomeMatic BidCoS: Info: LOWBAT_REPORTING on channel 2 of HomeMatic BidCoS peer 33 with serial number LEQxxx was set to 0x00. 06/06/16 09:23:15.978 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 58 with serial number LEQxxx was set to 0x00. 06/06/16 09:23:15.984 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 58 with serial number LEQxxx was set to 0x00. 06/06/16 09:31:24.450 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 15 with serial number LEQxxx was set to 0x00. 06/06/16 09:31:24.458 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 15 with serial number LEQxxx was set to 0x00. 06/06/16 09:31:40.804 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 43 with serial number MEQxxx was set to 0x00. 06/06/16 09:31:40.813 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 43 with serial number MEQxxx was set to 0x00. 06/06/16 09:32:24.127 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 12 with serial number LEQxxx was set to 0x00. 06/06/16 09:32:24.129 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 12 with serial number LEQxxx was set to 0x00. 06/06/16 09:44:02.461 Module HomeMatic BidCoS: Info: LOWBAT_REPORTING on channel 2 of HomeMatic BidCoS peer 33 with serial number LEQxxx was set to 0x00. 06/06/16 09:46:29.616 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 3 with serial number LEQxxx was set to 0x00. 06/06/16 09:46:29.618 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 3 with serial number LEQxxx was set to 0x00. 06/06/16 09:46:53.719 Module HomeMatic BidCoS: Info: LOWBAT_REPORTING on channel 2 of HomeMatic BidCoS peer 33 with serial number LEQxxx was set to 0x00. 06/06/16 09:50:05.633 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 24 with serial number MEQxxx was set to 0x00. 06/06/16 09:50:05.637 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 24 with serial number MEQxxx was set to 0x00. 06/06/16 10:04:46.943 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 4 with serial number MEQxxx was set to 0x00. 06/06/16 10:04:46.952 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 4 with serial number MEQxxx was set to 0x00. 06/06/16 10:06:00.570 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 41 with serial number MEQxxx was set to 0x00. 06/06/16 10:06:00.574 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 41 with serial number MEQxxx was set to 0x00. 06/06/16 10:07:18.390 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 19 with serial number LEQxxx was set to 0x00. 06/06/16 10:07:18.394 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 19 with serial number LEQxxx was set to 0x00. 06/06/16 10:07:27.976 Module HomeMatic BidCoS: Info: LOWBAT_REPORTING on channel 2 of HomeMatic BidCoS peer 33 with serial number LEQxxx was set to 0x00. 06/06/16 10:16:36.711 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 58 with serial number LEQxxx was set to 0x00. 06/06/16 10:16:36.726 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 58 with serial number LEQxxx was set to 0x00. 06/06/16 10:17:18.737 Module HomeMatic BidCoS: Info: LOWBAT_REPORTING on channel 2 of HomeMatic BidCoS peer 33 with serial number LEQxxx was set to 0x00. 06/06/16 10:27:30.928 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 43 with serial number MEQxxx was set to 0x00. 06/06/16 10:27:30.938 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 43 with serial number MEQxxx was set to 0x00. 06/06/16 10:27:32.412 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 15 with serial number LEQxxx was set to 0x00. 06/06/16 10:27:32.422 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 15 with serial number LEQxxx was set to 0x00. 06/06/16 10:33:15.666 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 12 with serial number LEQxxx was set to 0x00. 06/06/16 10:33:15.670 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 12 with serial number LEQxxx was set to 0x00. 06/06/16 10:40:08.709 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 3 with serial number LEQxxx was set to 0x00. 06/06/16 10:40:08.715 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 3 with serial number LEQxxx was set to 0x00. 06/06/16 10:44:47.828 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 24 with serial number MEQxxx was set to 0x00. 06/06/16 10:44:47.839 Module HomeMatic BidCoS: Info: LOWBAT on channel 0 of HomeMatic BidCoS peer 24 with serial number MEQxxx was set to 0x00. 06/06/16 10:45:16.646 Module HomeMatic BidCoS: Info: LOWBAT on channel 1 of HomeMatic BidCoS peer 29 with serial number LEQxxx was set to 0x00. 06/06/16 10:48:18.756 Module HomeMatic BidCoS: Info: LOWBAT_REPORTING on channel 2 of HomeMatic BidCoS peer 33 with serial number LEQxxx was set to 0x00.
Wie man sieht es kommen LOWBAT Meldungen. Hat jemand eine Idee warum diese nicht in OH2 ankommen?
Thomas
Wie sieht denn dein Binding unter openhab aus? Lowbat 0x00 entspricht “false” oder?
Gesendet von iPhone mit Tapatalk
Ist als Contact ausgelegt. Habe jetzt mal auf Number umgestellt. Es kommt aber nichts an, als wenn die Daten nocht abgefragt bzw. von homegeear gesendet werden.
Thomas
Hallo Thomas,
komisch. Kannst du das gleiche Log vielleicht noch einmal vollständig und mit Debuglevel 5 schicken? Das zeigt uns dann, ob die Meldungen an OpenHAB gesendet werden.
Ich glaube das lag am Item in Openhab. Ich habe jetzt auf Switch umgestellt und jetzt scheint es zu gehen. Muss jetzt mal alte Batterien raussuchen.
Thomas
