Node Blue ohne Inhalt
Hallo Zusammen, habe heute das aktuelle Nightly ( version 0.8.0-2409) installiert. Habe aber einen blöden Fehler - In Node blue wird leider nichts mehr angezeigt.
12/09/18 13:11:24.344 Web server (Port 2001): Client is requesting: /node-blue/ (translated to /var/lib/homegear/www/rpc/node-blue/index.php, method: GET)
12/09/18 13:11:24.352 Web server (Port 2001): Client is requesting: /node-blue/ (translated to /var/lib/homegear/www/rpc/node-blue/index.php, method: GET)
12/09/18 13:11:24.353 Script Engine Server: Info: Starting script "/var/lib/homegear/node-blue/www/index.php" with id 47.
12/09/18 13:11:24.361 Script Engine Server: Info: Client number 0 is calling RPC method: scriptHeaders
12/09/18 13:11:24.363 Script Engine Server: Info: Client number 0 is calling RPC method: scriptOutput
12/09/18 13:11:24.367 Info: Script with id 47 finished with exit code 0
12/09/18 13:11:24.385 Web server (Port 2001): Client is requesting: /node-blue/vendor/jquery/css/smoothness/jquery-ui-1.10.3.custom.min.css (translated to /var/lib/homegear/www/rpc/node-blue/vendor/jquery/css/smoothness/jquery-ui-1.10.3.custom.min.css, method: GET)
12/09/18 13:11:24.385 Web server (Port 2001): Client is requesting: /node-blue/vendor/font-awesome/css/font-awesome.min.css (translated to /var/lib/homegear/www/rpc/node-blue/vendor/font-awesome/css/font-awesome.min.css, method: GET)
12/09/18 13:11:24.386 Web server (Port 2001): Client is requesting: /node-blue/vendor/bootstrap/css/bootstrap.min.css (translated to /var/lib/homegear/www/rpc/node-blue/vendor/bootstrap/css/bootstrap.min.css, method: GET)
12/09/18 13:11:24.388 Web server (Port 2001): Client is requesting: /node-blue/red/style.min.css (translated to /var/lib/homegear/www/rpc/node-blue/red/style.min.css, method: GET)
12/09/18 13:11:24.392 Web server (Port 2001): Client is requesting: /node-blue/red/images/node-blue.png (translated to /var/lib/homegear/www/rpc/node-blue/red/images/node-blue.png, method: GET)
12/09/18 13:11:24.394 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.6.128:8126 accepted. Client number: 1441
12/09/18 13:11:24.394 RPC Server (Port 2001): Info: RPC server client id for client number 1441 is: 413
12/09/18 13:11:24.396 Web server (Port 2001): Client is requesting: /node-blue/red/images/spin.svg (translated to /var/lib/homegear/www/rpc/node-blue/red/images/spin.svg, method: GET)
12/09/18 13:11:24.434 Web server (Port 2001): Client is requesting: /node-blue/vendor/vendor.js (translated to /var/lib/homegear/www/rpc/node-blue/vendor/vendor.js, method: GET)
12/09/18 13:11:24.439 Web server (Port 2001): Client is requesting: /node-blue/vendor/ace/ace.js (translated to /var/lib/homegear/www/rpc/node-blue/vendor/ace/ace.js, method: GET)
12/09/18 13:11:24.465 Web server (Port 2001): Client is requesting: /node-blue/vendor/ace/ext-language_tools.js (translated to /var/lib/homegear/www/rpc/node-blue/vendor/ace/ext-language_tools.js, method: GET)
12/09/18 13:11:24.478 Web server (Port 2001): Client is requesting: /node-blue/red/red.min.js (translated to /var/lib/homegear/www/rpc/node-blue/red/red.min.js, method: GET)
12/09/18 13:11:24.486 Web server (Port 2001): Client is requesting: /node-blue/red/main.min.js (translated to /var/lib/homegear/www/rpc/node-blue/red/main.min.js, method: GET)
12/09/18 13:11:24.989 Web server (Port 2001): Client is requesting: /node-blue/red/images/grip.png (translated to /var/lib/homegear/www/rpc/node-blue/red/images/grip.png, method: GET)
12/09/18 13:11:24.998 Web server (Port 2001): Client is requesting: /node-blue/locales/editor (translated to /var/lib/homegear/www/rpc/node-blue/locales/editor, method: GET)
12/09/18 13:11:24.999 Web server (Port 2001): Client is requesting: /node-blue/locales/editor (translated to /var/lib/homegear/www/rpc/node-blue/locales/editor, method: GET)
12/09/18 13:11:25.000 Web server (Port 2001): Client is requesting: /node-blue/locales/node-red (translated to /var/lib/homegear/www/rpc/node-blue/locales/node-red, method: GET)
12/09/18 13:11:25.001 Web server (Port 2001): Client is requesting: /node-blue/locales/node-red (translated to /var/lib/homegear/www/rpc/node-blue/locales/node-red, method: GET)
12/09/18 13:11:25.004 Web server (Port 2001): Client is requesting: /node-blue/locales/jsonata (translated to /var/lib/homegear/www/rpc/node-blue/locales/jsonata, method: GET)
12/09/18 13:11:25.006 Web server (Port 2001): Client is requesting: /node-blue/locales/jsonata (translated to /var/lib/homegear/www/rpc/node-blue/locales/jsonata, method: GET)
12/09/18 13:11:25.020 Web server (Port 2001): Client is requesting: /node-blue/locales/infotips (translated to /var/lib/homegear/www/rpc/node-blue/locales/infotips, method: GET)
12/09/18 13:11:25.028 Web server (Port 2001): Client is requesting: /node-blue/locales/infotips (translated to /var/lib/homegear/www/rpc/node-blue/locales/infotips, method: GET)
12/09/18 13:11:25.080 Web server (Port 2001): Client is requesting: /node-blue/settings (translated to /var/lib/homegear/www/rpc/node-blue/settings, method: GET)
12/09/18 13:11:25.095 Web server (Port 2001): Client is requesting: /node-blue/settings/user (translated to /var/lib/homegear/www/rpc/node-blue/settings/user, method: GET)
12/09/18 13:11:25.147 Web server (Port 2001): Client is requesting: /node-blue/library/flows (translated to /var/lib/homegear/www/rpc/node-blue/library/flows, method: GET)
12/09/18 13:11:25.164 Web server (Port 2001): Client is requesting: /node-blue/red/keymap.json (translated to /var/lib/homegear/www/rpc/node-blue/red/keymap.json, method: GET)
12/09/18 13:11:25.228 RPC Server (Port 2001): Info: Connection from ::ffff:192.168.6.128:8128 accepted. Client number: 1442
12/09/18 13:11:25.229 RPC Server (Port 2001): Info: RPC server client id for client number 1442 is: 414
12/09/18 13:11:25.230 Web server (Port 2001): Client is requesting: /node-blue/red/images/deploy-full-o.png (translated to /var/lib/homegear/www/rpc/node-blue/red/images/deploy-full-o.png, method: GET)
12/09/18 13:11:25.253 RPC Server (Port 2001): Info: Transferring client number 414 to RPC client.
12/09/18 13:11:25.254 Node-BLUE Server: Info: Disabling node events...
12/09/18 13:11:25.254 Node-BLUE Server: Info: Enabling node events...
12/09/18 13:11:25.329 Script Engine Server: Info: Client number 0 is calling RPC method: setValue
Ich hatte exakt den gleichen Effekt. Da ich aber noch etwas ändern musste, bin ich direkt zurück auf 2398, ohne auch nur kurz in das Log zu schauen. Bei mir war es mit dem aktuellen Chrome unter Windows.
Ja, ist bei mir auch Google Chrome
Schaut bitte mal in die Entwicklerkonsole (F12) des Browsers für die Fehlermeldung beim Laden der Seite.
Keine Fehlermeldung…
Hab gerade mit @sathya gesprochen, das Problem sollte im nächsten Nighlty gefixt sein.
Gerade nightly eingespielt und was soll ich sagen, es funktioniert wieder alles :grinning:
Vielen Dank!
