Ich habe mal ein node-blue script zur Steuerung von HUE Lampen gebastelt, vielleicht kann es jemand brauchen.
Im wesentlichen kann das Script die Lampe Ein- und Aus-Schalten, Hoch und Runter dimmen und gespeicherte Profile setzen. Profile werden gesetzt durch wiederholtes drücken der Ein-Taste.
// 0 - On; 1 - Off; 2 - Dim up; 3 - Dim down
// some static parameters
$device_id = 62; // the homegear device id
$profiles = array(
array("payload" => "relax", "brightness" => 144, "hue" => 7676), // Relax: 144, 7676
array("payload" => "read", "brightness" => 254, "hue" => 7676), // Read: 254, 7676
array("payload" => "dimmed", "brightness" => 77, "hue" => 8381), // Dimmed: 77, 8381
array("payload" => "night", "brightness" => 1, "hue" => 8381), // Night: 1, 8381
// general statements
$bright = $hg->getValue($device_id, 1, "BRIGHTNESS"); // getting the current brightness
$state = $hg->getValue($device_id, 1, "STATE"); // getting the current brightness
if($inputIndex == 0) { // left key short
if ($state == 0) {
$profile_nr = 0;
$message['payload'] = 1;
$hg->setValue($device_id, 1, "STATE", 1); // switch on without confirmation
} else {
$profile_nr = getNodeData("profile_nr");
$message['profile_nr'] = $profile_nr;
$message['payload'] = $profiles[$profile_nr]['payload'];
$message['hue'] = $profiles[$profile_nr]['hue'];
$message['brightness'] = $profiles[$profile_nr]['brightness'];
$hg->putParamset($device_id, 1, "VALUES", array("BRIGHTNESS" => $message['brightness'], "HUE" => $message['hue']));
$profile_nr++;
if ($profile_nr >= count($profiles)) $profile_nr = 0;
setNodeData("profile_nr", $profile_nr);
return $message;
} else if($inputIndex == 1) { // right key short
$hg->setValue($device_id, 1, "STATE", 0); // simple switch off
$message['payload'] = 0;
return $message;
} else if($inputIndex == 2) { // left key long
$bright += 10; // increase brightness
if ($bright > 254) $bright = 254; // not over 254
$hg->setValue($device_id, 1, "FAST_BRIGHTNESS", $bright); // set the value without confirmation
} else if($inputIndex == 3) { // right key long
$bright -= 10; // lower the brightness
if ($bright < 0) $bright = 1; // not below 1
