jipp
October 3, 2017, 11:18am
1
Hi
I configured a debug node and tried to log the messages to ‘debug tab and Homegear flows log’
I see the messages when the web page is opened but I do not find any entry in any log file.
in the following files there is no entry for the debug:
root@lemonpi:/var/log/homegear# ls
homegear.err homegear-flows.log homegear-scriptengine.err
homegear-flows.err homegear.log homegear-scriptengine.log
Any hint where the log messages should be stored?
thanks
Wolfgang
pmayer
October 3, 2017, 3:03pm
2
Hi @jipp ,
I’m not sure if this is correct as I’ve not used node-blue yet, but have you tried the JavaScript Developer Console of your browser? At least thats where node-red puts some debugging information.
homegear-flows.log ist the mentioned Homegear flows log as far as I know.
so long,
jipp
October 3, 2017, 4:55pm
3
Hi
the browser shows no problems, debug and log is working there, but I would need to log the message in a file.
The homegear-flows.log does not show any entry.
Cheers
Micha
October 4, 2017, 7:34am
5
Hi @jipp ,
is there any output in the homegear-flows.log or just a blank file?
Cheers,
Michael
jipp
October 8, 2017, 1:58pm
6
Hi
after some investigations:
-the file was not empty
I figured out that the ‘debugLevel = 4’ inside ‘main.conf’ might has something to do with it.
I changed the log level critical and suddenly I saw messages from the Node-BLUE:
10/06/17 20:00:00.378 Flows Engine (18743): Node c0fd2e8b.2cb38: Debug node output (critical): (Boolean) 1
10/06/17 20:02:00.391 Flows Engine (18743): Node c0fd2e8b.2cb38: Debug node output (critical): (Boolean) 0
10/07/17 06:00:00.489 Flows Engine (18743): Node c0fd2e8b.2cb38: Debug node output (critical): (Boolean) 1
10/07/17 20:00:00.338 Flows Engine (18743): Node c0fd2e8b.2cb38: Debug node output (critical): (Boolean) 1
10/07/17 20:02:00.350 Flows Engine (18743): Node c0fd2e8b.2cb38: Debug node output (critical): (Boolean) 0
So it seems working - my mistake.
thanks to all
Jipp
pmayer
October 8, 2017, 2:24pm
7
You can set the debug level for the runtime via the homegear console:
sudo homegear -r
dl 5
jipp
October 23, 2017, 4:00pm
8
Hi
yes - thanks
I think I got this now under control
cheers
