I successfully build homegear-0.5.14 on my RPi and can start it:
11/24/14 13:34:19.865 Debug: debugLevel set to 5 [130/1938]
11/24/14 13:34:19.869 Debug: devLog set to 0
11/24/14 13:34:19.872 Debug: databasePath set to /var/lib/homegear/db.sql
11/24/14 13:34:19.875 Debug: databaseMemoryJournal set to 1
11/24/14 13:34:19.875 Debug: databaseSynchronous set to 0
11/24/14 13:34:19.877 Debug: logfilePath set to /var/log/homegear/
11/24/14 13:34:19.881 Debug: certPath set to /etc/homegear/homegear.crt
11/24/14 13:34:19.881 Debug: keyPath set to /etc/homegear/homegear.key
11/24/14 13:34:19.882 Debug: loadDHParamsFromFile set to 1
11/24/14 13:34:19.882 Debug: dhParamPath set to /etc/homegear/dh1024.pem
11/24/14 13:34:19.882 Debug: deviceDescriptionPath set to /etc/homegear/devices/
11/24/14 13:34:19.883 Debug: clientSettingsPath set to /etc/homegear/rpcclients.conf
11/24/14 13:34:19.883 Debug: serverSettingsPath set to /etc/homegear/rpcservers.conf
11/24/14 13:34:19.892 Debug: physicalDeviceSettingsPath set to /etc/homegear/physicalinterfaces.conf
11/24/14 13:34:19.892 Debug: gpioPath set to /sys/class/gpio/
11/24/14 13:34:19.893 Debug: scriptPath set to /var/lib/homegear/scripts/
11/24/14 13:34:19.893 Debug: libraryPath set to /var/lib/homegear/modules/
11/24/14 13:34:19.893 Debug: firmwarePath set to /var/lib/homegear/firmware/
11/24/14 13:34:19.894 Debug: prioritizeThreads set to 1
11/24/14 13:34:19.894 Debug: workerThreadWindow set to 3000
11/24/14 13:34:19.894 Debug: rpcServerThreadPriority set to 0
11/24/14 13:34:19.895 Debug: rpcServerThreadPolicy set to 0
11/24/14 13:34:19.895 Debug: rpcClientThreadPriority set to 0
11/24/14 13:34:19.895 Debug: rpcClientThreadPolicy set to 0
11/24/14 13:34:19.896 Debug: workerThreadPriority set to 0
11/24/14 13:34:19.896 Debug: workerThreadPolicy set to 0
11/24/14 13:34:19.896 Debug: physicalInterfaceThreadPriority set to 45
11/24/14 13:34:19.897 Debug: physicalInterfaceThreadPolicy set to 1
11/24/14 13:34:19.897 Debug: packetReceivedThreadPriority set to 0
11/24/14 13:34:19.898 Debug: packetReceivedThreadPolicy set to 0
11/24/14 13:34:19.898 Debug: eventTriggerThreadPriority set to 0
11/24/14 13:34:19.898 Debug: eventTriggerThreadPolicy set to 0
11/24/14 13:34:19.899 Loading RPC server settings from /etc/homegear/rpcservers.conf
11/24/14 13:34:19.899 Debug: interface of RPC server RPCServer1 set to 0.0.0.0
11/24/14 13:34:19.900 Debug: port of RPC server RPCServer1 set to 2001
11/24/14 13:34:19.902 Debug: ssl of RPC server RPCServer1 set to 0
11/24/14 13:34:19.902 Debug: authType of RPC server RPCServer1 set to 0
11/24/14 13:34:19.903 Debug: interface of RPC server RPCServer2 set to 0.0.0.0
11/24/14 13:34:19.912 Debug: port of RPC server RPCServer2 set to 2002
11/24/14 13:34:19.912 Debug: ssl of RPC server RPCServer2 set to 1
11/24/14 13:34:19.913 Debug: authType of RPC server RPCServer2 set to 0
11/24/14 13:34:19.913 Debug: diffieHellmanKeySize of RPC server RPCServer2 set to 1024
11/24/14 13:34:19.913 Debug: interface of RPC server RPCServer3 set to 0.0.0.0
11/24/14 13:34:19.914 Debug: port of RPC server RPCServer3 set to 2003
11/24/14 13:34:19.914 Debug: ssl of RPC server RPCServer3 set to 1
11/24/14 13:34:19.914 Debug: authType of RPC server RPCServer3 set to 1
11/24/14 13:34:19.915 Debug: diffieHellmanKeySize of RPC server RPCServer3 set to 1024
11/24/14 13:34:19.915 Loading RPC client settings from /etc/homegear/rpcclients.conf
11/24/14 13:34:19.916 Debug: hostname of RPC client ExampleClient set to myhostname
11/24/14 13:34:19.917 Debug: caFile of RPC client ExampleClient set to /path/to/ca-certficate
11/24/14 13:34:19.917 Debug: verifyCertificate of RPC client ExampleClient set to 1
11/24/14 13:34:19.917 Debug: forceSSL of RPC client ExampleClient set to 1
11/24/14 13:34:19.918 Debug: authType of RPC client ExampleClient set to 1
11/24/14 13:34:19.918 Debug: userName of RPC client ExampleClient set to myuser
11/24/14 13:34:19.918 Debug: password of RPC client ExampleClient was set.
11/24/14 13:34:19.921 Debug: Loading family modules
11/24/14 13:34:19.921 Info: Loading family module mod_philipshue.so
11/24/14 13:34:19.987 Module Philips hue: Debug: Loading module…
11/24/14 13:34:19.987 Info: Loading family module mod_homematicbidcos.so
11/24/14 13:34:20.056 Module HomeMatic BidCoS: Debug: Loading module…
11/24/14 13:34:20.143 Debug: Reading config for physical device family HomeMatic BidCoS
11/24/14 13:34:20.146 Debug: id of family HomeMatic BidCoS set to COC
11/24/14 13:34:20.149 Debug: default of family HomeMatic BidCoS set to 1
11/24/14 13:34:20.152 Debug: deviceType of family HomeMatic BidCoS set to coc
11/24/14 13:34:20.152 Debug: device of family HomeMatic BidCoS set to /dev/ttyAMA0
11/24/14 13:34:20.153 Debug: responseDelay of family HomeMatic BidCoS set to 95
11/24/14 13:34:20.153 Debug: GPIO1 of family HomeMatic BidCoS set to 17
11/24/14 13:34:20.154 Debug: GPIO2 of family HomeMatic BidCoS set to 18
11/24/14 13:34:20.161 Module HomeMatic BidCoS: Debug: Creating physical device. Type defined in physicalinterfaces.conf is: coc
11/24/14 13:34:20.162 Initializing database…
11/24/14 13:34:20.186 Initializing family controller…
11/24/14 13:34:20.189 Module HomeMatic BidCoS: Loading XML RPC devices…
11/24/14 13:33:18.417 Loading devices…
11/24/14 13:33:18.420 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 1
11/24/14 13:33:18.427 Module HomeMatic BidCoS: Loading HomeMatic BidCoS device 2
11/24/14 13:33:18.437 Start listening for packets…
11/24/14 13:33:18.449 Debug: GPIO path for GPIO with index 2 and device coc set to “/sys/class/gpio/gpio18”.
11/24/14 13:33:18.450 Debug: GPIO path for GPIO with index 1 and device coc set to “/sys/class/gpio/gpio17”.
11/24/14 13:33:20.458 Debug: Writing: X21
Ar
11/24/14 13:33:21.459 Initializing RPC client…
11/24/14 13:33:21.460 Starting XML RPC server RPCServer1 listening on 0.0.0.0:2001…
11/24/14 13:33:21.470 Starting XML RPC server RPCServer2 listening on 0.0.0.0:2002, SSL enabled…
11/24/14 13:33:21.474 RPC Server (Port 2001): Info: RPC Server started listening on address 0.0.0.0 and port 2001
11/24/14 13:33:21.537 Starting XML RPC server RPCServer3 listening on 0.0.0.0:2003, SSL enabled, authentification enabled…
11/24/14 13:33:21.546 RPC Server (Port 2002): Info: RPC Server started listening on address 0.0.0.0 and port 2002
11/24/14 13:33:21.599 Initializing event handler…
11/24/14 13:33:21.602 Loading events…
11/24/14 13:33:21.605 Startup complete.
11/24/14 13:33:21.608 All physical interfaces are connected now.
11/24/14 13:33:21.612 RPC Server (Port 2003): Info: RPC Server started listening on address 0.0.0.0 and port 2003
However, there’s no /var/run/homegear/homegear.sock created so I am unable to connect with ‘homegear -r’.
Any idea why?
When I use the eq3 software to pair my valve it doesn’t work, just loops with messages like this:
[quote]11/24/14 13:04:40.645 RPC Server (Port 2001): Info: Connection from 192.168.0.107:10702 accepted. Client number: 82
11/24/14 13:04:40.646 RPC Server (Port 2001): Listening for incoming packets from client number 82.
11/24/14 13:04:40.651 RPC Server (Port 2001): Debug: Packet received: 42696E000000001C000000146C697374426964636F73496E746572666163657300000000
11/24/14 13:04:40.652 RPC Server (Port 2001): Info: Client number 82 is calling RPC method: listBidcosInterfaces Parameters:
11/24/14 13:04:40.652 RPC Server (Port 2001): Response:
(Array length=1)
(Struct length=4)
[ADDRESS]
(String) VBC3984935
[CONNECTED]
(Boolean) 1
[DEFAULT]
(Boolean) 1
[DESCRIPTION]
(String) Homegear default BidCoS interface
11/24/14 13:04:40.654 RPC Server (Port 2001): Response binary:
42696E0100000087000001000000000100000101000000040000000741444452455353000000030000000A5642433339383439333500000009434F4E4E454354454400000002010000000744454641554C5400000002010000000B4445534352495054494F4E0000000300000021486F6D65676561722
064656661756C7420426964436F5320696E74657266616365
11/24/14 13:04:40.658 RPC Server (Port 2001): Info: Connection to client number 82 closed (3).
[/quote]
sathya
November 24, 2014, 12:53pm
2
Hey,
how did you start Homegear? Did you use the provided init script? “/var/run/homegear/homegear.sock” is only created, when Homegear is started as daemon. The only reason I can think of, is wrong permissions on “/var/run/homegear” or non existance of the directory. But the init script takes care of both issues.
For the second issue I need a log excerpt of the pairing process. It should work with the eQ-3 software. Did you factory reset your valve drive before pairing it?
Cheers,
Ok, yes that was the issue. I’m running a systemd based distro (arch linux, but soon also debian will have it) and therefor did not use the init-script. I’ll collect some infos on that in a github issue.
Now pairing does work, thanks for the fast reply!
