ich bekomme gefühlt nach einigen Tagen ohne Probleme mit Homegear plötzlich folgende Errormeldungen:
Error: Packet with data larger than 100 MiB received.
Danach scheint Homegear neu zu starten. Sobald dieser Fehler erstmalig auftrat, ist dieser nach jedem erneuten Start sofort wieder da, d.h. Homegear hängt quasi in einer Reboot-Schleife.
Hier das Error-Log:
04/19/18 15:48:24.406 Module Beckhoff: Error in file Interfaces.cpp line 45 in function virtual void MyFamily::Interfaces::create(): The provided hostname is empty.
04/19/18 15:48:24.411 Could not set owner for device /dev/serial/by-id/usb-0658_0200-if00: No such file or directory
04/19/18 15:48:24.412 Could not set permissions for device /dev/serial/by-id/usb-0658_0200-if00: No such file or directory
04/19/18 15:48:25.176 Warning: Unknown parameter property: label
04/19/18 15:48:25.177 Warning: Unknown parameter property: label
04/19/18 15:48:25.178 Warning: Unknown parameter property: label
04/19/18 15:48:25.179 Warning: Unknown parameter property: label
04/19/18 15:48:25.180 Warning: Unknown parameter property: label
04/19/18 15:48:25.195 Could not read device description files in directory: "/etc/homegear/devices/17/": Could not open directory "/etc/homegear/devices/17/"
04/19/18 15:48:25.195 Error: Could not initialize device family Z-Wave.
04/19/18 15:48:30.204 RPC Server (Port 2001): Warning: SSL is not enabled for this RPC server. It is strongly recommended to disable all unencrypted RPC servers when the connected clients support it.
04/19/18 15:48:30.204 RPC Server (Port 2001): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
04/19/18 15:48:30.205 RPC Server (Port 2002): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
04/19/18 15:50:12.493 Error: Packet with data larger than 100 MiB received.
04/19/18 15:52:06.282 Critical: RPC server's lifetick 2 was not updated for more than 120 seconds.
04/19/18 15:52:06.336 Critical: Killing child process.
04/19/18 15:52:06.347 Homegear was terminated. Restarting (1)...
04/19/18 15:52:16.338 Homegear was terminated. Restarting (2)...
04/19/18 15:52:16.604 Module CCU2: Error in file Interfaces.cpp line 287 in function virtual void MyFamily::Interfaces::create(): The provided hostname is empty.
04/19/18 15:52:16.627 Module Beckhoff: Error in file Interfaces.cpp line 45 in function virtual void MyFamily::Interfaces::create(): The provided hostname is empty.
04/19/18 15:52:16.633 Could not set owner for device /dev/serial/by-id/usb-0658_0200-if00: No such file or directory
04/19/18 15:52:16.633 Could not set permissions for device /dev/serial/by-id/usb-0658_0200-if00: No such file or directory
04/19/18 15:52:17.408 Warning: Unknown parameter property: label
04/19/18 15:52:17.410 Warning: Unknown parameter property: label
04/19/18 15:52:17.411 Warning: Unknown parameter property: label
04/19/18 15:52:17.412 Warning: Unknown parameter property: label
04/19/18 15:52:17.427 Could not read device description files in directory: "/etc/homegear/devices/17/": Could not open directory "/etc/homegear/devices/17/"
04/19/18 15:52:17.428 Error: Could not initialize device family Z-Wave.
04/19/18 15:52:22.437 RPC Server (Port 2001): Warning: SSL is not enabled for this RPC server. It is strongly recommended to disable all unencrypted RPC servers when the connected clients support it.
04/19/18 15:52:22.437 RPC Server (Port 2001): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
04/19/18 15:52:22.438 RPC Server (Port 2002): Warning: RPC server has no authorization enabled. Everybody on your local network can login into this installation. It is strongly recommended to enable authorization on all RPC servers when the connected clients support it.
04/19/18 15:55:12.868 Error: Packet with data larger than 100 MiB received.```
